Old 02-01-2004, 03:05 PM   #1
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Exclamation Need Emergency Help: Alarm System
Ok guys, let's see if you can help me out. My car is stuck at Arby's!!! A wire, presumably from my alarm system was hanging down by my feet and I believe I kicked it free or broke it. Now my alarm won't work and it seems to have killed my engine (I have ACC power, the car just won't crank).
I think I've damaged the alarm somehow and now I can't bypass the engine kill. I need to figure out how I can get the car started - I'm guessing that I'm going to have to disable the alarm system somehow.
Is this possible? Am I screwed? Any ideas? Thanks in advance.
Garret
Ghomer1 is online now   Reply With Quote
Old 02-01-2004, 03:17 PM   #2
JBPolkAudio
Member#: 5025
2004 STi
Where is your car? Can you reattach the wire you kicked? Can you get a rolling start and pop the clutch to start it?
~JB
JBPolkAudio is offline   Reply With Quote
Old 02-01-2004, 03:20 PM   #3
Ghomer1
Member#: 8091
2007 335i
Hey JB, I don't think i can reattach the wire - the wire that I kicked was the one that has the little LED light on the end, just to indicate that the alarm is on.
It's at Arby's in Laurel. NO HILLS!!!
Old 02-01-2004, 03:23 PM   #4
JBPolkAudio
Member#: 5025
2004 STi
Man, if you weren't all the way in Laurel, MD I would be there to help you out. I say find some guys to push you and pop the clutch. Or try reattaching the wires together and see if that solves anything for you, but it doesn't sound like that's the problem if it's just the LED light.
~JB
Old 02-01-2004, 03:28 PM   #5
Ghomer1
Member#: 8091
2007 335i
Thanks man - I know, it's just bugging me out. I don't know much about electrical - right now I just want to disable the alarm and start the damn thing.
G
Old 02-01-2004, 03:55 PM   #6
Uncle Scotty
OK Houston
we have an Uncle
*Note to self*------Tie wires up where they won't get fooked....
Old 02-01-2004, 03:56 PM   #7
Ghomer1
Member#: 8091
2007 335i
Didn't even see it come down. I guess I just put my big ass boot up too high....
Thanks for the bump though.
Old 02-01-2004, 04:06 PM   #8
BlueF
Member#: 45324
2008 STI
Regarding a "pop start"... you don't need a hill, long as you have flat ground and a few friends to push.
Here's hoping you get it going! : )
BlueF is offline   Reply With Quote
Old 02-01-2004, 04:45 PM   #9
Ghomer1
Member#: 8091
2007 335i
I don't think even a pop start would have got it running - the factory alarm IIRC has an engine kill switch. I think even if you get it going, the electrics won't let the car run.
In any case........I got it running. I had actually broke the valet switch (and maybe something else) right at the connection. So basically what I had to do was to cut and twist together the two wires leading to that switch.
BUT, I have no alarm or keyless entry right now - I'll have to check the alarm manual to see if I can troubleshoot this. Pretty messed up. Looks like I'll bit hitting the dealer soon.
G
Old 02-01-2004, 04:59 PM   #10
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Check the fuse. Its hard to find, its burried up in a bunch of wires in the dash near where the alarm brains are installed. There are 2 individual fuse holders up there with the alarm fuses. If the fuse goes out the car won't start, same thing happened to me.
slim speedy is offline   Reply With Quote
Old 02-01-2004, 07:06 PM   #11
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Just FYI,
The factory alarm has a starter interrupt circuit. IIRC there's not an ignition interrupt. Basically this means if you can pop start it, the engine will run and allow you to drive home.
Incase you don't know how to push start your car:
BTW, this only works on manual transmissions.
1. Round up 2-3 of the largest guys you can find.
2. Turn the key all the way on.
3. Put the transmission in 3rd gear.
4. Push the clutch all the way in.
5. Make sure you have a decent amount of distance in front of you.
6. Have them push you as fast as they can and let the clutch out quickly.
7. As soon as the engine starts, push the clutch in.
8. Thank the guys who pushed you and boogie home.
Regards,
Chris
FletchMY98 is offline   Reply With Quote
Old 02-02-2004, 05:58 PM   #12
ursine
Member#: 51771
2000 Impreza GC6 SRP
1980 G2 Celica Rally Taxi
I did the same thing but I did it on purpose, now I dont have an alarm system but I do have a nice little button under the dash that you have to hold to start the car. To some this may sound inconvenient but at least nobody can steal my car.
-Branden
ursine is offline   Reply With Quote
Old 02-03-2004, 11:30 PM   #13
Ghomer1
Member#: 8091
2007 335i
I'm just wondering why the alarm system won't work now. What do I need to do to get it to work? The car wouldn't start without the wires twisted together, but now that I have them together, the alarm won't work.
:sigh:
Perhaps I'll just take it to the dealer and let them sort it out.
g
Need advice on alarm system wheresmycar Car Audio, Video & Security 12 07-23-2004 04:02 AM
Need Emergency Help: Tire Ghomer1 Mid Atlantic Impreza Club -- MAIC 8 04-11-2004 02:34 PM
Need help finding alarm system rbehny Car Audio, Video & Security 4 02-28-2003 02:35 AM
need help installing the Subaru Alarm system!! bobo Car Audio, Video & Security 1 01-06-2002 12:10 AM
Do I need an alarm system? caligula New England Impreza Club Forum -- NESIC 20 10-31-2001 12:00 AM
Message Board Statistics All times are GMT -4. The time now is 11:52 PM.
