Old 07-07-2003, 12:21 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default WRX headgasket an optiong?
I am going to put a new headgasket on my MY97 DOHC 2.5L engine and I am wondering if a WRX or STi 2.5 headgasket might be the better option over the new and improved DOHC 2.5 gasket? Anyone know if this would effect my compression to my advantage? A fellow member was saying that my timing will be thrown off by changing the headgasket size, any input on this? OH and ofcourse the heads are being o-ringed.
Joshua
yebokmj is offline   Reply With Quote
Old 07-07-2003, 03:19 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The WRX gasket is not an option as it's made for a 2.0L cylinder size, not a 2.5L size. The USDM STi, though, might be an option, but I'm unsure if there is any thickness changes between them.
8Complex is offline   Reply With Quote
Old 07-07-2003, 03:37 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
that or the gasket for a SOHC EJ25 would be the gasket to use IMHO
Jeremy
HndaTch627 is offline   Reply With Quote
Old 07-07-2003, 02:16 PM   #4
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Other than surely increasing your compression ratio, you need to check to see if the smaller bore of the WRX gasket will interfere with the valves, and if the WRX fire ring will even reach the 2.5L cylinder liner.
wac is offline   Reply With Quote
Old 07-07-2003, 08:30 PM   #5
Z1 Performance
Member#: 9327
The 99 gasket is frankly as good as anything aftermarket.....
Z1 Performance is offline   Reply With Quote
Old 07-08-2003, 03:53 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
who would use aftermarket head gaskets?
Old 07-08-2003, 08:11 AM   #7
Z1 Performance
Member#: 9327
Many would, and many have.....in terms of the aftermarket units, the Power Enterprise ones are among the best quality units out there......incredibly strong, and can be retorqued countless times if the need arises.
Old 07-08-2003, 01:41 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
if they are copper they are garbage, for race motors coppers fine, for daily driven cars it just doesn't work.
Old 07-08-2003, 05:18 PM   #9
Z1 Performance
Member#: 9327
They are not copper...I would positively NEVER use a copper gasket on anything.
Old 07-08-2003, 05:18 PM   #10
Z1 Performance
Member#: 9327
Old 07-08-2003, 09:13 PM   #11
markus
Member#: 438
2004 STi
White on Gold
Default Re: WRX headgasket an optiong?
I did a quicky calculation once and determined that the impact on timing is fairly negligible (~3deg on a 2mm thick gasket IIRC), but it will happen.
Should you be concerned about it?? Can't answer that for you, but I would imagine that +/- 3 deg is well within the realm of an engine/ECU's tolerances. **shrug**
markus is offline   Reply With Quote
Old 07-08-2003, 10:41 PM   #12
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Question
Um... aren't 99-03 head gaskets the same part #?
Wedge is offline   Reply With Quote
Old 07-09-2003, 12:39 AM   #13
smacksube
Member#: 4067
01 2.5 rs
why don't you just o-ring and get it over with?
smacksube is offline   Reply With Quote
Old 07-09-2003, 12:57 AM   #14
yebokmj
Member#: 2213
Brilliant Red
Default My gasket choice
I ended up going with just the new and improved stock DOHC headgasket for I deffinately didn't want to raise the compression for turbo use. I am O-ringing the heads before I install the new gasket. Everything goes together friday.
Joshua
Old 07-09-2003, 03:15 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
adam- do you have any info on the PE gaskets?? i am curious because i will be using and EJ207 bottom end.
jeremy
Dealer Screw Up: WRX Headgasket on an STi williaty Service & Maintenance 4 11-28-2009 12:41 AM
FS: WRX headgaskets turboL Engine/Power/Exhaust 0 03-26-2007 11:54 AM
Note: Use WRX headgaskets turboL Normally Aspirated with bolt-on Forced Induction Powertrain 10 12-13-2006 02:02 AM
FS: WRX shortblock, WRX headgaskets, 3" DP flon3y Engine/Power/Exhaust 12 10-04-2006 02:51 AM
I Need Wrx Headgaskets Now! 96Imprezadent Tri-State Area Private Classifieds 2 08-06-2006 04:41 AM
