Old 02-03-2003, 08:12 PM   #1
Smash!
Member#: 31124
2002 WRX Sedan
Unhappy Cigarette Lighter socket no longer works
....after I used a power converter to run some small appliance. Now it doesn't provide power to my cell phone charge( or whatever I put in). Can it be a blown fuse? If so, can somebody direct me to which one it is?
Smash! is offline   Reply With Quote
Old 02-03-2003, 08:14 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
It is probably a blown fuse. Look up in your owners manual or the back of the fuse box lid to see which fuse it is.
Eric
Eric SS is offline   Reply With Quote
Old 02-03-2003, 09:24 PM   #3
brunetmj
Member#: 8023
2004 2.5 RS
I read a thread were the person said that besides the fuse it also has a fusible link. In other words if the fuse is ok then the lighter has to be taken apart. I do not exactly know what a fusible link is. I assumed it to be a wire that acts as a fuse. I have the same problem but my fuse is fine. I just havenít had time yet to pull the lighter apart to look.
brunetmj is offline   Reply With Quote
Old 02-03-2003, 09:24 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
A fusible link is basically when there is a fuse along the wire.
Eric
Old 02-03-2003, 09:37 PM   #5
brunetmj
Member#: 8023
2004 2.5 RS
Thanks. When i take the lighter apart i will know what to look for. By the way, the person who posted the thread knew it wasnt the main fuse because he was powering something off those wires just before the lighter and whatever it was had no problems.
Old 02-03-2003, 09:42 PM   #6
brunetmj
Member#: 8023
2004 2.5 RS
Oh forgot to answer Smash!'s question. It is fuse 4 located behind the little compartment by the drivers left knee. Check that first and if it is good? Well then you will need to take the lighter apart.
Old 02-04-2003, 12:37 PM   #7
Smash!
Member#: 31124
2002 WRX Sedan
hehe.. Thanks for having me in mind! I'll look during lunch or something and then probably drop it off at the dealer if it's not the fuse. Too lazy to put the lighter out.
Old 02-04-2003, 04:04 PM   #8
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I had my lighter socket fusable link blow out on me before. I was using someone's portable air compressor at an autox and i think it shorted out and killed the link. I looked at the fuse, but it was fine so i assumed something was wrong with the socket. I removed the socket and found the length of wire attached to the rear of the socket that is the furable link. I tested it for continuity and it turned out the circuit was open. The dealer gave me a free one under warranty. Its kind of a pain to have lost the socket and not the regular fuse. i would have rather replaes a fuse since they are much easier then taking the hvac stuff out to ge tthe socket out. I dunno why this is like this.
Cosworth is offline   Reply With Quote
Old 02-05-2003, 10:21 AM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I had the exact same thing happen as Cosworth (aircompressor at an auto-x) but we didn't replace the link we just jumped it with a piece of wire. There is already a fuse, the link is more heat protection.
BOY is offline   Reply With Quote
Old 01-07-2005, 06:38 PM   #10
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
Mine just blew and the fuse by the steering column is fine. Does anyone have info on how to get to the cigarette lighter itself to look at the wires in the back? Thanks
SupaSizeFries is offline   Reply With Quote
Old 01-07-2005, 06:51 PM   #11
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
on my wrx pretty much all you do is remove all the center console trim, remove the cd player , the a/c controls(just puseh these over a they are difficult to disconnect, then inder the a/c controls you will see one weierd shaped plug that goes to the lighter
DJ_STI is offline   Reply With Quote
Old 09-14-2005, 09:20 AM   #12
sinwagon
Member#: 60970
02 WRX wagon
white
That's all you have to do! Damn, I had the same thing happen. I was powering a compressor and it went down. Now I can't power my SIRIUS radio.
I took the console apart and found the plug behind, but can't get the lighter out. Is it more likely the lighter or the wire and fuse connected to the plug behind it. As before my main fuse is fine.
sinwagon is offline   Reply With Quote
Old 11-02-2005, 04:15 PM   #13
Chicote
Member#: 86411
okay, same happened here.. compressor at auto-x!! damn things!
Chicote is offline   Reply With Quote
Old 11-03-2005, 05:11 PM   #14
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Same thing happened to me using a compressor at an auto-x... fried the lighter element. For whatever reason- they don't like "heavy" assesories being run on them.
MK19_ is offline   Reply With Quote
Old 05-15-2014, 11:44 AM   #15
Huamaru
Member#: 184460
2005 STi
Crystal Grey/Silver
Default Fusable Link?
So where do I get this fusable link that you guys speak of? Mine just went out or at least Im suspecting it. And yes I was using a Slime Air Compressor.
Huamaru is offline   Reply With Quote
Old 05-15-2014, 01:19 PM   #16
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Holy bump.
You don't replace the link, you replace the socket.
Old 05-16-2014, 12:25 AM   #17
Huamaru
Member#: 184460
2005 STi
Crystal Grey/Silver
Again, where do I find this said socket?
Is this what I need?:
http://www.autopartswarehouse.com/details/QQSubaruQQImprezaQQReplacementQQCigarette_LighterQ Q19932012QQREPU506801.html
I don't wanna buy something I don't need...
Old 05-16-2014, 06:02 AM   #18
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That is a universal replacement. Go to a local or online dealer and buy the OEM part.
Old 05-17-2014, 11:17 AM   #19
sabe
Member#: 391067
2007 WRX 2.5
You don't need the lighter do you? Buy only the socket.
sabe is offline   Reply With Quote
Old 08-13-2014, 08:37 AM   #20
02hybridwrx
Member#: 397139
Same problem with mine haha. I'm not finding the "plug" that releases the socket to be removed though...
Sent from my SM-G900V using NASIOC mobile app
02hybridwrx is offline   Reply With Quote
Old 03-13-2015, 05:25 PM   #21
jogfrogjog
Member#: 43421
2004 STi Wagon
I was having a hard time figuring out how to actually remove the socket until I stuck my phone in as a camera and saw that it's a big nut holding it on the inside, I thought it was a plastic housing. I was able to get it loose with my hand.
jogfrogjog is offline   Reply With Quote
Old 05-12-2015, 01:05 PM   #22
Shimrra
Member#: 412441
So I'm in the same boat as others, I've removed the center bezel in my 02' impreza, and tested the power going to the outlet and it works, so I'm assuming that the fusible link is blown out (bought the car this way) but I'm stumped as to how to remove it without taking the whole center out of the dashboard... It wiggles, but I can't for the life of me see any way of removing it! Does anyone have a walk through?
Shimrra is offline   Reply With Quote
Old 02-17-2016, 08:27 PM   #23
Mike Wondo
Member#: 332416
2002 WRX Wagon
how do you remove the socket? does it push out towards the cab..or does it twist and pop off back in side?
Mike Wondo is offline   Reply With Quote
Old 02-17-2016, 10:28 PM   #24
jogfrogjog
Member#: 43421
2004 STi Wagon
There's a long nut on the back side of the socket made out of stamped sheet metal. You have to loosen that on the inside of the console and then it should come out. It's been a while since I took it out, just be careful to see if there are any wires you need to disconnect.
Fried fuses or somethign else? Stupid cigarette lighter socket. piglet Electrical & Lighting 11 03-16-2013 09:14 PM
tapping a wire into cigarette lighter socket? bnr34rb26dett Electrical & Lighting 4 09-04-2009 10:00 AM
Trying to run a new 12v cigarette lighter socket into my armrest... Thadddeus General Community 7 07-11-2005 04:21 PM
cigarette lighter socket p90tr Private 'Wanted' Classifieds 5 10-23-2004 08:29 PM
Need more cigarette lighter sockets msm98lw Electrical & Lighting 6 08-03-2004 12:20 AM
