Old 06-07-2001, 05:17 AM   #1
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post headers banging against skid plate all of a sudden?
Ok now (just started this week) I am getting vibration/noise from the headers (I'm guessing) vibrating against my primitive racing skid plate.
They never USED to do this except occasionally when the car went through hard shifts.
Could it just be the engine is running rough and causing more vibration to occur?
I am getting the car tuned up this morning, hopefully that will fix things but I'm just curious as to why this would start all of a sudden.
I'm also switching to Mobil 1 10W30 synthetic engine oil. Think I'll see any leaks? 30k miles on the ODO.
remarcable is offline   Reply With Quote
Old 06-07-2001, 08:41 AM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
on my skid plate, rumble soft, It was pretty close, so I added some washers to space it a bit. That may help if you can't get your engine to settle down, you may want to check your motor mounts, not that I've heard of them breaking, but...
m750 is offline   Reply With Quote
Old 06-07-2001, 03:44 PM   #3
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
Post
this happens after a while with most skid plates, they start to curve from the heat, just take it off and bend it back to shape, my buddy does this every now and agian and it keeps the rattle away. also you shouldnt see any leaks. i just switched at 56k and im not having any problems....yet
[ June 07, 2001: Message edited by: NateDogg ]
NateDogg is offline   Reply With Quote
Old 06-07-2001, 03:54 PM   #4
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
If you have properly maintained your engine, you will never see leaks from switching to synthetic.
You will sometimes see leaks in an older engine because existing leaks are filled with coke from the dino oil. The higher detergent properties of synth gets rid of the deposits and opens up the existing leak.
If you've properly maintained your engine, you don't have coke deposits.
gavin is offline   Reply With Quote
Old 06-07-2001, 09:59 PM   #5
tmaler13
Member#: 1992
Talking
Wierd..I have Coke Deposits around my cupholders. Will switching to Mt dew change this.
-Terry
tmaler13 is offline   Reply With Quote
Old 06-08-2001, 06:52 AM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
either bend the skid plate back a bit...
or add spacers...
on my GT i added spacers and the banging disappeared...
j. www.subiegal.com
Subie Gal is offline   Reply With Quote
Whine noise all of a sudden in WRX - all gears at certain times Civ2Sub311 General Community 38 06-14-2015 04:33 AM
Gruppe-S Headers And Primitive Skid Plate viaburn26 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-11-2008 06:57 PM
What's with all the dog killing all of a sudden? now with a sword mr_disco Off-Topic 10 09-02-2004 10:00 PM
Will Borla ss headers fit under skid plate. Rallyspec Normally Aspirated Powertrain 8 08-28-2002 12:07 PM
