Old 02-18-2004, 09:57 PM   #1
jfandem
Member#: 37747
2003 WRX
Sedona Red
Default Installed new turbo, broke uppipe stud, fixed it, leaks.....help! (LONG)
Ok a while back i installed my upgraded td04, and i had a stock gutted uppipe on there already. When i was loosening one of the rear bolts that hold the turbo to the uppipe, the stud broke right in half. I had no time or way to fix it at the time, so i left that one bolt off there, and was pretty sure it was going to leak too. So, i drive the car, everything is fine until im in like 2nd or 3rd and flooring it, and i hit full boost, the boost guage swings to around 15psi, then back down, then back up again, fluctuating alot. When this happens, i hear a whirring noise, not the normal turbo noise, but like a whining whirring noise, and it also fluctuates with the boost guage needle, louder as the boost goes higher. So, i thought this was a leak, so i bought a uppipe to turbo gasket, and fixed the broken stud by putting a new one in, and made sure everything was perfect. I put it all back together, and during idle and even revving, no sounds, but there were none before either. Then i drive it, noise is still there when i get on it...im starting to think its not a leak, and may be something wrong with this turbo? It is ported and polished, clipped exhaust wheel 10degrees, and a t28 compresser wheel. Help me out, sorry for the long thread
jfandem is offline   Reply With Quote
Old 02-19-2004, 10:09 AM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default Couple of questions...
1) Did you have the stock gutted up-pipe installed prior to this upgrade?
2) Do you notice smoke coming out from the exhaust?
3) Did you properly torque the up-pipe down to the exhaust inlet of turbo?
Check for smoke coming out the exhaust....
Kevin
latinskllz is offline   Reply With Quote
Old 02-19-2004, 12:22 PM   #3
j-speedracer
Member#: 48897
02 WRX
any possible debris off the uppipe getting sucked in the turbo?
j-speedracer is offline   Reply With Quote
Old 02-19-2004, 12:35 PM   #4
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
that's what I was thinking, since the up-pipe was gutted....
Old 02-19-2004, 04:03 PM   #5
jfandem
Member#: 37747
2003 WRX
Sedona Red
Default Re: Couple of questions...
Kevin
1) Yes, ive had this stock gutted uppipe on the car for at least 5k miles prior to this. It was FULLY gutted, and i bought it off somene, and i checked it thouhrouly for anything inside it, it was clean....
2) Smoke comes out of the exhaust only sometimes, maybe when i floor it people tell me it comes out black, but everyones does that...a while back smoke did come out of the exhaust, a bit of white smoke, but that eventually went away...and this was with my stock turbo anyway.
3) Yes i did torque them properly, and used new gasket BUT i didnt use a new gasket when i did the uppipe originally, but yesterday i put a new one in...
Help me out! thanks
Old 02-19-2004, 04:34 PM   #6
WRXtreme02
Member#: 12680
2010 GTi
Sounds like its just the stock ECU controlling the boost, and falling off near redline, PSI going up and down is prob because the turbo wants to boost, but the ECU is trying to tame it down... I say buy a boost controller...
WRXtreme02 is offline   Reply With Quote
Old 02-20-2004, 12:22 AM   #7
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Makes sense if he is running on a stock ECU...what other mods do you have, like a S-AFC etc...?
Old 02-20-2004, 12:30 AM   #8
jfandem
Member#: 37747
2003 WRX
Sedona Red
I am running on the stock ECU yes....and have just turboback (catless) forge BOV, m2 version 2 top mount IC, and thats it. No boost controller or anything.
Old 02-20-2004, 12:35 AM   #9
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default FYI
He is having an exhaust leak!
The sound that you speak of is more a SCREAM then a whirring sound
Get some studs and replace them and put in a new gasket and your done
WRXTuner
www.WRXTuner.com
WRXTuner is offline   Reply With Quote
FS: Brand new Turbo XS UPPIPE $130.00 02-05 wrx onryou MAIC Private Classifieds 4 08-20-2007 07:14 AM
Installing new turbo,injectors,FP,TMIC,Inlet pipe, big MAF in what order to install? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-19-2006 02:16 AM
Have you disputed a fix-it ticket? Help me! hentaipanda Off-Topic 14 03-24-2005 04:37 PM
Have you disputed a fix-it ticket? Help me! hentaipanda Southern California Impreza Club Forum -- SCIC 11 03-23-2005 12:42 PM
Turbo, Downpipe, Uppipe Studs are Horrible... Oo DaRk StAr oO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-21-2003 12:09 AM
