Old 07-01-2003, 11:52 PM   #1
my03nywrx
Member#: 37791
03 WRX sedan
Thumbs up Hotchkis F & R sway bars
Just installed my f & r sway bars. Front bar is 21mm & the rear is 3-way adjustable 20/22/24mm. I set mine at 22mm. I purchased the kit which came with everything(f & R end links,brackets,mounts,bushings & grease). The directions are great all step by step B & W pictures. Installation for the rear is simple(about an hour). The front is easy but time consuming(about 2 hours). Quality and workmanship is A1. The rear end links and bushings have grease fittings and are high polished aluminum. The bars are powder coated red. The front end links are adjustable in hight. Now I already had installed the Prodrive sport springs and STI replica strut bars. This was the perfect balance I needed to complete my suspension mods. I should of installed these sooner. There is a huge improvement in cornering. By the way I'm still running stock tires so those of you that already have improved in that area you will be even more amazed. I can't say enough about them. Except for my Prodrive stage 2 kit this is the most noticeable mod. The bars give you a VERY stable and predictable feeling coming in and out of a corner. Two thumbs up for Hotchkis and thanks to Mike @Subaruxtras.com for the recomendation.
my03nywrx is offline   Reply With Quote
Old 07-03-2003, 06:21 PM   #2
ride5000
Member Sales Rating: (4)
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default Re: Hotchkis F & R sway bars
Originally posted by my03nywrx
The rear end links and bushings have grease fittings...
now THAT'S a good idea!!
too bad i've got a cusco w/kartboys!
oh well.. we make do!
-ken
Old 07-03-2003, 11:57 PM   #3
neverendingmods
Member Sales Rating: (1)
Member#: 23796
2006 STi
white
They are "1 bars meaning 25mm(25.4mm to be exact). Rear is 23/25/27. I'm waiting on them to seperate the endlinks.
neverendingmods is offline   Reply With Quote
Old 07-17-2003, 03:01 AM   #4
w0rXer
Member#: 33222
2003 WRX
Midnight Black Pearl
It is a larger diameter bar but it is hollow. So they should be equivalent in stiffness to a solid bar of lesser diameter.
w0rXer is offline   Reply With Quote
Old 07-17-2003, 10:05 AM   #5
my03nywrx
Member#: 37791
03 WRX sedan
Arrow Hotchkis sway bars
The bars are hollow. As far as stiffness; handling is greatly improved.
Old 08-23-2003, 03:45 AM   #6
tdxflex
Member Sales Rating: (16)
Member#: 13634
Believe it or not, being hollow doesn't take away strength. Look at strut tower bars, lower arm bars, roll cages, bicycle frames, etc. However, increasing the diameter increases strength, these should be much stronger than most sway bars out there. Significantly bigger than my old cusco bars, about 2x bigger than stock. I did a short review on these also in this thread
tdxflex is offline   Reply With Quote
Old 08-27-2003, 11:01 PM   #7
KIMUTAKU
Member Sales Rating: (12)
Member#: 19776
2012 GVF SWP
Ninja Lime Green
sounds good..
any pics?
i like the cusco blue...but the hotchikis red seems to be pretty sweet too..
KIMUTAKU is offline   Reply With Quote
Old 08-31-2003, 01:22 AM   #8
neverendingmods
Member#: 23796
2006 STi
white
No powder coat peeling yet(18k mi.!) even after hard winters. If they would just seperate the endlinks! They are "stiff" or soft/normal. Great adjustibility/user preferences.
Old 10-28-2003, 07:37 PM   #9
Kartoffel
Member#: 12976
grocery getter
Default grease zerks
Great minds think alike! I got a set of Hotchkis bars when they first became available and they didn't come with grease zerks. AutoZone had Energy Suspension bushings with zerks built in.
So you're saying that the bushings for Hotchkis rear bars come with grease zerks now? That's good.
Kartoffel is offline   Reply With Quote
Old 11-02-2003, 01:22 AM   #10
neverendingmods
Member#: 23796
2006 STi
white
No , the endlinks themselves have an upper and lower grease fitting. Not the sway bar itself. I just got my Hotchkis endlinks. No I can ditch the modified MRT endlinks to ensure proper fitment.
Old 11-04-2003, 10:15 AM   #11
WRXtreme02
Member#: 12680
2010 GTi
I installed these bars and links as well, everything is very nice. Do you know how the car will react with the front end links adjusted in hight? I think I have mine out 6 threads but didnt mess with it.
Frank
WRXtreme02 is offline   Reply With Quote
Old 11-08-2003, 07:53 PM   #12
neverendingmods
Member#: 23796
2006 STi
white
Everyone w/ these bars and stock rear sway mounting brackets(not endlinks but the brackets) keep an eye on them. I went to change over to Hotchkis's rear endlinks and discovered I had broken a rear mount completely. These bars put a lot more load on the mounts. Meaning more aggressive driving is encountered. 04 mounts are beefier than 02/early03's. I ordered Hotchkis Tuning's mounts. I have no rear bar on right now.
Old 05-12-2004, 10:04 PM   #13
igalwrx
Member#: 13643
'02 WRX Sdn WRB
'05 Leg GT Ltd Wgn Black
The bars are great as long as they don't break. Ask me how I know! Front one broke...the bar not the mount.
igalwrx is offline   Reply With Quote
Old 05-25-2004, 10:10 PM   #14
wrxtrev
Member#: 26791
1990 JUSTY!!
white and black
ive broken two front bars so far... goin back to stock on front. more fun when it slides anyways...
wrxtrev is offline   Reply With Quote
Kartboy Endlinks & Cusco Sway Bar Combo|Tein & Cusco Coilovers|Cobb & Perrin Sways! Spun Autosports Suspension/Brakes/Handling 46 11-13-2007 01:34 PM
Rear Hotchkis (Adjustable) front stock Sway bars WRX UV BN RXD Suspension/Brakes/Handling 11 11-29-2006 09:46 AM
[FS] 2004+ Hotchkis STi F/R Sway Bars *Street Sway Set* (NEW) T1mmmy Private 'For Sale' Classifieds 4 07-10-2006 08:39 PM
FS: Hotchkis & Cusco sway bars, FT: TXS standard exhaust scoobie1 Private 'For Sale' Classifieds 7 08-11-2005 10:49 PM
Hotchkis front & rear sway bars with Whiteline endlinks willowracer Private 'For Sale' Classifieds 16 07-02-2005 07:38 PM
