Old 06-20-2013, 10:46 PM   #1
Isleblue65
Member#: 359400
2013 WRX
Default Tactrix driver will not load on XP laptop
Hi all,
I am unable to complete the installation of the Tactrix Open ECU 2.0 driver on my garage laptop, which is an older one running XP. It loaded fine on my main computer running Win 7.
I did the installs the same, so not sure what's going on. I sent Tactrix tech help an email and they have not replied back.
this is a print screen of what I see during attempted install:
Any suggestions?
Isleblue65 is offline   Reply With Quote
Old 06-22-2013, 09:33 AM   #2
quazimoto
Member#: 70395
Don't let windows instal it automatically. Manually install the driver.
Old 06-23-2013, 12:34 PM   #3
Isleblue65
Member#: 359400
2013 WRX
The xp laptop does not recognize the device (Tactrix cable), so I can't click on "device" to manually install the drivers. When I plug in the cable, there are two audible 'dings' where usually a new device dings once and is recognized.
I don't know of any other way to manually install the drivers.
My other laptop running windows 7 works fine and I can connect to my ECU - I was just hoping to keep it on my old garage laptop rather than drag the good one out there for tuning purposes.
Old 06-23-2013, 08:22 PM   #4
quazimoto
Member#: 70395
Make sure you have the latest Java and Windows updates.
Old 06-23-2013, 10:12 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The background makes it look like you were still in the process of installing ECUFlash at the time? ECUFlash includes the Tactrix drivers, it must be installed first before you plug in the cable.
Old 06-24-2013, 12:57 AM   #6
Isleblue65
Member#: 359400
2013 WRX
Yes I was installing ECU Flash, and at one point during that install, the Tactrix drivers window comes up. It then asks you to make sure your Tactrix 2.0 cable is plugged into the computer and then press 'Next'. At this point it tries to download the drivers for about a minute, and then the 'cannot complete device driver install' window comes up. There is something wrong with the laptop which I need to figure out. I'm going to search for and install all other outdated drivers, and see where that gets me. I updated Java and all Windows updates a few days ago, as that was my first thought.
Thanks for the ideas.
Old 06-25-2013, 12:25 PM   #7
Captdonno
Member#: 358459
2013 WRX
WR Blue Pearl Sedan
Did you try downloading the driver straight from Tactrix's site?
http://http://www.tactrix.com/index....d=38&Itemid=61
Windows XP doesn't automatically search and install updates like Vista/7 does. You usually have to manually install the drivers from either an installation CD or straight from the site.
Captdonno is offline   Reply With Quote
Old 06-27-2013, 05:23 PM   #8
mikeyPSF
Member#: 236475
Sorry we didn't see the email you sent to Tactrix support. What email address did you send it to? Or what was the date and your first name?
You definitely aren't ever prompted to connect the OpenPort during EcuFlash install. It shouldn't cause a problem if you do, but I generally do not have it connected. You are prompted to install both the 1.3 and 2.0 drivers but feel free to skip the 1.3 drivers if you don't have that device.
You also don't need Java for EcuFlash. You will for RomRaider, but EcuFlash doesn't use Java at all.
Are you logged in as a user with admin rights?
mikeyPSF is offline   Reply With Quote
Old 06-27-2013, 08:30 PM   #9
Isleblue65
Member#: 359400
2013 WRX
Thanks for replying here. I sent it to [email protected] on 6/20/13 in the morning, and first name is Craig. I don't believe I was ever prompted to install drivers; I think it just began installing them automatically, after which the installation failed and the window in the print screen image appeared.
I am logged in as an admin. I was able to download the software on my other laptop running Windows 7 with no issues, and flash my ECU with the Tactrix cable. However my old XP laptop is loaded with all of my .PDF manuals and automotive-related software, and it doesn't matter if it gets a little grease on it.
I have not tried it again since making this post, so I'll give it another try, and make sure I am logged in as an admin (I should be as I'm the only user of the computer, and my name is the computer name).
Old 06-28-2013, 09:22 PM   #10
mikeyPSF
Member#: 236475
Sorry Craig, I don't see a ticket on that date from you. That's annoying.
If it fails again on this attempt, could you grab the setupact.log file, zip it (if it's too large to email), and email that to support at tactrix? That file will show very detailed information about the install so we can see what went wrong. That file should be located in your C:\Windows directory.
Old 07-02-2013, 03:07 PM   #11
Isleblue65
Member#: 359400
2013 WRX
Last night I attempted this again. I first uninstalled ECUFlash, and then reinstalled it. This time it looked like it worked. Something came up that said all drivers had been installed successfully. I thought I was in the clear until I plugged in my Tactrix cable and a Microsoft window came up asking if I would like to install the drivers for the device using a CD rom, search for them myself or use the Web to find them. I tried to direct the device to the ECUFlash folder where the drivers are, but another error window came up saying something about drivers not being available.
So I emailed my setupact.log file to you (actually there were 2 of them, so I included both)
Anything you can do to help me get this garage PC up and running would be much appreciated!
Old 07-02-2013, 03:08 PM   #12
Isleblue65
Member#: 359400
2013 WRX
