Old 02-09-2004, 06:14 PM   #1
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Default idler wobble
Now i'm not totally positive its called the idler. It is the wheel that has the two belts going around it. Well anyway i've noticed that when running it seems to be wobbling a little bit. Any suggestions?
Brindor2.5 is offline   Reply With Quote
Old 02-09-2004, 07:02 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If it's the large pulley in the center of your middle timing belt cover, it is the crankshaft pulley which drives all the others. It will wobble a little bit, but you should check to make sure the bolt running through the center of it is tight.
Brian
North Ursalia is offline   Reply With Quote
Old 02-09-2004, 10:12 PM   #3
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
ok i'll check that, thanks.
Old 02-10-2004, 09:28 AM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I had this problem. The main crank pulley is actually made of 3 pieces [pressure?] fitted together, a center metal pulley, a rubber (i think it is) ring called the harmonic dampener, and an outer metal ring. Check to see if the harmonic dampener is sticking/slipping out. It happened on mine and caused the pulley to wobble when the engine was on. Took it in to the dealer and they fixed it under warranty though.
Click here to see my thread on wrxfanatics.com
http://www.wrxfanatics.com/index.php?showtopic=4951&hl=
There's a pic of it too.
Psydotek is offline   Reply With Quote
Old 02-10-2004, 04:50 PM   #5
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Whoah -- that aint good.
Coati is offline   Reply With Quote
Old 02-17-2004, 04:10 PM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
Courtesy Bump... I think more people need to see this... Just in case... [and to find out what happened with Brindor]
Steering rack problem? WOBBLE WOBBLe WOBBle WOBble WObble Wobble wobble.... baja6620 Baja Forum 10 02-11-2007 03:55 PM
Crank Pulley Wobble rexxman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-23-2001 10:04 PM
Steering wobble after AutoX tmat3 Brakes, Steering & Suspension 5 04-02-2001 09:36 AM
friggen wobblies... dirk.gecko New England Impreza Club Forum -- NESIC 7 01-02-2001 01:04 PM
Weird wheel/tire wobble... Sean Technical Forum Archive 4 06-05-2000 09:12 PM
