Old 02-22-2004, 09:34 AM   #1
bvl
Member#: 9255
2002 WRX Wagon
Default Dropping the oil pan
Looking at it from the bottom, it appears to me my 2002 WRX oil pan should drop out after removing the fasteners and sliding forward a bit.
Am I correct on this presumption, or will more need to be removed? My only other experience in this area is my Integra (drops out) and my miata (subframe in the way, have to lift engine)
I did some heavy searching last night but did not come up with solid results.
TIA,
- b
bvl is offline   Reply With Quote
Old 02-23-2004, 08:32 AM   #2
bvl
Member#: 9255
2002 WRX Wagon
some views...no replies. BTT
Old 02-26-2004, 02:29 PM   #3
UncleMeat
Member#: 33256
2010 subasuckbox
vomit
Don't know if you still need this, but the oil pan is a bit of a PITA. I took out the exhaust manifold and beat the piss out of it with a rubber mallet and screwdriver (at the seals) and it eventually came out. Once you crack the seal it gets real easy. That factory gasket is TOUGH.
UncleMeat is offline   Reply With Quote
Old 02-26-2004, 10:27 PM   #4
vile
Member#: 32371
'02 t-rex wagon
platinum
i can't seem to find it in the manuel the exact detail on how to remove it, but unclemeat is right.....it's going to be tough to seperate the oil pan from the block. this is because subaru uses a silicon sealer. it also suggest not to pry with a screw driver, instead, cut the seal around the pan
vile is offline   Reply With Quote
Old 02-26-2004, 10:52 PM   #5
UncleMeat
Member#: 33256
2010 subasuckbox
vomit
Well for me I pryed with a screwdriver because my pan was dented and had to be replaced. Guess I should've said that.
Yeah, use a boxcutter or something sharp that will cut in there. Once you get some of it cut you can start to pry gently.
Old 03-18-2004, 12:37 PM   #6
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
How exactly did you get to the bolts behind the oil pan? Looks like you might have to drop the crossmember or something to that extent. I posted this question in another section of the forum and i was told that i would have to jack up the motor. How did you do it?
I drive a WRX wagon is offline   Reply With Quote
Old 03-18-2004, 01:25 PM   #7
UncleMeat
Member#: 33256
2010 subasuckbox
vomit
I used about 4 different swivel adapters and it was a real pain but I got it done. That's the only way to go... getting the bolts back in really stinks, but it can be done without dropping or removing anything else.
Old 03-18-2004, 01:36 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You can unbolt the engine mounts from the crossmember and jack the engine up a bit .
Brian
North Ursalia is offline   Reply With Quote
just dropped in new motor and all the coolant in the oil pan JT's06sti Built Motor Discussion 39 03-01-2009 03:37 PM
How does the oil drain to the oil pan? msm98lw Newbies & FAQs 6 10-29-2005 12:05 AM
How do you separate the oil pan from the block? jasona Normally Aspirated Powertrain 16 10-06-2005 04:54 PM
Whats the thread and pitch for the oil pan plug? BrysImpreza Normally Aspirated Powertrain 0 10-27-2004 06:32 PM
What is the oil pan made of? SFsube Technical Forum Archive 1 09-11-2000 03:19 PM
