#1 |
Member#: 50287
Vehicle:02 WRX silver |
I installed a A/F guage today and i had to add a little wire to the 02sensor.. my question is... will it effect anything if i used a piece of wire that is about 2 inchs long and thincker then the factory wire.. its a small add on but i need to know if that wire will be ok or do i need to change it to a factory size wire... thanks
#2 |
Member#: 29283
Vehicle:2003 Subaru Forester Red |
did the same thing with mine you should be fine
#3 |
Member#: 50287
its about 2 times the size of the factory wire.. are you sure it will be ok.... thanks for the info
#4 |
Member#: 50287
anyone else????? please
#5 | |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
...wait you ran a wire straight to the 02 sensor? why didnt you run it to the ECU? |
#6 |
Member#: 50287
Its to the wire that conects to the ECU.. just outside of the ECU.. i just want to make sure that i wont have any problems do to the larger wire i had to splice in the wiring...
#7 |
Member#: 50287
i didnt think you are suppose to hook anything to your ECU so i used the wire comming out of the ECU to the O2sensor.. was that wrong??? and picture this -------=====------ that is what i meen by adding in a larger wire, will that cause some type of problem????? like resistance problems or something
#8 |
Vehicle:OK Houston we have an Uncle |
Your AF gauge is useless unles you installed a wideband o2 sensor to connect it to.
#9 |
Member#: 13282
Vehicle:2007 FXT WRB SPB Edition |
You should be fine, I've seen much much worse and everything worked ok. As long as everything has a solid connection and doesn't fall out and short you won't have any issues.
Buster http://subaru.awdcars.com |
| Thread Tools | |
| Display Modes | |
| crank/cam sensor HELP PLEASE | 199subaru | Factory 2.0L Turbo Powertrain | 7 | 09-15-2008 04:59 AM |
| EA82T code 11 crank angle sensor help please!!! | iluvdrt | Pre-2002 Factory Turbo Powertrain | 4 | 11-02-2005 05:25 PM |
| 02 sensor help please | JikJak | Factory 2.0L Turbo Powertrain | 4 | 07-23-2004 05:53 PM |
| 02 sensor help please | JikJak | Vancouver Impreza Club Forum -- VIC | 5 | 04-17-2004 06:26 PM |
| 02 sensor question please help | ac_gohan | Normally Aspirated Powertrain | 1 | 02-04-2001 08:59 PM |
