Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 07-19-2003, 02:38 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default What Cars Came With A Rear LSD?
Since the FAQ was getting huge with my single question posts, I figured I would do a different format and create a new thread. I'm poking around in the FSM's, and while they give a LOT of information, there are a few holes as to which models actually had the LSD. Please feel free to correct me if I have made an error.
Unless specified, the LSD uses male axles and is a viscous coupling unit.
Impreza:
2000-2001 2.5RS 5MT, 4.111
2000-2001 2.5RS 4EAT, 4.444
2002+ WRX 5MT, 3.545,
2002+ WRX 4EAT, 4.111
2004 WRX STi 6MT, 3.900, mechanical
SVX:
1992-1997 AWD 4EAT, 3.545 final drive, has axle stubs
Legacy:
1991-1992 Turbo 5MT (Sedan only?), 3.900 final drive, has axle stubs
2000 GT, GT-LTD, Outback-CW, Outback-LTD, Outback-SDN (excluding Outback, Brighton, and L)
2001+ 2.5L (Excluding Brighton and L) 5MT, 4.111
2001+ 2.5L (Excluding Brighton and L) 4EAT, 4.444
2002+ 3.0L (H6) Outback and Outback-SDN 5MT, 4.111
2003+ Baja, see Legacy specifications
Forester
2000-2002 Forester S 5MT, 4.111
2000-2002 Forester S 4EAT, 4.444
2003+ with Disc Brakes 5MT, 4.111
2003+ with Disc Brakes 4EAT, 4.444
2004 XT Turbo 5MT and 4EAT, 4.444
-Jon
stimpy is offline   Reply With Quote
Old 06-03-2004, 11:05 PM   #2
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
My '91 Legacy Turbo 4EAT has a 3.900 LSD.
I don't believe it was just 5MTs that had 'em.
IronMonkeyL255 is offline   Reply With Quote
Old 06-03-2004, 11:38 PM   #3
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
That is correct, the 4EAT 91 Leg T's came with the rear LSD as well.
Wedge is offline   Reply With Quote
Old 06-04-2004, 08:44 AM   #4
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Exclamation Modification required.
No stubs on the SVX rear VLSD diffs.
Todd
wawazat is offline   Reply With Quote
Old 06-04-2004, 12:10 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the svx and STI rear diffs are r180s
USDM models only the canadian models from those years are open
the xt6 also used a r160 with a 3.70 ratio
Old 06-05-2004, 10:10 PM   #6
sick1.8t
Member#: 22345
2003 RSX
black
will the r180 from the svx/STI bolt into the gc8? (disregarding the gear ratios)
sick1.8t is offline   Reply With Quote
Old 06-05-2004, 11:18 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i dunno
diffs don't bolt directly to the sub frame so if you had the right bracketry ... yeah i guess?
Old 06-06-2004, 12:11 PM   #8
Structure828
Member#: 50488
1999 GC8 ej20g!
91' Legacy RS used 4.111 rear LSD (Jap Spec)
Structure828 is offline   Reply With Quote
Old 06-06-2004, 12:12 PM   #9
Structure828
Member#: 50488
1999 GC8 ej20g!
And you can also add 92-94 Liberty/Legacy RS and RS-RA to the list
Also...didnt the 1999 Impreza have rear LSD as well? I thought it was the first year, because my car certainly does, and I never switched out the rear end. Unless the owner before me did.
Old 06-06-2004, 02:11 PM   #10
Schlogen
Member#: 59118
2016 WRX
Pure Red
02 RS 2.5 have it?
Schlogen is offline   Reply With Quote
Old 06-06-2004, 03:48 PM   #11
Charge
Member#: 3313
Originally posted by Schlogen
02 RS 2.5 have it?
Nope, it doesn't.
The 99 Impreza 2.5RS's had it, I thought. I was pretty sure just the 98's didn't, for that body style.
Neil
Charge is offline   Reply With Quote
Old 06-06-2004, 07:12 PM   #12
sick1.8t
Member#: 22345
2003 RSX
black
whats the deal with the stub axels/no stub axels thing? are they not compatable?
Old 06-07-2004, 12:51 AM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
It was an option for '99RS. It was standard in '00 and '01.
rob is offline   Reply With Quote
Old 06-07-2004, 03:34 PM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Lemme see if I remember.
Many of the late model axles have a male end that inserts into the rear differential. Some of the older models required axle stubs because the axles themselves did not have a male end. The axles were a flange type kind of similar to the front axles (but not really). For this to work, the rear differential requires a 3-4" long axle stub to which the axle will mount to.
-Jon
Old 06-08-2004, 02:28 AM   #15
sick1.8t
Member#: 22345
2003 RSX
black
anyone know if the wrx lsd is compatible with the older impreza L rear ends (as far as mounting goes, not the actual gear ratios)
Old 06-08-2004, 09:06 AM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
See the above post.
You'll have to either source newer axles or take the stubs from your current diff and insert them into the LSD first. Also, you'll have to do some minor clearance grinding inside the older housing to fit the (slightly larger) LSD in place. There is some good info in the drivetrain forum by Joel Gat regarding the swappage and fitment issues of LSD's, both OEM and aftermarket.
It's my understanding that with the older diffs, you can remove the stubs and then use newer type axles.
(without taking the ring gear into consideration)
Jay Storm
Old 06-08-2004, 10:51 PM   #17
sick1.8t
Member#: 22345
2003 RSX
black
so i can source a wrx lsd rear end (complete), then i can make it work with that and just inserting my old impreza L stub axels into it, then using my existing axels.
i'd like to keep my existing axels if possible.
thanks for the info
Old 06-09-2004, 03:18 AM   #18
shinjyo
Member#: 25808
2003 Impreza RS
STI---->Prodrive
So what is it on my 2003 Impreza 2.5 Sedan?
Is it just an AWD or something like central differential XXX
Do it function totally different with the LSD??
WOud u mind explaining it to me??
Thanks!
shinjyo is offline   Reply With Quote
Old 06-09-2004, 10:53 AM   #19
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
2001 was the last model the RS (2.5) came with a rear LSD. It's open, in other words, it doesn't compensate for power differences between the rear wheels, same goes for the front one.
Old 06-10-2004, 12:12 AM   #20
uberbrighton
Member#: 56676
1996 Impreza
"Brighton" Hunter Green
How can you tell if you have an LSD differential with out opening it up? I have one that is supposed to be from an 02 WRX. I'd like to know that I didn't get cheated.
uberbrighton is offline   Reply With Quote
Old 06-12-2004, 01:44 AM   #21
sick1.8t
Member#: 22345
2003 RSX
black
something i ran upon:
http://kmhafer.datsun510.com/Subaru.htm
Clutch-Pack LSD:
1985-1986 (production up to 3/86) XT 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11000).
1986-1987 (production from 4/86-10/86) GL 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11001).
1986-1991+ (production from 11/86) Loyale/GL 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11002).
1988-1991 GL and XT-6 4WDs with single range transmissions are listed with a 3.90 LSD option (Subaru part # 22011 GA022).
Old 06-12-2004, 01:45 AM   #22
sick1.8t
Member#: 22345
2003 RSX
black
turn one of the half shafts (axel connections) and the other side should turn the same direction, if it turns the opposite direction, its a non-lsd.
Old 05-21-2005, 07:04 AM   #23
Sic 2.5rs
Member#: 86715
2001 GM6 RS
Silverthorn
this only works if you can get enough torque on the lsd to make it "lock up" so you would have to have some kind of load on the tyres. I checked this last week when I had my car on a lift.
Sic 2.5rs is offline   Reply With Quote
Old 06-12-2004, 01:58 AM   #24
Rebellion
Member#: 8069
2002 Impreza WRX
Sedona Red + Mud!
yep.. agree w/ sick1.8t... the 86 GL10 Turbo my friend has the the above mentioned LSD (almost positive it was standard on the GL10T).
Rebellion is offline   Reply With Quote
Old 07-04-2004, 03:43 AM   #25
sick1.8t
Member#: 22345
2003 RSX
black
a sube tech at a dealership said that the svx rear end wont directly bolt into the rear of an impreza. i'm not sure if he also ment the axels are the wrong length or if its just the housing wont fit into the existing bracketry. anyone have any info on this? i was under the impression that all newer rear ends would bolt into the impreza, set aside the whole stub axle thing.
and is the svx rear really a R180?
'02 WRX 6 spd STI Conversion with r180 rear LSD & DSS (Drive Shaft Shop) Rear CVs nissaneng Transmission (AT/MT) & Driveline 16 03-17-2010 02:39 AM
Car came with intake, what AP options do I have? ST3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-02-2006 01:25 AM
4.11 Tranny with Matching Rear LSD Diff JoeT Private 'For Sale' Classifieds 17 02-10-2005 05:31 PM
Are the painted side skirts the same size as the plastic ones that my car came with? RyanRock Interior & Exterior Modification 5 05-13-2004 07:33 PM
I wish my car came with a hand gun accessory Stroke Off-Topic 9 09-05-2003 01:55 PM
