Old 05-08-2013, 10:14 PM   #1
BuckeyeMark
Member#: 267893
2003 WRX sport wagon
sonic yellow
Default JDM V7 grill - how to attach to USDM WRX
Hi Guys,
Looking for some advice here. I have a grill that I believe to be a JDM V7 Non-sport variety from an STi. I have painted the grill to match my sonic yellow bugeye but have discovered that the mounting clips are different from my stock 2003 grill. Wondering if there is an oem grill clip that might work. Does anyone know if there is an off the shelf grill clip that willl solve this problem?
Picture here:
http://s1058.photobucket.com/user/MA...%20WRX%20parts
Thanks in advance for your help.
Mark
BuckeyeMark is offline   Reply With Quote
Old 05-08-2013, 10:20 PM   #2
25rsti
Member#: 166324
That's not a jdm STi grille. You're going to have to figure something out. It should mount just like your stock one.
25rsti is offline   Reply With Quote
Old 05-09-2013, 01:07 AM   #3
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
it is a jdm sti grille it's just not the "sport" version
http://www.jdm-online.com/sold/jdm-s...-nose-cut.html
OP: just drill out the holes in the rad support and use some plastic pushpins to mount it, personally i believe that was a replica as a genuine subaru V7 grille would not have holes like that to mount with. I have gotten 2 genuine JDM STi grilles and neither had the holes shaped like that. Unless you can prove otherwise that it is a genuine item then it appears you got a used item with which the previous owner(s) drilled the holes to be that shape.
brew02wrx is offline   Reply With Quote
Old 05-09-2013, 01:17 AM   #4
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
looks like aftermarket or something..
murrdogg24 is offline   Reply With Quote
Old 05-09-2013, 08:08 AM   #5
BuckeyeMark
Member#: 267893
sonic yellow
Thanks for the input guys.
I purchased this grill from a very reputable seller here on NASIOC who took it from a full front clip that he had imported. I suppose it is possible that an aftermarket grill was fitted in Japan. However I have seen other images of non-sport grills very much like this on JDM STis. I also received the grill side pieces with the "vent" cutouts as well as the V7 STi scoop from this clip and they appear to be authentic.
The mounting holes are in exactly the right places, just too big. I am almost sure they have not been drilled. There are no signs of drill marks and the plastic is built up around the holes as you would expect for them being molded that way.
I'll keep looking.
Old 05-09-2013, 10:56 AM   #6
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
That is a genome STi grille, with optional center piece for the emblem.
You can put in a rubber grommet so the snap pins that mount on the front clip engage the 4 larger holes on the top side of that grille.
I believe the bottom 2 should snap right into the bugeye headlight openings.
satrya is offline   Reply With Quote
Old 05-09-2013, 11:02 AM   #7
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Found the link at japanparts:
http://www.japanparts.com/db/partsli...mall=11&page=4
It is listed as the Sports Grille; I believe it came out when the Genome STi parts came out for the first year of the bugeyes (along with the Genome STi re-branded gauges)
Sports grille (from japanparts):
Sports grille with optional ornament:
Old 05-09-2013, 12:32 PM   #8
BuckeyeMark
Member#: 267893
sonic yellow
Wow, this is super helpful! Thank you Satrya. That is exactly what my parts look like. I like the rubber grommet idea.
Old 05-09-2013, 01:20 PM   #9
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
You're welcome. Or you can just put a 1" screw behind the front clip, attach it with a washer and nut on the front side of the front clip. Then, drill a hole on the top of the screw for a cotter pin. I've been meaning to do just that on mine.
The Genome STi grilles (this and the 2 other models) aren't that popular.
Old 05-13-2013, 10:21 PM   #10
25rsti
Member#: 166324
I sit corrected.
Old 05-14-2013, 04:09 AM   #11
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
zip tie through the holes
bbun is offline   Reply With Quote
Old 05-14-2013, 04:48 PM   #12
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
that's what I did lol.
Mr.Chow is offline   Reply With Quote
Old 05-14-2013, 10:08 AM   #13
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
i had an "aftermarket" grill on my RS, mounting didn't line up, drilled holes, used zipties the first time around, then found some plastic push rivets small enough to use. good luck.
VTSubieRS is offline   Reply With Quote
Old 05-15-2013, 10:14 PM   #14
BuckeyeMark
Member#: 267893
sonic yellow
I followed satrya's advice and I am very pleased with the results. I used some stainless steel hex bolts with some fender washers and stainless nuts. Here are some pictures:
http://s1058.photobucket.com/user/MA...Genome%20Grill
Thanks again for the help.
Mark
Old 05-16-2013, 11:04 AM   #15
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Looks good.
I see you also use the "grille side pieces" that goes with the Genome grille. That almost begs for the side vents on the front bumper cover to have slats like the sedan version. I used it for a while but imho, the oem one flows better with the Genome Sports Grille.
Btw, any thoughts about painting the "optional ornament"?
Old 05-16-2013, 09:47 PM   #16
BuckeyeMark
Member#: 267893
sonic yellow
Yeah, the Genome side pieces are a little cheesy as they are not real vents. They are distinctive though. Overall, I am pleased with the look.
Regarding painting the ornament mount... Mine is made of a hard rubber. Not sure how well it would take and hold paint. I cleaned mine up and hit it with some black plastic sealant and it looks pretty good.
I am getting to where I dont have too many more things that I want to change on the car. My scoop is a genuine V7 STi complete with the splitter with the IC sprayers. I also have a V7 water tank and the IC Spray switch for the dash. Need to figure out how to get that mounted and wired up.
