Old 09-29-2002, 05:07 PM   #1
JohnnyRex
Member#: 25167
2002 Subaru WRX
Black Stolen...
Exclamation Don't like your daylight runtime lights?
Don't like your daylight runtime lights? They annoyed me when I bought the car, so I made sure that was the first thing I got rid of. It's quite easy to do for anyone else that wants to get rid of them. If you look near the turbo, just infront and to the left of it, there is a square silver part that says "CAUTION HIGH TEMP" on it. On the bottom of that part there is a connection. Simply unplug that, and walla...no more daylight runtime lights I went as far as taking the part off. It can be easily dont with 2 small bolts that hold it in place. Then I just took the wire that got unplugged from it and zip tied it to another wire. Any questions?
JohnnyRex
JohnnyRex is offline   Reply With Quote
Old 09-29-2002, 05:34 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Well, congratulations on doing this mod, but be assured it's not breaking news on here
There are many threads and links to instructions on disabling the DRL's. And FYI, the part you disconnected/removed is not the main module but rather just a load resistor. In DRL mode the low beams are connected to ground through this resistor so they operate at reduced intensity. As long as you have the stock headlights this is all you need to disconnect to eliminate the DRL operation.
There is also another module, located next to the glovebox in the passenger side kick panel, that is the actual DRL control unit. If you ever install HID lights this module will need to be disconnected as well.
Oh Yeah! Well, we don't like your kind around here very much either chapstien Off-Topic 33 03-16-2010 12:29 PM
Don't like your kids? Go on strike! America cries :( Mr_Blastman Off-Topic 12 02-22-2008 02:23 PM
CDW: I don't like the color of your house Mk750 Mid West Subaru Owners Club Forum -- MWSOC 1 04-12-2005 02:33 PM
Don't like your STi wing? -White STi Only- Subaruist Member's Car Gallery 5 03-30-2004 10:09 AM
Things you don't like about your legacy? kkozma Legacy Forum 33 11-06-2001 12:16 AM
Message Board Statistics All times are GMT -4. The time now is 11:16 AM.
