Old 08-27-2003, 12:42 PM   #1
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Default Throttle body spacer
Does anybody make a T-Body spacer like the airaid ones for other engines? Also, would this make a difference in my engine? I havea 03 2.5RS with little to no mods.
Thanks for your time
Shane
PARANOID56 is online now   Reply With Quote
Old 08-27-2003, 06:20 PM   #2
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Paranoid, Are you after an Amazing Tornado like effect or insulation from heat or what's on your mind,,,?
Dr Ken is offline   Reply With Quote
Old 08-27-2003, 06:45 PM   #3
Julian
Member#: 1182
MY00 RS
BRP
The intake runners in the manifold are already plenty long. The extra inch or so you could extend the TB back towards the firewall will gain you nothing.
May be referring to the old Chebby trick of putting a riser under your carb to gain a bit of torque or help out an overcarbed engine.
Julian is offline   Reply With Quote
Old 08-27-2003, 06:50 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
no Amazing Tornado , no crap like that, i was just thinking of something like a heat spacer and something to make the intake runner a little longer. But as state above, they are already long. just ideas...
Shane
Old 08-27-2003, 08:17 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The spacer trick was to help the air & fuel mix better. You only have air going through your manifold.
The heat issue, do the TB bypass mod if you're that concerned about heat. It will make much more difference then a spacer.....especially if you do get a spacer and don't do the TB bypass
Legacy777 is offline   Reply With Quote
Old 08-27-2003, 11:34 PM   #6
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
well, come and join us at the phenolic spacer party, just a few threads down...
... you will likely have what you're looking for soon.... the rest of us are trying to source similar spacers for the EJ25.
Old 08-28-2003, 07:59 AM   #7
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
yeah. it won;t help to isolate the TB if oyu still have super-hot coolant coursing through it. it will actually make things worse since it can't bleed heat into the manifold. just do the TB bypass. at that point the manifold is heating things up more htan the TB.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-28-2003, 10:24 AM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
Yea, i already did the T-body bypass mod a few months ago (living in San Diego, i didnt think i would need all the hot coolent going into the tbody) So, would doing this help any?
Oh, if i had one made, would i just have one that matches a tbody gasket, ie, just trace out the gasket?
Shane
Old 08-28-2003, 10:24 AM   #9
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Hey Igg: very good point. Say, would you like some phenolic spacers for your beast if and when they're available ?
Old 08-28-2003, 10:42 AM   #10
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Hmmm,
Hondata gaskets for the intake AND throttle body.....
RokketRide is offline   Reply With Quote
Old 08-28-2003, 05:31 PM   #11
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
sure. I'm alwaysin the market for this or that. depends onthe price certainly. I'm poor and/or cheap
rokket - once you isolate the intake manifold, there's nothing to bleed heat into the TB. any heat the TB acquires form engine bay air will bleed into the intake manifold making act much like a heat sink. our engines just don't have much of a need for that kind of spacer. if there are gains to be gotten they are minimal.
-IggDawg
Old 12-14-2005, 01:14 PM   #12
calib17a
Member#: 64150
calib17a is offline   Reply With Quote
Old 12-14-2005, 04:31 PM   #13
flanders
Member#: 76382
2000 BH
BP Wannabe
I think he bought one off rs25.com
flanders is offline   Reply With Quote
Old 12-14-2005, 08:51 PM   #14
mattvct
Member#: 100377
The area where a phenolic spacer would probably work best on these cars is between the engine and the intake manifold rather than between the manifold and the throttle body.
In the past I've always just made my own, since they're not that difficult. Just trace your intake manifold gaskets onto some teflon skived sheeting in 1/8" thickness and you should be all set to cut and install (remember 1/8" longer mounting bolts however).
I've used this stuff in the past to great effect.
https://secure1.nexternal.com/shared...3&Refresh=True
mattvct is offline   Reply With Quote
Throttle body spacer for 2.2??? Jaredm82 Normally Aspirated Powertrain 8 07-09-2004 12:58 PM
throttle body spacer Haven Normally Aspirated Powertrain 6 09-30-2001 01:45 AM
Nitrous Throttle Body Spacer Joncas Normally Aspirated Powertrain 5 07-15-2001 04:06 PM
