Old 09-04-2003, 02:19 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default front diff/ rear diff/ and RWD conversion
hey. ive got a JDM 4.11 trans, and a supposedly 4.11 JDM rear diff on the way. so, if my rear diff turns out to be somthing OTHER than 4.11 i am screwd rite>?
differnt gear ratio front/rear diffs make transmission blow up?
so......... if i were to do the RWD converison, with the welded center diff, i could run whatever rear diff i wanted right?
from my understanding, on a RWD car, FR layout, you can swap whatever rear diff gearing u want and drive it w/o any other transmission changes correct?
dos the subaru trans when turned into FR and no axels int eh front do the same?
h
supermoose is offline   Reply With Quote
Old 09-04-2003, 03:43 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why would you be screwed, a US 4.11 diff is somehow different from a JDM 4.11 diff
There are 4 common differential ratios, all of which can be easily found. The hardest is probably 4.44 which I just so happen to have for extra parts. 3.54 3.9 and 4.11 are fairly common so it wouldnt be so hard to find another. Even 3.7 is very easy to, but only prior generation subarus use them.
ciper is offline   Reply With Quote
Old 09-04-2003, 04:25 PM   #3
supermoose
Member#: 9093
swap starr
Default nerg
the idea of getting screwed wwould be my rear diff coming in somthign else other than 4.11 i dotn really wnat to have to swap final drives on it, got too much to do already.
h
Old 09-04-2003, 05:25 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
I dont understand. Swapping rear differentials is far easier than any of the other work you have to do! I did it WITHOUT a lift or special tools ALL ALONE in my driveway!
Old 09-07-2003, 07:35 AM   #5
JSiwek
Member#: 14909
In answer to your question, Supermoose... YES, you need to match the ratio of the rear diff with that of your tranny/front diff. If they are different it will be very bad. If your rear diff does come in the wrong ratio it's fairly easy to change it with a new ring/pinion set. That said, it's also VERY easy to get a US 4.11 rear diff.... I see no advantage to getting a 'JDM' one either... they're the same thing.
JSiwek is offline   Reply With Quote
Old 09-08-2003, 05:16 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default Re: front diff/ rear diff/ and RWD conversion
h
You got it right. The only change in running a different rear diff ratio is your speedometer would be changed.
FS OH: R180 Rear Diff., Rear Axles, and DCCD Stuff ej20_ftw Drivetrain 42 07-08-2008 01:06 AM
WTB: 02 psm oem wagon front diff/rear diff Dr. octagon Private 'Wanted' Classifieds 0 03-09-2008 05:07 PM
WTB 02-05 r160 rear diff, rear axles, and center diff 95gstnj Private 'Wanted' Classifieds 0 02-05-2008 12:38 AM
LS1 and RWD conversion on a Honda Prelude.... SilverBoosted Off-Topic 31 07-31-2006 05:58 PM
Need HELP: DccD Problems.. Center Diff?? Rear Diff?? Dccd Controller? NotoriousD Transmission (AT/MT) & Driveline 4 06-16-2006 04:26 PM
