Old 01-02-2004, 04:46 PM   #1
wgknestrick
Member#: 32576
04 STI
Default Everything you need to know about boost creep
With the countless threads about boost creep problems with turbobacks on the 2.5l STI, I think this thread should be helpful as a quick summary to those planning on moddifying their STI.
Q) What is boost creep?
A) Boost creep occurs when the wastegate is physically unable to bypass enough exhaust around the turbine on the turbo.
Q) Is boost creep harmful?
A) Yes, boost creep is one of the worst problems you can have with a turbo engine. Boost creep means that there is NO way for the boost pressure to be controlled. Boost pressures in excess of 20psi!!! have been recorded on STIs with TBE before the ECU cuts fuel.
Q) What causes boost creep?
A) Installing a turbo back exhaust whether aftermarket catted or not will in almost all cases cause boost creep to a certain extent.
Q) Are there any other options to prevent boost creep besides porting the wastegate?
A) Yes, Installation of an exhaust that either keeps the stock OEM muffler or one of the stock cats should not cause boost creep.
Q) How do I know if I have boost creep?
A) If you have a full TBE, then you probably have it. A boost gauge will tell you what pressure you are at as well. Fuel cut occurs when the ECU senses boost in excess of 17.5psi for 2-3s. Fuel cut in my experience is a very violent "stutter" from the engine that resembles extreme knock, followed by CEL.
Q) What is the overboost CEL?
A) (P0244) Wastegate malfunction
Q) Is there anything else I can do besides porting the wastegate to prevent the creeping....MBC, EBC, engine management etc?
A) This problem is isolated to the wastegate only. The wastegate is a mechanical system. There are no current workarounds or "fixes" besides this. The 2.5l just flows too much exhaust through the turbo once a turbo back has been added for the wastegate to control boost. If you think of it as a hierarchy, then it should make sense.
level 1) wastegate controls boost pressure
level 2) boost solenoid controls wastegate
level 3) MBC/EBC/ECU controls boost solenoid
Using this logic, if the problem resides on the 1st level, no matter what you do on top of it, you will still have the problem. Whatever (MBC, EBC, UTEC, ECUTEK) is controlling the wastegate CANNOT prevent boost creep if the WASTEGATE is UNABLE TO FLOW ENOUGH EXHAUST to prevent boost creep. A fuel cut defender will not eliminate the boost creep problem, but it will stop the fuel cut. Your boost will still creep up to 20psi, but the ECU won't be able to tell due to the altered signal from the FCD.
Q) My car seems to boost creep when it is cold out. Why is that?
A) Ambient temperature plays a huge role in how well your engine runs. In general, the cooler ambient temperature, the better your engine runs due to the laws of thermodynamics. The colder air causes your engine to make more HP (more work under the curve with lower temps), therefore more energetic exhaust gases, therefore your car is more prone to boost creep when it is cold out. If you live in an area that does not see colder temperatures (AZ for example) too often, then boost creep may never become a problem.
Q) I want to port my wastegate. What do I do?
A) Can you remove and install a turbo? If yes, there are a couple of options. You can send it to Deadbolt (www.deadboltspeed.com) for porting, have a local machine shop port it, or do it yourself with a "Dremmel like" tool.
Some other info on porting:
http://rx7.freeservers.com/modhb/boostcontrol.htm
http://www.fwdmopar.com/sites/dennis/wgateport.html
http://forums.nasioc.com/forums/show...hreadid=300296
http://www.allpar.com/mopar/boost-creep.html
http://members.tripod.com/alexander_grabau/id18.htm
(edited---to fix links, add links, and include CEL code)
(edited #2---to include temperature question)
I hope this is helpful to some people and please let me know if anything needs to be corrected.
Bill
wgknestrick is offline   Reply With Quote
Old 01-02-2004, 04:54 PM   #2
Sev
Member#: 8364
4.5 STi
dirty
nice thanks for the laying it all out....
areg
Sev is offline   Reply With Quote
Old 01-02-2004, 05:05 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I hope I never meet the boost creep.
ANZAC_1915 is offline   Reply With Quote
Old 07-16-2005, 11:20 PM   #4
TampaSTI
Member#: 90140
2005 STI
Good article http://www.pghsubarus.com/tech/porting/porting.aspx about boost creep & porting the wastegate
TampaSTI is offline   Reply With Quote
Old 07-17-2005, 12:32 AM   #5
slingshot
Member#: 44668
'07 M5
Pretty sure I got that link from this thread in the first place.
slingshot is offline   Reply With Quote
Old 07-17-2005, 01:51 AM   #6
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
My overboost problems have always only been in 4 or 5 gear. This was with modded WRX. Quick high rpm/air flow solves this in gears 1,2 ,3.
Installed TurboXS turbo back with stock muffler '05 STI, max boost went from 14psi stock to 15.5 psi TSX, no more, falls off at 6000+ rpm with stock turbo anyway, back to 14 psi or so.
Seems another solution no one has mentioned would be a different turbo designed for more air with corresponding larger wastegate able to handle whatever the 2.5 blows at it. Recommendations? hwy61
hwy61 is offline   Reply With Quote
Old 04-15-2015, 08:40 PM   #7
enzomatic75
Member#: 266558
If you lived in Longmont, CO, you'd already know him
enzomatic75 is offline   Reply With Quote
Old 01-02-2004, 05:25 PM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
you need to fix the nasioc thread... put this link...
DanzBorin is offline   Reply With Quote
Old 01-02-2004, 05:28 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The scoobynet link is messed up too. Very nice post you got there, reminds me of my FAQ series! Good Job!! Since this is a super common issue with the STi, maybe this should be stickied??
Old 01-02-2004, 05:52 PM   #10
T3RMIN4L
Member#: 37434
[email protected].. nice writeup wgknestrick. Anyone who has met the boost creep and capped the flow with their stock axleback care to comment on the performance loss compared to the full 3"+ back? Personally I think its more than noticable on the butt dyno.
T3RMIN4L is offline   Reply With Quote
Old 01-02-2004, 05:58 PM   #11
wgknestrick
Member#: 32576
04 STI
Can anyone help me out with detailed, pictorial instructions for turbo removal/installation. getting the turbo installed back in the car was more difficult than I ever thought it would be. Instructions would be nice for the community.
Old 01-02-2004, 07:24 PM   #12
hatchy
Member#: 36852
2004 STI
ECU cuts fuel at above 17.5psi, I think, not 20psi.
And fuel cut feels more like hitting the rev limiter.
hatchy is offline   Reply With Quote
Old 01-02-2004, 07:25 PM   #13
Neil Fowlie
Member#: 50018
oh good I am not an idiot
I listen to all the people talking about waiting for the utec
to eliminate boost creep, and wondered how it could possibly do that. Same thing happens on eagle talons, but there it raises boost from 10 to about 13 psi, still safe and nowhere near fuel cut.
The only way to get rid of creep is to port the wastegate.
unless you are planning to use the utec, to actually tune the car
based on the 20psi you will be running.
another thing to consider before going for a tbe
when you see manufactures claims of hp increase
most of it is due to the increase in boost.
for example my old fwd eagle talon dynos at 145 whp stock (10psi) after TBE (with cat) 170whp (13 psi)
after i had my turbo ported, I tried setting the boost back to stock(10psi) with the TBE, dynoed at 151. Then same day turned the boost up to 13psi power back up to 170whp
So basically the TBE gave minimal gains on its own
all the claims from the aftermarket shops were kinda
misleading. Taking the credit from boost creep
in their hp increase claims.
I know these are totally different cars
but when I see a company claiming their exhaust makes an extra 27 whp for the sti, the first thing that i think is, oh 20 hp for the extra boost, 7 for the exhaust
Neil Fowlie is offline   Reply With Quote
Old 01-03-2004, 12:16 AM   #14
qbbraveheart
Member#: 49043
thanks for clearing everything up
qbbraveheart is offline   Reply With Quote
Old 01-03-2004, 12:25 AM   #15
XT6Wagon
Member#: 524
04 STi
Actualy A wastegate doesn't NEED to flow enough exaust to control boost, it only needs to be able to control the pressure drop ACROSS the turbine. So the stock wastegate setup in a VF39 works great because while it doesn't flow worth a damn, its great and murdering the flow out of the turbine with the stock downpipe in place. In fact I bet if you could measure the flow through the wastegate for both the stock downpipe and a aftermarket bellmouth, you would find that the flow goes up alot with the aftermarket setup... yet can't control the boost as well thanks to the flow not being able to affect the flow out of the turbine anywhere near as well as with the stock downpipe
XT6Wagon is offline   Reply With Quote
Old 01-03-2004, 01:40 PM   #16
BU308
Member#: 9905
'01 GDB STi RA
'04 2.0 FXT
Does a stronger wastegate acuator such as the one from HKS cure the boost creep problem? I am having the boost creep problem on my JDM STi7 wagon after installing the Cusco downpipe. Thanks.
BU308 is offline   Reply With Quote
Old 01-03-2004, 01:50 PM   #17
carguy19
Member#: 48550
2004 ^^^whp ^^^wtq
the gains on a turbo car with an exhaust are typically 7-10% from my experience, even on cars that don't spike.
carguy19 is offline   Reply With Quote
Old 01-03-2004, 02:14 PM   #18
wgknestrick
Member#: 32576
04 STI
Wastegate diameter is pretty much the only variable that is directly linked to boost creep. A spring will do nothing to help creep. The boosts "creeps" because the wastegate is completely open yet still cannot flow enough exhaust through it to control the boost. Whether it "flows" enough exhaust or "is large enough" to equal the pressure differences is a moot point because this is the same thing, just worded differently.
Downpipes can also contribute (read HKS and stock designs)
Old 01-03-2004, 03:01 PM   #19
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
I had to cap mine with the stock axleback after getting boost creep with a Bosal downpipe,cat eliminator pipe,stock mid section and a Prodrive tailpiece.
It didnt seem to hurt the lowend,,but the car definately does NOT pull as well topend.My butt dyno says,,if i got a 30%increase in power with boost creep, I figure i lost 15% by putting the stock axleback back on.
But hey ,it's safe.
Rudy
ps excellent writeup wgknestrick
jagcars26 is offline   Reply With Quote
Old 01-03-2004, 04:27 PM   #20
T3RMIN4L
Member#: 37434
yeah Id agree the power gains were amazing will the full turbo back and Im sooo upset about having to settle for less power and seemingly worse throttle response.
Old 01-04-2004, 02:20 AM   #21
XTC
Member#: 46202
2005 STI
What if you get a downpipe such as the B&B downpipe or the BMP twin dump downpipe? They have split collectors for that separate turbine and wastegate gases. Will that help eliminate boost creep?
XTC is offline   Reply With Quote
Old 01-04-2004, 12:11 PM   #22
jagcars26
Member#: 2394
2009 Forester X
Like I said earlier,,I have the Bosal(twin dump) downpipe,,I still got boost creep.
Rudy
Old 01-04-2004, 12:18 PM   #23
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
XTC - you will still get the boost creep.
Zornorph is offline   Reply With Quote
Old 01-04-2004, 12:43 PM   #24
complexx
Member#: 46948
2004 Impreza WRX STI
World Rally Blue
Default diagram
can anyone link to a diagram that draws out the flow of gases through this system, I want to make sure I'm understanding this concept properly.
complexx is offline   Reply With Quote
Old 11-20-2006, 08:25 PM   #25
blitzjza80
Member#: 46002
2005 STi
OK, I will install my invidia divorced waste gate downpipe to my stock cat-back exhaust, will I seen boost creep? My car is an 05 STi, bone stock. I am in So.Cal area, so the weather is not that cold. I am so worry about the boost creep issues after finished reading this entire thread. Please let me know then. Thanks!
blitzjza80 is offline   Reply With Quote
Everything you need to know about a Cutout? zacxzx Newbies & FAQs 25 05-15-2009 06:31 PM
everything you need to know about turbos dankEe Tri-State Area Forum 1 11-08-2007 05:59 PM
Everything I Need to Know about Raleigh Durham But Was afraid to Ask Cdiff South East Region Forum 5 12-13-2005 02:13 PM
Everything you want to know about cheap boost control desiwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 86 03-09-2005 08:21 AM
Everything you wanted to know about the WRC but were afraid to ask rsquire_downunder Motorsports 7 02-12-2003 11:28 AM
