Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 08-10-2000, 10:02 AM   #1
Gary Thomas
Member#: 1832
Post O-ring replacement directions
If anyone is considering doing the power steering o-ring replacement, here are complete directions:
1. remove belt cover by using a 10mm socket on the 2 bolts - one on each end of the cover. Then slide the cover toward the front of the car off its bracket.
2. Remove power steering fluid reservoir's cap, screen, and fluid. Just reach a finger in the reservoir and pull the screen out. Then syphon out the 10 ounces of fluid or use a turkey baster.
3. Remove the 2 torx bolts on the reservoir with a T40 torx bit.
4. Remove the last remaining bolt on the back of the reservoir (driver's side of it) with a 12mm socket.
5. Lift up the reservoir and tilt it toward the passenger side to expose the o-ring so you can replace it.
Gary Thomas is offline
Old 08-10-2000, 11:25 AM   #2
richeich
Member#: 1353
2001 Impreza 2.5RS
Thumbs up
Thanks for posting it over here Gary, now it's in a searchable database.
Rich
richeich is offline
Old 08-11-2000, 12:00 AM   #3
nubbsjr
Member#: 174
Post
I just got my o-rings from the dealer today. Got two just in case of a problem.Gonna do it as soon as the engine cools of a bit.
nubbsjr is offline
Old 08-10-2000, 06:23 PM   #4
Gary Thomas
Member#: 1832
Post
I see aredubjay has just posted directions on other important operations. I think that is a great idea to post these procedures on this site. I have some very good directions from Phil North about the ECU noise suppressor crush mod that I will condense and post.
[This message has been edited by Gary Thomas (edited August 11, 2000).]
Old 08-10-2000, 07:59 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Talking
Stoppit Gary, you're freakin' me out!
richeich is offline
HTML code is On
Ring and Pinion swap directions. smileyou Transmission (AT/MT) & Driveline 8 11-17-2008 01:25 PM
A/C o-ring replacement jahl7787 Service & Maintenance 1 05-07-2008 12:08 AM
Spark plug o-ring replacement uturn Service & Maintenance 8 12-28-2006 04:32 PM
ABS light still on after ABS ring replacement six1five Brakes, Steering & Suspension 3 11-08-2005 09:29 AM
Replacement pistons (upgrades) that are direct replacements? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-01-2003 04:08 PM
