Old 02-15-2003, 02:50 AM   #1
AKWRX
Member#: 23485
2002 WRX sedan
Default Modified Autometer A/F Gauge
The Autometer A/F gauge as modified by www.gadgetseller.com sold as "Full Throttle" Air/Fuel gauge is a cost effective upgrade. Tested both the standard Autometer 3375 Sport-Comp and the modified version. They use a 0-1V oxygen sensor available from Autometer, or as tested, using a generic Bosch OS100 two wire (unheated) sensor costing about $28 from any auto parts store. The standard gauge uses the 20 LED indicator to display the full 0 to 1V sensor output. The modified version uses the 20 LEDs to display only from .77V through .97V, which gives much better resolution of A/F ratio in the critical area near WOT. While it is no substitute for a spendy, professional quality, wide band A/F gauge for tuning, it does provide much more useful data than the normal narrow band A/F gauge. Plus, if you already have any of the various versions of the Autometer A/F gauge, it can be modified for $25 plus USPS mail shipping. The one day turnaround service time is very prompt. This is a recommended option for a higher quality, low cost narrow band A/F data gauge.
AKWRX is offline   Reply With Quote
Old 02-20-2003, 01:30 AM   #2
alltractionWRX
Member#: 14819
WR Blue
MachV also sells this modified autometer A/F gauge but how do you like it so far I am considering buying one.
alltractionWRX is offline   Reply With Quote
Old 02-24-2003, 11:25 PM   #3
M3GTR
Member#: 21965
V-mounted 40R...what
I've got the autometer gauge but got a new o2 sensor, heated 0-5 volts, works really well, very accurate and responsive
M3GTR is offline   Reply With Quote
FS: autometer gauge pod, autometer oil pressure gauge, maddad EGT gauge schiarelli Interior/Dressup/Audio & Security 2 10-29-2009 11:26 AM
Modify Autometer Cluster Bezel Gauge Pod to fit 60mm gauge? roninsoldier83 Interior & Exterior Modification 2 05-29-2009 07:53 PM
02-03 Autometer Instrument Dual Gauge bezel w/ Autometer EGT & Boost, everything PhastEddie Interior/Dressup/Audio & Security 5 05-23-2008 08:00 PM
FSNY Autometer Cluster Bezel $45 , Autometer A/F gauge pro comp ultra lite(Brand new) turbotoyzz Interior/Dressup/Audio & Security 3 12-29-2006 05:57 PM
FSNY Autometer Cluster Bezel $45 , Autometer A/F gauge pro comp ultra lite(Brand new) turbotoyzz Tri-State Area Private Classifieds 3 12-29-2006 05:53 PM
