Old 09-07-2003, 09:13 PM   #1
Wheeldog
Member#: 19848
2002 WRX Wagon
Default Comments on a 1990 Legacy wagon
Some friends of ours just picked up a 1990 Legacy wagon to replace one of their old cars that had gotten too expensive to be worth fixing. The car is interesting in that it only has about 63k miles on it. The inside looks pristine but the outside isn't so great - it's got rust holes that are just about big enough to put your hands through behind the front wheel wells and big surface rust spots in other places. Apparently the car runs well. I was just wondering what the known trouble areas are on this year Legacy.
Wheeldog is offline   Reply With Quote
Old 09-07-2003, 09:21 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
That's insanely low miles.
However yeah the rust issues suck.
May want to check out the legacycentral bbs www.bbs.legacycentral.org
Legacy777 is offline   Reply With Quote
Old 09-08-2003, 02:38 PM   #3
d4d4d4d4
Member#: 38925
1990 legacy wgn
Pig blood for paint
Thumbs up Great buy!
That's really really low miles for that year and model. Make sure all the CV joints and brakes are intact. Regardless of the exterior, the engine is brand spankin new for a 2.2l Subie boxer. You should easily see another 150-200,000 problem free miles. Just remeber to ALWAYS!!!! and I really mean ALWAYS warm up your car before taking off. 5-15 minutes is ideal for a morning start. 1-2 minutes if the car is still somewhat warm. If your car is an Automatic, then I highly recommend driving without 1st gear. Activate the MANUAL button on the shifter, then shift it down into 2nd or 3rd gear. The transmission will lock into 2nd and never jump down to first gear. The car will pull just fine from a stand still when in 2nd gear just as long as you don't need a speedy jump into traffic, in which case just deactivate the MANUAL button and you'll instantly be back in 1 st gear.
It's more important to do the 2nd gear thing when the car is just warming up. Since the AWD tranny is so large for such a small engine, it takes a long time for it to reach an ideal temp. As we all know, Auto trannies don't like shifting when cold. The tansmission will slam into 2nd gear and cause unneeded stress when cold. So, drive around town in second (second is good for speeds between 0-60) for a while before using 1st.
d4d4d4d4 is offline   Reply With Quote
Old 09-08-2003, 04:13 PM   #4
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Is it even an AWD? Is it a 2.2? I believe it came in the 1.8L as well as the 2.2L then. I have a '94 with about twice the milage, and haven't had too many problems. CV joints once or twice, but nothing major. Then again, mine is FWD. It may be different on an AWD.
IronMonkeyL255 is offline   Reply With Quote
Old 09-08-2003, 06:00 PM   #5
Wheeldog
Member#: 19848
2002 WRX Wagon
Thanks for the comments guys. I didn't have time to look the car over very well, but I'm quite sure it is FWD. I don't know which engine it has, or even what the trim level is. I may take a look under the hood the next time we are over at their place.
Old 09-08-2003, 08:02 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
IronMonkeyL255: Not in the US.
Wheeldog: Thats really low mileage, Id be afraid that it was all short trips and city driving (meaning lots of wear and tear)
ciper is offline   Reply With Quote
Old 09-08-2003, 08:17 PM   #7
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Oh, well... I guess I was mistaken. When did they offer the 1.8L 'til, anyway?
Old 09-09-2003, 11:07 AM   #8
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Default Re: Great buy!
Really? What about the larger 2.5L AT and 1.8L AT (Fwd) it really bothers me when I see a person pull right off after starting.. I like to think of it as someone pouring cold water on a sleeping person making them get up and work right away. Sooner or later the engine says I Quit!
SubaruImpreza_power is offline   Reply With Quote
Old 09-09-2003, 11:10 AM   #9
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
If it's like the other Subie engines Check under the Alternator on the engine block the Engine Model should be Stamped on their right under it.. It will say like EJ18, EJ25...etc
Old 09-09-2003, 12:01 PM   #10
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
USA market always had the 2.2, though in other markets, Europe, Asia, Japan, there were some 1.8 and 2.0 Legacies.
Legacies were also available in 2WD format until 1996, I believe.
I do miss my '93 Sedan...even if it was 2WD.
Matt is offline   Reply With Quote
Old 09-09-2003, 01:58 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
IronMonkeyL255: Only the Impreza got the 1.8. Legacy had the 2.2 and 2.2 turbo.
Old 09-09-2003, 06:55 PM   #12
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Ah... I believe they were available in FWD until '97. All Legacys were AWD '97 and on.
Old 09-10-2003, 09:28 AM   #13
aross
Member#: 831
11 Blurple WRX
03 BH MBP
My 1991 Legacy Sport Sedan shifts very well when cold.
I have never had a too firm shift, unless floored when cold, and who does that
My car has 310,000Kms on it, and the infamous AWD bind - but it still shifts great.
It is different when it gets to minus 20 - but I need to warm up then, not all year.
Perhaps I have a one off....
aross is offline   Reply With Quote
Old 09-10-2003, 10:29 AM   #14
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
what's this infamous AWD bind?
Old 09-10-2003, 05:35 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
The center differential starts locking up at random times. Fluid is leaking past and building pressure preventing the release at low speeds.
Old 09-10-2003, 05:40 PM   #16
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
So how will it make the car feel? Like it's fighting you?
Old 09-10-2003, 05:59 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
Take a U-Turn in a parking lot. You will easily feel it, and possibly even hear it.
I dont know how to explain it except for having a locked center differential, like in a normal 4x4. The wheels are trying to spin at the same speed so everything gets all bound of and you have to drag the wheels around as you turn. Puts ALOT of stress on the u-joints and wears tires down.
Old 09-11-2003, 12:11 AM   #18
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Wait a min here...... You mean if you turn the wheel at half to almost full lock that crazy sound that sounds like the steering pump is the AWD bind?
Hmmmm.. Or maybe not? My Fwd Impreza makes about the same nosie but not as loud as the Forester.
Old 09-11-2003, 02:15 PM   #19
ciper
Member#: 15543
90BJ Legacy LS ABS
"You mean if you turn the wheel at half to almost full lock that crazy sound that sounds like the steering pump is the AWD bind"
Probably not, that sound is probably fluid passing the seals inside the rack. It acts like a reed in a wind instrament causing the vibration.
Explain when the sound your speaking of happens.
Old 09-12-2003, 03:19 PM   #20
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Like making a U-turn on a street.. When the car is at full lock a loud Humimng sound can be herd.. Never did this on the old maxima we had.. It seems to be a Subaru thing.. I guess I gotta listen more when I make the tight turns.. It does not matter how fast you go right?
Old 09-12-2003, 04:09 PM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
Your holding the stearing against the stop
STOP DOING THAT!!!! You will damage the power stearing!!! Many WRX owners with less than 10k miles have needed items to be replaced from doing this from a short time! You should never hold the stearing all the way to one side.
Old 09-12-2003, 07:58 PM   #22
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
geeez The manual says hold it no more then 5 Sec.. What happens if you left it more then that?
Anyway it still makes that hmming sound does not need to be full lock.. you can turn the wheel about 180 and it does that sound. But I have to check this out tomorrow of that Awd Bind..
And to get it right We are talking about the 4EAT correct?
Old 09-12-2003, 08:34 PM   #23
ciper
Member#: 15543
90BJ Legacy LS ABS
Yeah AWD 4eat
There are many threads, here is an example
http://forums.nasioc.com/forums/show...hreadid=321407
Old 09-15-2003, 10:59 AM   #24
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Ciper, I don't hold my steering at full lock for maybe more than a second, and not very often either... I'm doing damage even this way???
DerFahrer is offline   Reply With Quote
Old 09-18-2003, 08:48 PM   #25
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I had to make a tight turn at a stop sign (Went down wrong street) and I was in a factory area and their was no where else to go but to turn around.. It took me about 2 Sec to make the full turn.. I did let go once I felt i did enough turning..
Just don't go crazy in the snow but try to advoid turning at full lock.
Took my 1990 Legacy wagon to 14.9 finally, 10 psi reddevil Proven Power Bragging 12 08-14-2006 12:53 AM
Parts, parts, Parting out 1990 Legacy wagon. soslow Private 'For Sale' Classifieds 6 03-16-2006 11:16 PM
1990 Legacy wagon with a loud, obnoxious rear end the_legacy Legacy Forum 3 11-14-2005 01:51 AM
Thinking of 1990 Legacy Wagon PETC Legacy Forum 14 06-16-2005 10:43 PM
Parting out 1990 Legacy wagon Legacy777 Private 'For Sale' Classifieds 2 09-07-2004 08:45 AM
