Old 05-26-2003, 06:13 PM   #1
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Default my swap progress
before
pictures from its ebay auction
durring
mostly-done
and yes a gda exaust will fit a gc2/6/8.. old 1.8 inthe back ground
Old 05-27-2003, 02:23 AM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
what year or verison ej20 is that ? how much did you pay for it and how was the wiring. is your impreza AWD. because its an older motor was wiring easier? is it drivable yet I got so many questions cuz your doing what I wanna do more or less little 4 door lower end impreza to ej20
scobaru is offline   Reply With Quote
Old 05-27-2003, 03:29 PM   #3
HubbieScooby
Member#: 7088
Super Slow
is that an aftermarket engine management i see there?? looks like a Tec2...
HubbieScooby is offline   Reply With Quote
Old 05-27-2003, 04:32 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
jeeze
what year or verison ej20 is that ? EJ20G
how much did you pay for it 650
how was the wiring. not too bad yes that is a tec2 i used part of the 1.8 engine harness
is your impreza AWD. yes
because its an older motor was wiring easier? um dunno
is it drivable no the tec pickup is bad
I wanna do more or less little 4 door lower end impreza to ej20 my goal was a $5000 car ..it is now close to $12500
Old 05-27-2003, 05:06 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What were your goals with this? I know you've been working on it for ever, but I am kind of surprised to see the stock A/W IC and the stock WRX turboback exhaust.
Which radiator did you use?
-Jon
stimpy is offline   Reply With Quote
Old 05-27-2003, 05:34 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
how much HP is that motor?
Old 05-27-2003, 11:01 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
$$$ my friend $$$
finding an early air to air intercooler has proved ot be very difficult for a reasonable price if any one knows of one or has one let me know the usdm WRX intercooler just wont fit
as for the exaust .. at some point i will take the exaust off mY GDA and put it on.. but getting hte project moving was more important
this motor is 200-220 stock .. there are a few versions so i am not 100% sure how ever it has the same injectors and internals as the 260 version .. just a smaller turbo .. any one have a good source for an ihi flanged TD05?
Old 05-28-2003, 02:32 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Now if you want very difficult for a reasonable price, try finding that TD05... You may have to source a WRX intercooler and do some TB modifications to get it to fit. I had a MY94 IC about a year ago and it cost me $50 plus another $80 or so just to ship. They were hard to come by back then.
So how about my question on that radiator?
-Jon
Old 05-28-2003, 03:10 PM   #9
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
130 ... wow thats cheep i have been looking at 300+
there is no way that the GDA intercooler will fit ... i am using the 1.8 throttle body .. it is already a full inch longer than the standard EJ20G
yeah i would like a td05 too
stock 1.8 radiator
Old 05-28-2003, 03:19 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
It is already tapped for the remote radiator cap? I thought an extra fitting was needed to use that remove reservoir.
-Jon
Old 05-28-2003, 06:20 PM   #11
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
nope ..
taken from the guys at i-speed
i removed (hacksaw) the spring from the lower radiator cap so that it is always open then routed the hose from the surge tank to the overflow
like so (from a converted RS at rim)
fwiw i found an air to air intercooler today for 240 shipped
Old 05-28-2003, 06:36 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Oh ok. So the stock radiator overflow line goes up to the surgetank and the surgetank returns to the stock overflow? Sounds simple enough.
Now you need to find the hood to go with that topmount IC
-Jon
Old 05-28-2003, 08:59 PM   #13
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
do you have all the parts needed for the air-water intercooler(pump, front cooler)? Removing that inline air silencer is worth a couple free HP
Scoobie Steve is offline   Reply With Quote
Old 05-28-2003, 09:18 PM   #14
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
nope and it is officaly for sale
actaully he entire silencer is in place encluding the part in the fender
run 1st tune 2nd
actually i have a period SOJ genuine hood scoop .. so i am going to cut and bolt that on .. old scoops are bolt on top vs recessed
jon you shodul change your profiel to
"MY96 Project GFA" you are going to use a usdm motor right?
Old 05-28-2003, 09:38 PM   #15
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Hehe. Hardly anybody knows what a GF8 means, let alone a GFA. Although, technically, you do have a point. Mebbe I'll change it.
-Jon
Old 05-29-2003, 09:45 AM   #16
Puckaveli
Member#: 1518
00 2.5RS
I am upgrading my IC on my Ver2 so I have an extra A-A Ver2 IC. It is the slightly larger STi version also. Let me know if you want it.
Puckaveli is offline   Reply With Quote
Old 05-29-2003, 11:30 AM   #17
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
aggggg! bad timing..
already bought one, thanks tho puck
oh and a tip ... if you plan to use the power steering pump from your existing car you will need to move the bracket over from your old car as the jdm pump does not have a fluid level sensor ...AND the sensor on the usdm pump fowls on the bracket AND you will have to massage the hard lines right after the pump and switch over the brackets on the hard line too.
Old 05-31-2003, 01:04 PM   #18
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
new intercooler
she is running .. be it wildly out of tune and leaking coolant on the headder
Old 05-31-2003, 01:40 PM   #19
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Ooooh! Tune it then!
Did you get a baseline map for your Tec-II?
-Jon
Old 06-01-2003, 07:22 PM   #20
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I dig the blingin' purple.
monovich is offline   Reply With Quote
Old 06-01-2003, 11:53 PM   #21
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah and it start and idles .
annnnd smokes ... alot ..
i have a coolant leak down near the oil cooler ... and white smoke in the exaust at least i think it is white
Old 06-01-2003, 11:55 PM   #22
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
smoking is bad for you Do u have any clue what any of this is from? is it just an old motor and it's showing its age?
Old 06-02-2003, 11:55 AM   #23
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
not sure.. i need to find the coolant leak .. hope fully they are not realated
yeah i bought an unknown used motor ... shrug ...
Old 06-02-2003, 02:32 PM   #24
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
White is a lot better than black, grey, and/or blue . Unless, of course, it's your headgasket leaking coolant into the combustion chamber...
-Jon
Old 06-02-2003, 03:46 PM   #25
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
well so far the oil looks ok no conteamination ..
yeah .. can a turbo leak coolant?
need to do a compression check
my swap progress EJ20G homemade Rocky Mountains Impreza Club Forum -- RMIC 63 06-01-2010 05:06 PM
My swapped flared wagon progress ProjectL Member's Car Gallery 204 03-10-2010 12:10 AM
RR's Swap Progress pt. 2 RR02wrx Subaru Conversions 87 05-03-2007 08:26 PM
my swap progress ImprezaRSfan! Subaru Conversions 23 05-31-2004 11:54 PM
Silvia swap progress Blugin Texas Impreza Club Forum -- TXIC 29 05-01-2003 11:10 PM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
