Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-02-2002, 01:50 PM   #1
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Platinum Silver, Stage2
Question Reducing Exhaust Noise in Cabin
Just put in a new exhaust and although the sound outside of the car is certainly not as loud as many on the market, doesn't call a lot of attention to my car and most importantly I like it!
I do NOT want to put a silencer on my exhaust or hack it in any way.
The noise inside my wagon however is a bit louder than my wife would like. The low end drone takes a bit getting used to.
Wanted to know your opinions and feedback on:
1) the use of sound dampening material (i.e., Dynomat Extreme) in the doors and floor of the the trunk space as an effective way to reduce noise
2) Besides those places I mentioned, where else should I use the material in the car
I'd like to hear the opinions especially from all of the audiophiles with performance exhaust. I figure you would know most about the best method to get the most out of your audio AND performance.
Thanks ahead of time!
topcover is offline   Reply With Quote
Old 10-02-2002, 02:06 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I'd concentrate on the floor of the trunk and the floor in front of the back seat simply because this is where the noise should be most prominent. I suppose you could try using an SPL meter to verify this is the case, someone probably has one they'd let you borrow for a couple days.
Materials you should be looking at should at the very least have a thin sheet of aluminum. Ideally you'd want lead bonded to the damping material. It's not as ridiculous as it sounds, thin sheets of lead are flexible and not THAT heavy (~1 pound per sq foot). McMaster-Carr sells them for sound BARRIER purposes. After all, it's much more effective to not let the sound in in the first place than it is to damp it once it gets into the car.
Constraining it to damping material will be even more effective. Sound must travel through the damping material, then gets reflected by the lead sheet back into the damping material again.
If you go with an off the shelf product, try to get one with as thick of a barrier layer as possible. Think reflection rather than absorbtion.
Old 10-02-2002, 10:42 PM   #3
prodrive121
Guest
Member#:
What about the general reduction of cabin noise? is there a way taht one could fill the head liner? would it help
Old 10-03-2002, 01:09 AM   #4
Rattler
Member#: 6351
2004 Tacoma 2xCab
\m/ \m/
What kind of exhaust did you put on? I HAD a Borla. Its not on the car because of the droning it produced. Another guy had the Borla and installed a different muffler, some type of race muffler, and it disappeared. I yanked mine off and went with a Prodrive muffler. It was neat being loud but it got old after a while.
Rattler is offline   Reply With Quote
Old 10-03-2002, 01:16 AM   #5
jland67
Member#: 14427
2002 09 Mazdaspeed 3
Grey
I am going to use RaamMAt on my car this weekend. Check out this link of several people who have already use sound deading materials in there cars.
http://forums.nasioc.com/forums/show...hreadid=208027
Jland
jland67 is offline   Reply With Quote
Old 10-03-2002, 01:45 AM   #6
rayder
Member#: 14535
02 Impreza WRX
man that stuff gets heavy if you do it how i used to do it for car audio...
I know firewall, floor board, and trunk areas make a hug difference.
rayder is offline   Reply With Quote
Old 10-03-2002, 01:49 AM   #7
sevenhead
Member#: 15073
2002 WRX Sedan
Lotus Seven, A-H 3000
Hey, he has a Vishnu Stage 2. Wonder if he has bell-mouth downpipe and twin tip muffler or signature downpipe with single tip? Wonder if the drone would be as apparent in a sedan?
Lee
sevenhead is offline   Reply With Quote
Old 10-03-2002, 02:31 AM   #8
topcover
Member#: 8999
2002 EJ25 FXT Wagon
The exhaust is the Vishnu non-signature exhaust. It is a beautiful piece of work and the noise outside is not loud. Let me lay out some other parameters.
1) Not loud on the outside.
2) Other i-club members especially the younger ones don't consider it loud.
3) The biggest complaint is coming from MY WIFE. For those of you who are married you understand.
Actually a day after the install, I'm getting used to it. (note: "I'm getting used to it") Just wanted some options.
QUESTIONS:
1) Should I start with the trunk, rear floor boards and work my way toward the front and check as I go?
2) Besides me doing this myself. Would reputable car audio places be able to do this work?
Old 10-03-2002, 02:35 AM   #9
rayder
Member#: 14535
02 Impreza WRX
yes, but you shoudl do it yourself. Most installers assume you won't be pulling your carpet.. and won't take the time to do it right.
If you don't heat it up and apply correctly... it will not dampen as well as it can.
It's been awhile, and there amy be tons of new stuff since I was an installer... but back when i was installing, Super Dynamat was the bomb. I would use a few layers of that, then use the dampening spray over it.
That was before i cared about weight though...
Old 10-03-2002, 03:31 AM   #10
SonicYellowWRX
Guest
Member#: 23351
Pika Chu!
TEAM DARRIIFFFTAA
well... i guess you should try lining the trunk first to see if that is acceptable by the wifey. lining the firewall and floorboard would require WAAY too much work! another idea might be to line the hood?
SonicYellowWRX is offline   Reply With Quote
Old 10-03-2002, 10:53 AM   #11
TurboRex
Member#: 8635
04 STI, 07 FXT
I would go another route. Add a resonator. This will quiet it down quite a bit without hurting performance or messing up your car.
Greg
TurboRex is offline   Reply With Quote
Old 10-03-2002, 02:09 PM   #12
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Greg
Greg -
Believe it or not... it already has a resonator!
Old 10-03-2002, 02:17 PM   #13
kenchan
Member#: 15106
give it 2 weeks, ur wife will get use to it.
kenchan is offline   Reply With Quote
Old 10-03-2002, 03:10 PM   #14
TurboRex
Member#: 8635
04 STI, 07 FXT
Add another one! I have one resonators and two mufflers. The sound is still noticeable but adding the second muffler (looks like a resonator) made my wife comment on how much quieter it was.
Greg
Old 10-03-2002, 03:33 PM   #15
SonicYellowWRX
Guest
Member#: 23351
Pika Chu!
TEAM DARRIIFFFTAA
Greg
thats the best thing to do, but he doesnt wanna hack his exhaust up to add another.
Old 10-03-2002, 03:44 PM   #16
TurboRex
Member#: 8635
04 STI, 07 FXT
Yeah, I know what you mean. I hated doing it to mine since it was a nice turbo back exhaust system. However, I think it is a better flowing exhaust now and quieter as well.
Greg
Old 10-03-2002, 08:14 PM   #17
j y
Member#: 8829
GRB STI
I have had great results with this stuff in my previous car:
Cascade Audio Engineering VB-1X spray
Really easy to apply (just spray it on and let dry) and it does a good job of damping exhaust and road noise. No messing around with heavy Dynamat sheets.
-Jeff
j y is offline   Reply With Quote
Old 10-03-2002, 09:06 PM   #18
tnmn28
Member#: 16071
2005 G35 Sedan
Twilight Blue
Stan,
Remove your VS-2 and return it to stock. Then you can sell the setup to me cheap!
tnmn28 is offline   Reply With Quote
Old 10-04-2002, 01:28 AM   #19
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
Stan,
Get some ear plugs!!!! lol
Calvin
RimRockaz is offline   Reply With Quote
Old 10-04-2002, 01:52 AM   #20
topcover
Member#: 8999
2002 EJ25 FXT Wagon
Yeah... I'm gonna go ahead and wait a few weeks and see if we don't get used to it. I'm already there. My 6 y/o thinks its kinda cool and my wife after three days is still undecided.
If by that time she's still not used to it, I think I'll go ahead and buy a roll of RaamMat that Jland suggested and start on the floor of the trunk and work forward.
If that doesn't work, I think I'll go ahead and talk to my lawyer about getting the divorce papers drawn up.
Old 10-04-2002, 01:12 PM   #21
bcristea
Member#: 11343
2008 STi
Its best to stop the noise at its source.
There's not much you can do to the stock headliner to absorb more interior noise.
Brian
bcristea is offline   Reply With Quote
Old 10-04-2002, 02:27 PM   #22
thrashvr6
Member#: 2226
2002 V70 Wagon
Red
Yeah, have you considered sticking a sock in your wife's mouth?
(If my wife sees this I'm dead..)
thrashvr6 is offline   Reply With Quote
Scratching/Scraping noise in Cabin. Engine Noise? Help! seasons Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-22-2005 07:34 PM
Way to reduce exhaust noise coming into cabin area txl146 Car Audio, Video & Security 21 12-22-2004 01:50 PM
Increase noise in cabin while braking to a stop S-WRX Brakes, Steering & Suspension 1 06-01-2004 02:43 AM
help! need to reduce exhaust noise BlueWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-04-2002 10:15 AM
Reducing cluking noise in TEINs zacek Brakes, Steering & Suspension 2 08-07-2002 04:03 PM
