Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 04-07-2003, 06:32 PM   #1
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
Default Gas Guage
my gas guage reads half tank ..but i ran out of gas ...HELP
pistoffjstr is offline   Reply With Quote
Old 04-07-2003, 07:46 PM   #2
stitches
Member#: 24293
2000 2.5RS
Default Shell gas
Did you fill up with shell gas. They have been having problems with there gas wrecking gas guages.
stitches is offline   Reply With Quote
Old 04-07-2003, 09:58 PM   #3
pistoffjstr
Member#: 29283
Red
Nope i only use mobil
Old 04-08-2003, 02:06 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Gonna have to tow it in to somewhere and have them find out the problem... Could be any number of things. Needle, gas tank guage, etc.
Old 04-08-2003, 03:26 AM   #5
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Default Re: Shell gas
huh??? hows that?
moogoob is offline   Reply With Quote
Old 04-08-2003, 09:49 AM   #6
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
Cabal is offline   Reply With Quote
Old 04-08-2003, 11:33 AM   #7
pistoffjstr
Member#: 29283
Red
naaa there was a gas station right down the road from were she went dry 2 gal. of gas in a gas can and drove it to the station and filled up no towing nessisary
Old 04-08-2003, 03:26 PM   #8
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Default Re: Re: Shell gas
Originally posted by moogoob
huh??? hows that?
Ref here
Looks like it only affects some parts of Canada.
BlueTDimly is offline   Reply With Quote
Old 04-08-2003, 07:45 PM   #9
matt8416
Member#: 34929
2004 sti
07 Lexus Breakwater Blue
Default fuel gauge
due to saddle type tank you have two sending units in series this could effect reading.get a copy of wiring diag by grounding connector the gauge will read empty.
with tank below half tank remove back seat and carpet in cargo area 2 access covers can be seen / remove - top of fuel pump units can be seen dis connect elect & fuel lines,remove nuts from the stud that hold units in place on tank. remove both fuel pumps with a ohm meter on leads to senders you can check for opens as you move float up and down
be VERY CAREFUL when reinstalling pumps DO NOT - DO NOT over torque the nuts and make sure the gasket is set correctly or you will get a e-light for evap
matt8416 is offline   Reply With Quote
Old 04-08-2003, 08:34 PM   #10
Skylab
Member#: 4263
Arrow
I had a similar problem with mine. It was reading empty and still had 1/4 tank. Dealer replaced it under warranty. This is a semi-common problem with Subaru. They replace the fuel pump/sending unit. The fuel level reader and fuel pump are one unit...so you get them both replaced.
There is a thread in this FORUM about the problem I had. But the paragraph above sums up the whole thread.
Good luck.
Skylab is offline   Reply With Quote
Old 04-09-2003, 12:29 AM   #11
pistoffjstr
Member#: 29283
Red
cool when it gets warm again ill try that thanks
D@#N COLD WEATHER a week ago it was 60-70 degrese
Old 04-09-2003, 04:50 PM   #12
Blindeye_03
Member#: 4418
2014 Golf GTI
Good luck.
My gauge is starting to do it really bad too...It shows the empty light after about 240 miles, so I will drive to a gas station (if im on a hill it does the same thing, but goes away after i start driving).
I fill up with a full tank of gas and only pump like 10 gallons (says its full too)... how long (mileage) is the warranty good for on that part???
I pump 93 octane btw (for my proecm chip).
-justin
(sorry if its hard to follow what im saying, the computer here is slow as poo and im tired :-p ).
Blindeye_03 is offline   Reply With Quote
Old 04-09-2003, 11:39 PM   #13
matt8416
Member#: 34929
2004 sti
Default gauge
per SOA tech bulletin subaru would rather you fill your tank more-often and have more fuel in reserve than have one customer run out of fuel.
Old 04-09-2003, 11:51 PM   #14
Blindeye_03
Member#: 4418
2014 Golf GTI
SOA is REALLY starting to disappoint me...
If a piece of your car is not working properly (ie: gas gauge showing low when infact you arent)...something is wrong and that needs to be fixed. If your car is underwarranty you should DEMAND it be fixed (sometimes its the only way to get things done).
Now I doubt my car would fall in the warranty since I am at 52kmiles.
-justin
Is the Low-gas warning light wired with gas gauge? Hazdaz Electrical & Lighting 5 06-17-2003 10:28 PM
Problem gas gauge or not to worry? moogooob Normally Aspirated Powertrain 1 03-27-2002 06:12 PM
gas gauge misreading alphabenson Service & Maintenance 1 01-28-2002 08:19 PM
My gas gauge reads 50% off. anyone else? Eric SS General Community 15 12-20-2001 08:42 AM
('93-'01) gas gauge malfunctions? wop Impreza Forum 4 08-30-2001 09:35 AM
