Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-29-2003, 08:54 PM   #1
DrunkenDragon
Member#: 21471
Default EJ22T conversion Documented?
hey i was wondering if anyone Documented an EJ22T swap into a GC?
like how some one documented an H6 conversion to a GC like the one you would see here?
http://linaracing.com/pics/eventdeta...6%20Conversion
thanks
DrunkenDragon is offline   Reply With Quote
Old 12-30-2003, 01:50 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
There is no documentation that I am aware of. If somebody would like to write it up I'll be happy to add it to the FAQ.
-Jon
stimpy is offline   Reply With Quote
Old 01-06-2004, 07:52 PM   #3
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Default How about some definitive info?
A documented swap would be excellent, but until then, maybe a collection of definitive info would be good? After searching through all of the threads, I have generally read that an EJ22T swap into a GC8 is very straightforward, but for those who have done it, what specifically is needed for the swap, and what speficically is to be expected? I keep seeing it mentioned that the stock ECU can be used, along with the 2.5 heads (SOHC or DOHC) and that all that is needed along with the block itself is a legacy oil pump.
Considering someone wanted to use the block as is with stock internals, what else is needed, and what else is to be expected or modified during swap, (injector mounting and location?) Also, what type of work is required to finish the project, being that it is straightforward?
Expertise much appreciated.
jonathan
ilmaestro is offline   Reply With Quote
Old 01-07-2004, 08:06 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
over on legacycentral.org they have the factory parts list and factory service manuals in pdf forum.
here is a linky linky
everything can be found here & yeah they should be in pdf.
http://www.main.experiencetherave.co..._manual_scans/
For the parts things, there's this
http://www.main.experiencetherave.co.../Parts_Manual/
and the black blook parts sheet
http://www.surrealmirage.com/subaru/...art_Sheets.pdf
subiekid is offline   Reply With Quote
Old 01-07-2004, 12:18 PM   #5
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
I can't help too much...paid someone to do my motor swap
the mechanical part of it is straight foward...it's the wiring that can be a bitch
Scoobyslack1 is offline   Reply With Quote
Old 01-07-2004, 01:44 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Are you asking for a full EJ22T swap or just a shortblock swap?
-Jon
Old 01-07-2004, 02:29 PM   #7
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
-Jon
Just a shortblock swap, to build a 'hybrid' with current EJ25 heads since it seems that's what many people with GC8's do. This would be the most straightforward option, no rebuilding of the block, all the existing sensors and wiring would be used.
jonathan
Old 01-07-2004, 02:49 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
There should be lots of that information in the Aftermarket Forced Induction section.
Please dig around and post it up in here once you find it. I'll put it up in the FAQ.
-Jon
Old 01-07-2004, 03:19 PM   #9
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
-Jon
Oh believe me, I've dug There isn't a thread I havn't read. I guess I'll agree with DrunkenDragon, a documentation of the most simplified shortblock swap would be good.
jonathan
Old 01-07-2004, 07:11 PM   #10
DrunkenDragon
Member#: 21471
Well i was thinkin of the whole motor swap... ECu and wiring
Old 01-07-2004, 09:38 PM   #11
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
That would sure be a lot of documenting
Old 01-07-2004, 09:51 PM   #12
james_gt
Member#: 20852
1995 Impreza L
Red
well I just did the whle swap ecu and whole engine. It is fairly straightforward, as said the wiring can be a pain. The mechanical part was very easy, we just had to make a few adjustments for the coolant line and the throttle body. The hardest part I did was try to install a wrx intercooler on it. I would be glad to help if needed.
james_gt is offline   Reply With Quote
Old 03-02-2004, 02:43 AM   #13
DrunkenDragon
Member#: 21471
bump?
Old 03-02-2004, 04:16 AM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
In this thread there is a link to just about every good ej22 thread...
http://forums.nasioc.com/forums/show...hreadid=505723
This one will show just how different the liner thickness...
http://forums.nasioc.com/forums/show...highlight=ej22
totoherbs is offline   Reply With Quote
impreza outback sport EJ22T conversion KillerBumbleBee Subaru Conversions 15 11-10-2008 10:53 AM
EJ22T conversion---expert advise needed RedP1 Subaru Conversions 7 11-21-2003 12:34 PM
ej22t conversion krzyxkrean Legacy Forum 2 10-20-2003 07:17 PM
EJ22T Conversion into MY99 2.2L... Can anyone here do it? Soon2BturbodRS North West Impreza Club Forum -- NWIC 1 07-03-2003 12:30 AM
EJ22T conversion questions... Fitz Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-14-2001 09:56 PM
