Old 08-10-2003, 01:30 PM   #1
garretwp
Member#: 22054
2000 Impreza RS 2.5
Default rain and idle problems!!!!
Ok, Here are the specs of my car. I have a 2000 impreza rs 2.5, it has headers, which was just installed, cat back exhaust, gravel sports intake, and torque chip 2 piggy back. Here is my problem. For some reason when it rains out some what hard, the car idles ruff. The top mount cold air intake has the scoop plate cut to a certian level to allow air to flow through but keep the water out. that is only installed when it rains out. Say the car is sitting running and its raining hard out, the car will run fine and than start to idle ruff, i pulled the car into the garage and opened the hood, and the intake does not seem to have any water on the filter. but if i look at the front of the engine bay, at the passenger head light area, there is water laying in the bay. has anyone had idle problems with there car when it rains? can someone give me some pointers to look for and maybe check? thanks
Garrett
garretwp is offline   Reply With Quote
Old 08-10-2003, 02:40 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Sounds very symptomatic of bad spark plug wires.
Wich subarus are known for. What happens is when they get wet or there is alot of moisture in the air the wires start arcing to each other or to a ground via tiny cracks in the wires insulation.
Jay
munkis is offline   Reply With Quote
Old 08-10-2003, 02:54 PM   #3
garretwp
Member#: 22054
2000 Impreza RS 2.5
so it could be bad wires? should i change the wires? the wires have 35000 miles on them? i was planing on getting new wires anyway.
Garrett
Old 08-10-2003, 03:07 PM   #4
garretwp
Member#: 22054
2000 Impreza RS 2.5
I also forgot to mention i have the bosch plat. 2 in the car as well.
Garrett
Old 08-10-2003, 05:58 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
wires would be a good place to start in my opinion.
Also, in my experience even just taking them off to change plugs, as you have done, will cause them to fail prematurally, in theory they should last about 60k.
I havent seen many subaru wires last that long though.
Jay
Old 08-10-2003, 06:36 PM   #6
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Sounds like the same way my 99 RS ran when the wires were shot. It shuddered like crazy when it was raining or really damp out. Wires fixed the problem for me. OEM wires aren't all that expensive so I'd give replacing the wires a shot. Worst case is you won't need to do them for a bit longer down the road.
Keith99RS is offline   Reply With Quote
Old 08-11-2003, 04:08 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
start with wires, i would suggest replacing the plugs as well
Packard Electronics=Owned by GM=Junk arse wires!
HndaTch627 is offline   Reply With Quote
Old 08-11-2003, 11:34 AM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
A-FREAKIN-MEN
However, the ignition system is designed around those wires and the ridiulous amount of resistence in them.
BOY is offline   Reply With Quote
Old 08-11-2003, 10:26 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
hehehe, well I was trying to say in a nice way....LOL
good job jeremy
Jay
Old 08-12-2003, 03:37 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
good job jeremy
Jay
*bows*
thank you thank you, i'm here all wek
rain causing cel and maf problem djc1827 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-04-2010 10:56 AM
Rough cold starts and idle problems WorldRallyRedneck Service & Maintenance 6 03-25-2008 05:55 AM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
help 91' justy 5sp starting and idling problems silv3l2 'Old School' Subaru Forum 0 02-10-2004 09:17 PM
Idle and overheating problems 4 days after installing injectors/fuel pump(long) WRX-Hellfire Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-08-2002 07:02 PM
