Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-18-2003, 12:24 PM   #1
SportyBry
Visiting NASIOC Timeout
Member#: 40648
2004 STi
Blue, of course
Default STi BOV sound clips anyone ? plus de-snorkelfying q's...
Hi guys,
I for one like BOV sounds and it's a personal thing, so please
don't go posting flames here.
I am looking for some BOV sound clips on a few options for my
STi. I was thinking about the WorxTuning BOV or TurboXS -rfl.
Can anyone post some interior (and maybe exterior) sound clips
of these in operation? I tried the dl at the turboxs WEBsite and
my machine cannot play it for some reason. I like the WORX unit's
OEM color match and drop-in-bolt-up appeal so I am most
interested in getting a sound clip of that one. I e-mailed them for
one but they never sent anything
I was also thinking about de-snorkelfying my car and going with
the 7"->3" velocity stack inlet that someone wrote about earlier.
Anyone have a sound clip of how the stock BOV sounds using this
kind of conversion? (de-snorkelfied) I have seen people write
that you can hear the BOV much clearer with this done....
Lastly, when de-snorkelfying has anyone gone with an upgraded
flat-panel filter in the box? Make and model? Results? With
changing the filter I am also a bit concerned about filtering
performance. My past experneice is that the HKS Mega flow units
do very little filtration- has anyone seen any test results on this
kind of thing? It would be great to know what filters work best
AND increase performance.
As always, thanks in advance for any help...
-Brian
SportyBry is offline
Old 08-18-2003, 01:13 PM   #2
renichms
Member#: 38550
2004 Impreza WRX STi
WR Blue
I should have video from inside my STi of a nighttime run on a really cool road (already got vid of the road but no BOV sound in it, not an aggressive run, bad camera angle and daytime ) in the near future...the BOV will be quite audible.
RN
renichms is offline
Old 08-18-2003, 01:24 PM   #3
RichQY
Member#: 31948
2004 STi
i was running last night
road was so smoother and quiet i heard bypass valve dumping sound clearly..
i never knew i could hear it w/o taking off the snorkel. but i did ..
along w/ my bad @ss detonation
RichQY is offline
Old 08-18-2003, 03:19 PM   #4
neverfastenuff
Member#: 19312
2004 WRX STi
Silver / Silver
I am trying to hook up with one of my friends who has a Digital recorder and take some video and sound clips to send to my brother. I will post some clips of the WorxTuning valve for you if I can ever get the equipment.
Mike
neverfastenuff is offline
Old 08-18-2003, 03:27 PM   #5
rjhang
Member#: 37184
2004 STi
Check out http://www.alltrac.net/tuning/alltracblowoff.htm _or_ http://socalsupras.com/tuning/blowoffvalve.html
These sites (identical?) have some BOV sound clips available.
-Rich
rjhang is offline
Old 08-19-2003, 12:48 PM   #6
SportyBry
Member#: 40648
2004 STi
Blue, of course
I'm still trying to find a sound clip of the WORXtuning BOV on an
STi. Can anyone help me out ?
Thanks again,
-Brian
Old 08-19-2003, 01:10 PM   #7
renichms
Member#: 38550
WR Blue
Oh yeah, didn't make the clip specifically for the BOV but got it loud and clear in STiParkRun2.mov:
http://www.schoolsubjects.com/sti/video
It's an HKS SSQV.
RN
renichms is offline
Old 08-19-2003, 01:35 PM   #8
JikJak
Member#: 38225
749 04STI 06CLS55
RangeRoverSport s/c
what is desnorkelfying?
JikJak is offline
Old 08-19-2003, 01:57 PM   #9
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
i think he's referring to the stock air intake which goes up the front of the engine bay and flattens out to suck air from under the hood.. .
filbert is offline
Old 08-22-2003, 12:40 AM   #10
SportyBry
Member#: 40648
2004 STi
Blue, of course
Does anyone out there have some sounds from the Worxtuning
BOV they can send me ?
-Brian
Old 08-22-2003, 02:51 AM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Im not big on BOVs on an other wise stock motor but I will say the RFL is R F L ... by far the loudest I have ever heard.
totoherbs is offline
Old 08-22-2003, 09:02 AM   #12
rjhang
Member#: 37184
2004 STi
Thanks again,
-Brian
I heard that WORXtuning will be making their BOV sound clips available via their website shortly. You may want to email them for a clip if you can't wait..
-Rich
rjhang is offline
Old 08-22-2003, 09:06 AM   #13
rjhang
Member#: 37184
2004 STi
It's an HKS SSQV.
RN
I like the sound although it is not very pronounced. It sounds more like chirping than wooshing, but maybe, that's just me.
A few questions, if you don't mind...
- So, are you running richer (perhaps a worse mileage, too?) as others say?
- Do you have to purchase a WRX or STi-specific mounting kit for SSQV?
- Does the installation require a ECU reset?
Thanks,
-Rich
rjhang is offline
Old 08-22-2003, 11:26 AM   #14
renichms
Member#: 38550
WR Blue
Thanks,
-Rich
-Gas mileage has NOT changed. If it gets worse, it's not noticable in the slightest bit.
-The kit for the 2002 WRX fits the STi perfectly. Same factory BOV, I'm told, and the same aftermarket kit fits. It was an easy install.
-It says to unhook the cable from the negative terminal. Mine stayed unhooked a long time. If this resets the computer, then it does require it (according tot he instructions).
I really like it...it's fun. Scares small children and ricers. In the car, it sounds awesome...the camera doesn't quite catch it. At some point, I'll have video from outside the car with it...
RN
renichms is offline
Old 09-03-2003, 04:39 PM   #15
WorxTuning
NASIOC Manufacturer
Member#: 42684
The factory valve on the WRX has a lower spring pressure than the STi, otherwise the valves are identical.
WorxTuning is offline
sound clip...16g plus SMC pump plus SSQV plus prodrive jimtweet Factory 2.0L Turbo Powertrain 5 03-27-2006 09:19 AM
BOV Sound clips creature546 Factory 2.0L Turbo Powertrain 10 07-15-2003 12:52 AM
BOV sound clips scooby555 North West Impreza Club Forum -- NWIC 0 07-09-2003 08:02 AM
BOV sound clips for those interested. ;) View Askew Bay Area Impreza Club Forum -- BAIC 6 03-18-2002 12:28 AM
('93-'01) BOV sound clips............ GOLDBERG Impreza Forum 7 09-28-2001 03:54 PM
Message Board Statistics All times are GMT -4. The time now is 07:15 AM.
