Old 04-29-2013, 03:06 AM   #1
zandander
Member#: 281895
2005 Impreza WRX
Default radiator just took a dump.. replacement suggestions?
Well, as the title says my radiator just died on me. Was on the way home from the GFs house and all of a sudden all my lights got really dim. My first though was my Alt belt broke. So I eased on the next 3/4 mile to the house and when I got home the first thing I smelled was coolant. NO GOOD!
Popped the hood and it was steaming like crazy from around the radiator. Took a few minutes for the steam to go away but once it did I noticed that it looked as if the coolant was coming out from the top endtank :/
I also squeezed the upper rad hose and it felt compeltely devoid of fluid, but doing that it made some more coolant splash out around the endtank..
So, long story short, what brands would you guys recommend? I'm looking for OE style (would love all aluminum, but my wallet wont as much) that will last and would LIKE to try and find a good one for under $200
I've been looking at KOYO, Mishimoto, and GMS.
So please, if you guys have had experience with this please let me know ASAP!
Thanks in advance!
Zander
zandander is offline   Reply With Quote
Old 04-29-2013, 05:40 AM   #2
missmysubie
Member#: 313857
07 STI LTD
(Mustang) 306/346 VF48
I've had good luck with my mishimoto....and had to go this route because the same thing happened to me.....luckily I caught it earlier than you did....but it might cost you a lil over 200...but well worth the piece of mind the crappy plastic endcap won't be a problem anymore.
missmysubie is offline   Reply With Quote
Old 04-29-2013, 06:47 AM   #3
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
I wouldn't go with oem plastic end tanks. Aluminum would be my first choice. Misimoto is a quality piece. Can be picked up for about $300 or so I picked up the mishi x-line for $300.
wrxlaunch is online now   Reply With Quote
Old 04-29-2013, 01:20 PM   #4
snowmanwithahat
Member#: 328283
2004 STi
I went with the Koyorad aluminum radiator though. I doubt it matters much as long as you stay away from the plastic end-tanks. I had the EXACT same problem with my stock one. Sprung a leak through stress fractured plastic at the top of end-tank.
My exact purchase... been very happy with it. That and some nice red Samco hoses and you have a pretty sexy looking engine bay.
http://www.oakos.com/Merchant2/merch...gory_Code=3230
snowmanwithahat is offline   Reply With Quote
Old 04-29-2013, 08:14 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Nearly any aluminum replacement will do. A simple search finds MANY great results with even Ebay ones.
Old 04-29-2013, 09:28 AM   #6
greenplates
Member#: 239162
I purchased a Mishimoto for same ball park price of an OEM plastic radiator.
It has been great for the last 2 years. No issues what so ever. You will also see the running temperature drastically lower [dual core aluminum radiator]
greenplates is offline   Reply With Quote
Old 04-29-2013, 09:38 AM   #7
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
How so? Not trying to be an ass btw. I installed a mishi xline and temp gauge is same position as oem plastic when it reaches operating temp
Old 04-29-2013, 12:34 PM   #8
greenplates
Member#: 239162
My car runs cooler. I also replaced the thermostat while coolant was drained (thermostat was like $11 bucks).
Rather than a single core, plastic radiator. The Mishimoto is a dual core aluminum radiator with greater airflow for cooling fins and greater cooling capacity.
Also, its not so much about reducing temperature as it is maintaining a proper running temperature on very hot summer day in traffic OR driving hard in mountains. Stock radiators are designed for commuting to work
Old 04-29-2013, 09:42 AM   #9
zandander
Member#: 281895
2005 Impreza WRX
Thanks for the replies guys. I'll keep looking around for the rest of the day.
Speaking of all aluminium rads, gimmick motorsports has an all Al rad for 195!
Old 04-29-2013, 11:31 AM   #10
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
Unless you are racing the car or just want the looks save your money and get a good OEM replacement. Your daily driven street car does not need a larger capacity radiator.
WRXSleeper is offline   Reply With Quote
Old 04-29-2013, 11:45 AM   #11
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
1. It's not about capacity. It's about getting rid of the POS failure prone plastic end tanks.
2. OP. Search. Then PM Ron.
bushflyr is offline   Reply With Quote
Old 04-29-2013, 01:04 PM   #12
WRXSleeper
Member#: 43853
Platinum Silver
You do realize that basically every car on the road has a radiator with plastics end tanks right?
You then also realize that at this point if you own a 02-05 WRX you have an old car with probably 100k+ mileage. If the stock radiator lasted 8-10 years and 100k+ how much more do you really plan to keep the car that you need to worry about the end tanks failing again?
At this point in my ownership of this car I am not going to spend extra money where it is not necessary when I only plan to keep this car another 2-3 years.
Yes, there were some bad radiators from factory. I had mine replaced around 20k under warranty. It didn't burst, it was a slow leak where the plastic meets the metal.
Old 04-29-2013, 01:16 PM   #13
mikesh_21
Member#: 337809
Default Mishimoto X-line Rad
I just purchased and installed the following:
http://www.mishimoto.com/subaru-wrx-...01-triple.html
Got it off of Amazon for 315, I know out of your price range but definitely worth it. After getting it fully installed and refilling it I turned the car on to run it until the fans kicked on so that I could make sure I had all the air bubbles out. Well, needless to say, after 30 minutes the fans never kicked on (dont worry they have since and I know they work it was just a cooler day and the new Rad was doing an amazing job cooling).
Anyways, I just wanted to say that so far I am extremely pleased with the new Rad and I would definitely recommend it if you can up the extra bill for it.
p.s. make sure your oil filter does not seem to leak a tiny bit because if it does change out your oil cooler o-ring.
There is a great thread for doing this here: http://forums.nasioc.com/forums/show....php?t=1683668
(I know I am not supposed to "cross reference" but I felt like this is a valid reason for doing it.)
Great to do the 2 at the same time since you kinda have to drain your coolant to replace that ring. Just a little bit of hindsight that I missed since I am now on my second batch of coolant and oil filter/oil.
p.p.s. I will be putting some serious miles on the wagon this upcoming month so I will keep in touch with how the radiator holds up.
mikesh_21 is offline   Reply With Quote
Old 04-29-2013, 11:39 AM   #14
Turd Nugget
Member#: 346017
2013 STi Wagon
I have used sub $100 all aluminum ebay rads on multiple cars, never had a problem with any. I have one thats been going on 6 years on a 400+whp honda of mine.
Turd Nugget is offline   Reply With Quote
Old 04-29-2013, 12:46 PM   #15
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Stock temp thermostat?
Old 04-29-2013, 12:54 PM   #16
zandander
Member#: 281895
2005 Impreza WRX
Not looking for greater capacity, just trying to get rid of the plastic endtank failure. And when you say Ron, you mean unabomber?
Old 04-29-2013, 08:04 PM   #17
neurosis05
Member#: 230265
2005 WRX stage II
yeah, I PM'ed unabomber and he gots da hook up. Seriously though, he can get you discounts. I got my Mishimoto radiator with his help and saved a bundle. It's shiny
neurosis05 is offline   Reply With Quote
Old 04-29-2013, 09:54 PM   #18
skirex
Member#: 157782
2005 WRX Wagon
my radiator failed at about 60k, got a mishimoto radiator for $250 ish?, cant remember where, have since put on 40k miles over the last 4 yrs without a single problem.
skirex is offline   Reply With Quote
Old 04-29-2013, 07:52 PM   #19
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
I have had good luck with gimmick radiators. I think is was only 190$ thru a vender on this site.
Cois32 is offline   Reply With Quote
Old 04-29-2013, 10:36 PM   #20
zandander
Member#: 281895
2005 Impreza WRX
Got a good price on a gimmick rad. Anyone have any issues with them? Talking about on a personal level, not any he said she said stuff.
Old 04-29-2013, 10:45 PM   #21
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Car part reviews, or Google search it.
Old 04-29-2013, 11:10 PM   #22
SnowBRDGod247
Member#: 319756
2002 Audi S4
Just had my oem replaced on my 2002 w a koyo and it is awesome. Very good looking radiator and super well built should literally last forever vs the oem.
SnowBRDGod247 is offline   Reply With Quote
Old 04-30-2013, 12:21 PM   #23
Ravendas
Member#: 158399
2003 WRX
If you're not racing, Ebay all aluminium is the way to go. Been running mine for 3 years now with occasional light track duty without any issues at all.
Ravendas is offline   Reply With Quote
Old 04-30-2013, 02:48 PM   #24
Mr.Sparkle
Member#: 83725
2015 WRX
I bought a CX Racing aluminum rad off ebay when my stock one failed. Cost about $130 but not 2 years later it sprung a leak. I then got a Mishimoto and couldn't be happier.
Mr.Sparkle is offline   Reply With Quote
Old 05-01-2013, 12:46 AM   #25
zandander
Member#: 281895
2005 Impreza WRX
Just ordered the gms rad. Will update when it comes in and after I install it! Thanks for all the replies guys!
