Old 11-18-2002, 06:56 PM   #1
TheWeis
Member#: 17939
2002 WRX Sedan
Default Broken banjo bolt in a stoptech caliper?
Friend and I were working on his WRX, adding the Stoptech big brake kit, and I made the mistake of letting him do some of the work himself...he ignored the torque wrench and kept going, snapping off a banjo bolt in one of his nice new calipers. I tried to vise grip out the stub, but it is in there hard. Any ideas? Thanks.
TheWeis is offline   Reply With Quote
Old 11-18-2002, 06:59 PM   #2
D_REX
Member#: 8945
MY02 WRX
Default Re: Broken banjo bolt in a stoptech caliper?
Get an easy out, youll need to drill a hole in it, and then the easy out will alloy you to extract it.
D_REX is offline   Reply With Quote
Old 11-18-2002, 07:27 PM   #3
tdxflex
Member#: 13634
i've never used an easy-out but from what i hear they're kind of brittle. for speed bleeders it's recommended you drill a hole, then lightly hammer in an allen key in the middle and try to twist it out, if it strips, go up a size drill bit and allen key.
tdxflex is offline   Reply With Quote
Old 11-19-2002, 11:39 PM   #4
TheWeis
Member#: 17939
2002 WRX Sedan
I'm nervous about putting a drill into this bolt as chips could easily fall into the caliper, causing some problem. I will look into this easy out thing.
Old 11-20-2002, 12:21 AM   #5
D_REX
Member#: 8945
MY02 WRX
If you read my post above youll see that the Easy Out is really just a specialized version of the method tdxflex suggested. It requires you to drill a hole in the banjo bolt.
Old 11-20-2002, 09:34 AM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default every
banjo bolt Ive seen already has a hole through it. Did it break off low enough to get to the hole in the bolt? If so an easy out (or bolt extractor) is the way to go. It is agressively reverse threaded so it tightens into the bolt counterclockwise and tries to break the blot shaft loose. Of course, there shouldnt be much resistance to the bolt shaft coming back out anyway as I assume it was recently loose and not seized in place.
On a side note, invest in a torque wrench.
HTH
ss
subysouth is offline   Reply With Quote
Old 11-20-2002, 11:37 AM   #7
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
dont banjo bolts already have a hole in the middle?
or did it snap off above where the hole ends
elgorey is offline   Reply With Quote
HELP!!!! - Need Banjo Bolt in Rockville MD kumanchu Mid Atlantic Impreza Club -- MAIC 3 04-27-2009 12:59 PM
i need a wrx power steering pump banjo bolt in MKE asap scobaru Mid West Subaru Owners Club Forum -- MWSOC 3 09-24-2007 01:19 AM
Stripped banjo bolt hole in brake caliper? Fix it!!! thrdeye Brakes, Steering & Suspension 0 10-14-2005 03:10 PM
What size washers do I need for banjo bolts on brake caliper? thrdeye South East Region Forum 27 10-14-2005 01:15 AM
Stock Banjo bolt same as Stoptech Banjo bolt? mav1c Tire & Wheel 3 11-22-2004 10:15 AM
