Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 05-24-2000, 11:45 AM   #1
HRE | giulio
Member#: 481
Question The vacuum hose+bead trick... thingy
I did a search, but i cant find the original thread.
Someone once said they used a bead in some hose to enrichen the fuel mixture. Anyone remember that?
If you can find it, or know the steps to do it, let us know.
Thanks,
g
HRE | giulio is offline
Old 05-25-2000, 12:32 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Haven't heard anything about it but I'm guessing that they were talking about the hose the comes off the intake plenum towards the throttle body. I think that one takes a reading as to exactly what kinda prssure there is in there, but I'm not sure. It obviously has something to do with the way the car runs since it won't run with it off.
Personally I don't know about putting a bead in there (which'd make the passage for air smaler since it forced the air through the hole in the center of the bead instead of just the hose)... I'd be worried about it being sucked in or out or something.
8Complex is offline
Old 05-25-2000, 12:38 AM   #3
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Actually it was modifying the vacuum signal to the fuel pressure regulator so that it would see more vacuum and raise the fuel pressure in the rails. I personally wouldn't do this, but to each his own.
rao is offline
Old 05-24-2000, 01:25 PM   #4
HRE | giulio
Member#: 481
Post
I rem the bead was tight, and the the hole in the bead (made for string) still let some air pass through.
This mod was created before the SAFC was mainstream.
Old 05-24-2000, 03:11 PM   #5
Keith
Member#: 191
2012 J train
Brown
Post
haha I acutally know alittle about this Dave (service manager of metric subaru) does this for his/mine/other dealers, car everytime we go to an auto-x. I dont think it does damage, but he says only to do it when racing, not all the time. he puts a screw in the vaccume line, I can show u how to do it if u like It helps alot though..I think
Keith
Keith is offline
HTML code is On
where is the vacuum hose for boost gauge bigj514 Electrical & Lighting 2 12-22-2006 03:12 AM
i took off the vacuum hoses and found this OvrClkdPmp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-25-2005 04:48 PM
More PSI by changing a part of the vacuum hose? J Ho Newbies & FAQs 5 03-04-2005 10:38 PM
What is the vacuum hose size for stock BOV? Styley1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-23-2003 07:50 PM
