Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 08-31-2003, 11:35 AM   #1
Aspen_2.5RS
Member#: 3310
Question Procedure to set timing on 02 wrx engine?
Hey, I'm trying to determine if my engine is out of time. Is there anywhere online that tells step by step how to set it? Or does anyone know how?
Again this is for an 02 wrx engine.
Thanks,
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 09-01-2003, 12:01 AM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The crank position sensor sends a signal to the ECU that fires the ignition coils. So the only "timing" adjustments would be to check that the Crank Position Sensor is firmly mounted, that the toothed wheel has not lost any teeth, and that the camshaft timing belt has not slipped. See page EN-194 in volume 3 of the Service manual.
Alan is offline   Reply With Quote
Old 09-01-2003, 12:05 AM   #3
Aspen_2.5RS
Member#: 3310
, this car was hit in the front which caused it to skip timing. BTW, I have no service manual, that's why I was asking. I already have it on now.
Cam
Old 09-01-2003, 03:01 AM   #4
Austin
Member#: 7089
The crank timing gear is secured onto the crankshaft by a woodruff key.
The only way your timing can be off is if the timing belt has jumped on either the crank timing gear or one of the cam gears.
Check the alignment marks between the timing belt and the crank/cam gears.
Austin is offline   Reply With Quote
Old 09-01-2003, 07:01 PM   #5
Aspen_2.5RS
Member#: 3310
THE TIMING IS OFF. It did skip teeth on the cam gears.
nevermind,
Old 09-01-2003, 11:50 PM   #6
Austin
Member#: 7089
Nevermind what?
You asked, I answered - if your timing is off, check/correct the alignment of the timing belt in relation to the cam sprockets
Clutch Bleeding Procedure on 02 WRX DreWRX Transmission (AT/MT) & Driveline 10 04-20-2010 01:13 PM
Need a reputable shop in central/west NJ to install clutch on 02 WRX Worxman02 Tri-State Area Forum 10 09-24-2009 02:38 PM
02 rs tranny on 02 wrx engine simprezl25 Transmission (AT/MT) & Driveline 0 09-22-2009 02:22 PM
Anyone know of a shop or home garage to install clutch on 02 WRX? Dreww Mid Atlantic Impreza Club -- MAIC 9 02-21-2009 08:17 PM
Ignition timing on 02 wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-02-2006 03:27 PM
