Old 07-30-2003, 05:33 AM   #1
exhondaguy
Member#: 13608
02 impreza
Default how to remove rear differential protector?
help? on 02 wrx. do i need something to support the differential when i remove the protector? thanks
exhondaguy is offline   Reply With Quote
Old 07-30-2003, 11:37 AM   #2
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
are talking about the steel, or aluminum plate? found :Here
if that's what you're talking about, then no, you don't, it's four bolts- 2 on each side of the diff and you'll probably have to loosen the two bolts in the rear to slide it out
speed safely
Brian
Slvrblt is offline   Reply With Quote
How to remove rear differential sensor? ASAP DJS1 Transmission (AT/MT) & Driveline 1 05-01-2010 05:31 PM
How to remove center differential assembly/transfer case?? WRXINTX Transmission (AT/MT) & Driveline 8 03-08-2006 11:46 AM
How to confirm rear differential and ratio? ryceracerx Transmission (AT/MT) & Driveline 2 10-22-2004 03:48 PM
Need to remove rear diff. protector? logikbomb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-02-2004 03:54 PM
