Old 02-03-2004, 04:12 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default 6spd sti clutch/flywheel in 5spd wrx tranny?
this is my second clutch/flywheel in my wrx, being the replacement for the original which was covered under warranty because of the cold clutch judder issue. well, it's doing it again
i give up. i was holding out hoping all my problems would be solved once i found a 6spd sti swap i could afford, but it's too late now. i've read in some threads of people being able to use the clutch/flywheel/pressure plate from a 6spd in a 5spd wrx, and my cold clutch judder problems will never come back again (i hope)... but there was something about having to grind away portions of the inner bell housing on the tranny i'm not clear on.
can someone walk me thru this?
Benjamin Tang is offline   Reply With Quote
Old 02-04-2004, 09:40 AM   #2
Billy_H
Member#: 34047
02 WRX
Check RalliSpecs website, they sell the Exedy Sport Clutch which is almost identical to the STi clutch and a hell-uva lot cheaper...oh, and it bolts right on.
Billy_H is offline   Reply With Quote
Old 02-05-2004, 09:25 AM   #3
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Ben. Give Mike a call at the shop (Kingpin). He installed a 6mt Fly and clutch in his 5mt a while back. I think he said 45 minutes with a die grinder to make it work...
Clark
AZScoobie is offline   Reply With Quote
Old 02-05-2004, 09:31 AM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Clark
Cool..... the STi is like an inch bigger right?
totoherbs is offline   Reply With Quote
Old 02-05-2004, 09:35 AM   #5
AZScoobie
Member#: 8785
netcom.com
It only hits in a few places. I saw the grinding work before it was done. Its not that bad and you get a much better clutch.. The fly is heavy though.. Probably a good setup for drag racing. Mike loved the 6mt clutch.
Clark
Old 02-05-2004, 09:40 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
does the flywheel have a larger overall diameter? would that mean having to use an sti starter?
Old 02-05-2004, 09:41 AM   #7
AZScoobie
Member#: 8785
netcom.com
No.. Its thicker and the "weights" hit the bell housing.. Start and every other piece work. Its a direct swap as long as you grind out the housing. Call Mike for info on where and how much grinding.
Clark
Old 02-05-2004, 03:00 PM   #8
Benjamin Tang
Member#: 4496
2009 Forester
red
thanks clark... any thoughts on whether i should go and get the stock flywheel machined down for weight?
Old 02-06-2004, 12:20 AM   #9
Z1 Performance
Member#: 9327
just fit a proper 5 speed clutch (non OEM) and you'll be fine ...the 6 speed is the same basic unit, only 5mm larger in diameter. 6 Speed clutch works as Clark pointed out, though you have very few options in the aftermarket.
Z1 Performance is offline   Reply With Quote
Old 02-06-2004, 12:25 AM   #10
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
pm'd you
David Glasscock is offline   Reply With Quote
Old 02-06-2004, 06:26 PM   #11
Benjamin Tang
Member#: 4496
2009 Forester
red
can u recommend a driveable 5spd clutch and flywheel setup? i've gone thru so many aftermarket clutches in the past and have had mixed results, from bear traps that made my left leg bigger than the right, to poor reliability.
the other reason i'm kicking this around is because i can find cheap low mileage used 6spd sti clutch/flywheels for $200.... still need a bearing though. and then the cost to install... grinding... i just want this cold chatter to end!
Old 02-06-2004, 06:46 PM   #12
Z1 Performance
Member#: 9327
Well, let me know what you have had so far on your Subaru that you were not pleased with so we can narrow down a list
Old 02-06-2004, 07:13 PM   #13
Benjamin Tang
Member#: 4496
2009 Forester
red
not subaru but on my previous hondas and acuras that i've owned... act, clutchmasters, exedy.
Old 02-07-2004, 01:12 PM   #14
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Hey Ben,
As Clark mentioned I dropped a 6spd clutch in my 5spd last year. I had already tried several aftermarket clutches and didn't find anything that I liked. The 6spd is inexspensive and is a great replacement. We usually carry them for $300 with flywheel. Let me know if oyu are interested. Thanks.
Mike
Kingpin is offline   Reply With Quote
Old 02-07-2004, 01:26 PM   #15
Benjamin Tang
Member#: 4496
2009 Forester
red
mike... how bad is this heavy flywheel issue? is it something i can machine the flywheel to lighten it up, or....?
Old 02-08-2004, 03:46 AM   #16
Chaste Automotive
Vendor
Member#: 44921
We hvae two different clutches for STi 6 speed, Alcon and AP if you are interested. Exedy are are the exact same as the STi clutches.
Chaste Automotive is offline   Reply With Quote
Old 02-08-2004, 12:44 PM   #17
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
You might be able to machine this but I have not tried. I left mine stock and had no problems with it. Aftermarket flywheels are available for this setup if you prefer. Thanks.
Old 02-18-2004, 11:37 AM   #18
Benjamin Tang
Member#: 4496
2009 Forester
red
is it possible to reuse the wrx flywheel bolts?
Old 02-18-2004, 01:56 PM   #19
AZScoobie
Member#: 8785
netcom.com
Yep. Just use a drop of locktite and trq down.
Clark
Old 03-06-2004, 06:10 PM   #20
myton78
Member#: 35215
What about stock wrx clutch and heavier flywheel (I dunno what flywheel though.) Will this cure the judder?
Kingpin for the 6spd mod, what area needs to be machine in this picture?
http://www.oakos.com/wrx/gallery/gearbox/IMG_5403.JPG
all pics located http://www.oakos.com/wrx/gallery/gearbox/index.htm
myton78 is offline   Reply With Quote
Old 03-06-2004, 06:44 PM   #21
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
Well not the best picture for this. You basically need to shave down the ribs on the inside of the bell housing and a bit of the area up by the starter whole.
This pic is better.
Old 03-07-2004, 10:24 AM   #22
myton78
Member#: 35215
This pic is better.
thx
Old 03-07-2004, 10:43 AM   #23
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Now I know there is reasoning behind this, but if the Exedy plate is the same as the STI, why grind the hell out of your bell housing?
Wouldnt it just make more sense to use the properly sized clutch/flywheel? Or it there some difference in feeling that can be noticed?
Gfunk720 is offline   Reply With Quote
Old 03-07-2004, 12:22 PM   #24
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
The reason that I had gone to this combo when I had my 5spd were as follows:
1. The STi unit is much beefier than the USDM version and I was putting down enough power to make this a concern.
2. I had been thru the aftermarket excedy full face unit as well as several other clutches. The heavier duty of which held the power but were a nightmare to drive on a daily basis. On the other end the full face units I was tearing thru. This was a good compromise of both.
3. Cost. Very inexspensive and at the time that was a concern.
4. Availability. There was one in the shop.
I really liked the feel and holding power of the STi unit. I of course eventually went to the 6 spd and still use the stock STi unit with that. This isn't for everybody, but it worked well for my situation. Thanks.
Old 03-07-2004, 04:29 PM   #25
Benjamin Tang
Member#: 4496
2009 Forester
red
what kingpin said... having had heavier-duty aftermarket clutches on previously owned cars,i don't want to be walking around with my left leg being bigger than my right
WTT: 6SPD STI Tranny for a 5SPD WRX Tranny crav3s2k MAIC Private Classifieds 30 09-10-2009 11:08 AM
06 clutch/flywheel in 02 wrx Boarder325 Transmission (AT/MT) & Driveline 2 11-04-2008 07:35 PM
06 Sti swap on a 5spd wrx tranny AlmirWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-03-2008 11:36 PM
sti 6 spd clutch &flywheel in 5spd wrx trans ECUtuneOne Transmission (AT/MT) & Driveline 9 09-06-2006 07:34 PM
6spd clutch/flywheel in 5spd transmission OneArmedScissor Transmission (AT/MT) & Driveline 1 12-21-2005 12:05 AM
