Old 03-19-2003, 08:16 PM   #1
Imprezd
Member#: 3357
Default HELP!! Head Bolts & Cams Bolts Torque Specs
Help me please, I am in the process of putting my motor back together I need the the Headbolt Torque and sequence specs and the same info for the cams bolts.
Thanks in advance..
P.S. I am willing to guess Jon in Ct will be the first to respond if any does answer Thanks as well..
Imprezd~
Imprezd is offline   Reply With Quote
Old 03-19-2003, 10:33 PM   #2
morphgabbin
Member#: 15466
2002 wrx
Here's the head gasket:
B: INSTALLATION
1) Install the cylinder head and gaskets on cylinder
block.
CAUTION:
Use new cylinder head gaskets.
Be careful not to scratch the mating surface
of cylinder head and cylinder block.
2) Tighten the cylinder head bolts.
(1) Apply a coat of engine oil to washers and
bolt threads.
(2) Tighten all bolts to 29 N.m (3.0 kgf-m, 22 ft-
Ib) in alphabetical sequence.
Then tighten all bolts to 69 N-m (7.0 kgf-m, 51 ft-
(3) Back off all bolts by 180" first; back them off
by 180" again.
(4) Tighten the bolts (A) and (B) to 34 N-m (3.5
kgf-m, 25 ft-lb).
(5) Tighten the bolts (C), (D), (E) and (F) to 15
N-m (1.5 kgf-m, 11 ft-lb).
n n
(6) Tighten all bolts by 80 to 90" in alphabetical
sequence.
CAUTION:
Do not tighten the bolts more than 90".
(7) Further tighten all bolts by 80 to 90" in al-
CAUTION:
Ensure the total "re-tightening angle" [in the
two previous steps] do not exceed 180".
The lettering for the bolts goes like this in correspondence to your head.
C A F
E B D
morphgabbin is offline   Reply With Quote
Old 03-19-2003, 10:40 PM   #3
morphgabbin
Member#: 15466
2002 wrx
for the camshaft:
tighten to 16ft.lbs. in alphabetical sequence. Oh and start with the intake cam. I don't know why, that's just what it says.
A E C
B F D
and remember to tighen them slightly before torquing them down.
Sorry for the crued figures, but the manual wouldn't let me copy the pictures for some reason.
You should be able to figure out which bold is labeled what pretty easily though.
Old 03-20-2003, 07:30 AM   #4
Imprezd
Member#: 3357
Thanks,
I can get my heads on the motor now...
Imprezd~
help!need torque specs for manifold to head bolts twinz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-01-2010 04:55 PM
Torque spec for cam cap bolts? rogue Service & Maintenance 9 08-28-2007 06:51 PM
Official Head Bolt/Stud Torque Specs for Various Motors White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-17-2006 06:42 PM
Vishnu main power & alternator pulley torque specs FreeBSD_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-19-2003 05:57 PM
Warning-Torque Spec Error in Shop Manual for Cam Shaft Cap Bolts GarySheehan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-02-2001 04:37 PM
