Old 08-23-2003, 04:29 PM   #1
blackjettaglx
Member#: 28853
2003 WRX Wagon
Default Oil change question
I am planning on changing the oil on my 2003 WRX wagon. I am on my way to the store to get the oil and filter and realized that I don't know what size and type of washer I need for the oil drain plug.
Does anyone know what the size and type required is???
blackjettaglx is offline   Reply With Quote
Old 08-23-2003, 04:51 PM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
I don't know the dimensions, but I know it'd be hard to find a similar crush washer anywhere other than at your local subaru dealer.... I think they are $0.75 or $0.50 apiece. You can't go wrong at the dealer service desk.
besides, I don't change off the washer EVERY oil change.. I let it go 3 or 4 times. No leaks no problems.
Cujo31 is offline   Reply With Quote
Old 08-24-2003, 02:37 AM   #3
SidneyWRX
Member#: 36099
'02 rex
I've never had a washer on mine and it's got 33k miles on it and 9 oil changes. Still as good as the first day I got it. Never needed to add any oil, nor has it leaked.
SidneyWRX is offline   Reply With Quote
Old 08-24-2003, 03:04 PM   #4
Platinum2003WRX
Member#: 33515
2003 WRX
Me neither..no leaks thus far
Platinum2003WRX is offline   Reply With Quote
Old 08-25-2003, 02:06 PM   #5
Wagon Joe
Member#: 34436
For me, it's definitely worth < $1.00 / 3 months for the peace of mind associated with changing the washer each time.
Wagon Joe is offline   Reply With Quote
Old 08-25-2003, 10:37 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
The crush washer helps ensure you don't ruin the threads on the pan by over tightening. It also helps keep the bolt from loosening between oil changes. Since the washer is "crushed" (hence the name) when you tighten the bolt, you're supposed to replace it at every oil change. If you use the same washer over and over again, it's not doing it's job.
- Kean
Old 08-27-2003, 12:00 PM   #7
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Kean is absolutely correct...
DerFahrer is offline   Reply With Quote
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 09:14 AM
wrx oil change question inchoate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2001 03:39 PM
('93-'01) Stupid Oil Change Question Star*Child Impreza Forum 7 05-19-2001 10:23 PM
Few oil change questions? Turk Normally Aspirated Powertrain 10 03-01-2001 01:50 AM
Oil change question... ImprezaRS2000 General Forum Archive 6 05-09-2000 09:06 PM
