Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 12-02-2002, 10:02 PM   #1
Tobey
Member#: 21400
2015 WRX Limited
ISM
Default autometer egt gauges, what egt probe are you using?
just called summit and they couldn't give me a definate answer on which one to buy. just did a search with little luck, any ideas? i'm guessing the 5249 kit will work, but i can't see a picture of it anywhere on autometers website.
from the pics of their other probe kits, it doesn't look like these screw in? maybe it's the pcitures or i'm not seeing it, but i'm lost.
any help would be greatly appreciated.............
Tobey is offline   Reply With Quote
Old 12-02-2002, 10:14 PM   #2
jjunior887
Member#: 16738
2015 WRX Limited
CWP
I got the 5249 kit and it is the screw in type. you will have to tap the manifold with an 1/8" npt tap for it to fit. here's the pic from summit
Not exactly the same as the one you get but it's pretty close. BTW I have heard the Westach probe reacts a bit faster but mine seems to work well enough for what i use it for. good luck-James
jjunior887 is offline   Reply With Quote
Old 12-03-2002, 12:37 AM   #3
Tobey
Member#: 21400
2015 WRX Limited
ISM
that's great info, thanks!!
Old 12-03-2002, 12:48 AM   #4
D_REX
Member#: 8945
MY02 WRX
I've heard the exact opposite. The sheilded tip on the westach probes should be more durable. They do make an exposed tip part, but they didn't reccomend it when I talked to them, said it wouldn't last long.
D_REX is offline   Reply With Quote
Old 12-03-2002, 01:42 PM   #5
Tobey
Member#: 21400
2015 WRX Limited
ISM
last question on that 5249, do i need a sendor or does that probe wire into the gauge itself? i just want to make sure i order everything at once!
thanks for the info~
Old 12-03-2002, 03:09 PM   #6
D_REX
Member#: 8945
MY02 WRX
The gauge should come with everything you need to interface to the probe.
Old 12-03-2002, 07:55 PM   #7
jjunior887
Member#: 16738
2015 WRX Limited
CWP
What he said. Glad i ended up with the autometer probe, I never heard a bad thing about Westach until you said something. Makes sense though. Thanks-James
Old 12-03-2002, 09:05 PM   #8
Tobey
Member#: 21400
2015 WRX Limited
ISM
i have had autometer in the pats and they were always good to me about fixing something, and their customer service rocks. i think the autometer would be better to use just because it is meant to work with their gauge. however having never seen either the guage or the probe, the other may work just fine.
anyway, i do thank you guys for the insight, it's much appreciated!
Old 12-04-2002, 12:13 AM   #9
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Tobey
Got this from Autometer last year.
Thank you for your further inquiry. The 4365 is a competition gauge
set-up and thus is designed with higher accuracy and response time than
the 4344 which is designed more as an entry-level kit for a more
every-day type of use where durability is more of an issue than response
time. The following information is part of a write up by one of our
engineers regarding EGT's and specifically the differences in the
various types of thermocouples that we have available:
"When choosing EGT probes, one needs to consider the tradeoff between
longevity and response time. Auto Meter's 4365 uses standard type-K
thermocouple probes of which four types are available.
1) Model 5249 Severe Duty Closed Tip Probe for use with a Weld-in-Bung
This probe offers the most longevity for severe applications.
It has the slowest response time but is recommended when longevity needs
to be maximized in severe applications that employ turbo or super
charging, nitrous oxide or diesel fuel with water injection.
2) Model 5244 Standard Duty Open Tip Probe for use with a Weld-In-Bung
This probe inherently has the quickest response time of all available
type-K probes, as the junction is isolated and openly extended beyond
the probe's body.
It is not possible to make a response time faster than this probe offers
unless you decrease the overall mass of the weld point. This in turn
would drop the reliability under high temperatures.
Use this probe in Gasoline or Alcohol applications where a quick
response time is desired.
3) Model 5243 Severe Duty Open Tip Probe for use with Weld-In-Bung
This probe is also quick to respond but offers improved reliability by
retracting the junction to a point just above the probes body for more
Use this probe for all severe applications that demand a quicker
response time. Although it is compatible with all fuels, open probes
should not be utilized with diesel engines that employ water injection.
This probe is also not recommended for turbo-charged drag racing engines
that retard timing to quickly spool-up the turbo.
4) Model 5247 Standard Duty Open Tip Probe for use with a Clamp-Around
mount
This probe has the same operational characteristics as the 5244 but is
designed for a quick and simple "Street" installation that does not
require welding.
Type-K EGT Operation Primer
If applied correctly, Type-K EGT thermocouples are fairly rugged devices
considering the environment that they are required to operate. They
obtain durability with simplicity. Like any thermocouple, Type-K
thermocouples use two dissimilar metals that are welded together. The
Type-K materials are Nickel-Aluminum and Nickel-Chromium. Any two
dissimilar metals that make contact will form a small thermoelectric
voltage measured in thousandths of volts. The voltage is dependent upon
the temperature of the contact point of the metals. As most things
developed from nature, this voltage is non-linear over temperature. But
assuming the metals remain in contact, the small voltage will always be
there and the voltage values will always be the same for any given
temperature. Thermocouples are self powered devices that convert
temperature to voltage, this makes them attractive for a variety of
applications which measure temperature. The Type-K thermocouple
temperature range is -450F to +2500F. The corresponding voltages
offered are -6.456 mV to 54.856 mV (0.054856 Volts) respectively.
Because the voltage output is so small, amplification is required to
make the signals obtained from the sensors do useful and intelligent
work (ie: record values and trigger outputs). All amplification requires
external power, so expect a connection to your vehicle's power source to
make the system function.
I hope this information proves to be both helpful and inciteful to you
when you make your choices regarding which of our products will be best
for your application.
Thanks!
Kris
Tech/Service
Wombat North is offline   Reply With Quote
Old 12-04-2002, 12:20 AM   #10
Wombat North
Member#: 21267
STI, EWG 8cm Green
BTW
I use the 4365 comp gauge and the 5249 Severe Duty Closed Tip Probe. 2 in fact, 1 in each manifold.
I'm happy with these
Old 12-04-2002, 03:49 AM   #11
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Hey guys!
I bought the sport-comp egt gauge. it came with a probe. the part number for the kit is 3344. is this probe okay to use? is it still fairly accurate? i was thinking of upgrading later on.
thanks
scubaracer is offline   Reply With Quote
Old 01-31-2004, 05:51 PM   #12
metoo
Member#: 4764
2004 STi sold :(
forizzle
Originally posted by scubaracer
Hey guys!
thanks
According to this thread, you have the 5249 probe
http://forums.nasioc.com/forums/show...highlight=3344
But everytime I'e seen the 3344 sold, the picture shows a clamp-on probe. Does yours clamp on or screw in?
metoo is offline   Reply With Quote
Old 01-31-2004, 06:45 PM   #13
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
I have the 3344 gauge...it comes without a probe as the probe kit is sold seperate to suite the needs of the customer.
I am using the 5249 probe with it and it is a screwed in type.
It is fast acting and has worked trouble free for ~10k miles so far.
Old 01-31-2004, 07:08 PM   #14
Aaron'sWRX
Member#: 34150
02 WRX
Post
http://www.westach.com/products.htm ... I went with a Autometer EGT gauge but didnt trust their probes. I bought a 1/8th NPT Type K probe from Westach. They are about $50 dollars. Westach has been around since the 1940's making products for aircraft, agricultural, and Auto. Check them out.
Aaron'sWRX is offline   Reply With Quote
Old 07-09-2004, 10:23 PM   #15
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I just bought a 3 gauge set from a guy here on the board.
My EGT gauge is the 3343 and here is a picture of the probe. The Autometer instructions mention a ceramic washer which I don't have. Where do I get one?
Anybody out there use a probe like this? Any leaks? I would rather weld in a bung myself and have it thread in but I think that would require buying another probe.
-Scott A.
cky211 is offline   Reply With Quote
Old 07-10-2004, 12:19 AM   #16
Uncle Scotty
OK buy Nates beans
-Scott A.
If it were me, I'd flush the clamp on probe that you have and buy the 5249 kit and use it.
The washer. most likely, is available from Autometer.
They DO have very good customer service, in my experience
What INCAR camera are you using and what mount Scooby South Motorsports 142 08-03-2009 10:38 AM
('93-'01) gc owners: what lowering springs are you using and how low, and how much did you pay? legacy2003 Impreza Forum 37 11-06-2004 05:57 AM
What door speakers are you using, installer says mine are to deep. Digital-RX Texas Impreza Club Forum -- TXIC 10 06-29-2002 02:32 PM
What is everyones fuel pressure at idle and what pump/FPR are you using? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-30-2002 03:32 AM
('93-'01) What engine oil are you using? srosqvist Impreza Forum 24 06-30-2001 06:11 PM
