Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 02-22-2004, 10:06 PM   #1
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Default Is my ECU dead?!?!
i just did a ej2.2t ecu and harness swap into my 95 impreza 1.8, and i don't have any spark and the output from the ecu to energize the relay doesn't output any power and i hooked up an alarm L.E.D. for a CEL, one side ign and one side i believe is the MIL wire is, and it never flashes. i don't have my dash in, but that shouldn't make a difference right? the ECU is Automatic and the car is Manual, i put ignition power to the wire for a park and nuetral switch then grounded 2 other wires (b9,B10 i believe) for the nuetral safety switch
the only other thing is that i didn't have one of the crank and cam sensors for the legacy so i soildered the impreza 1.8 sensors in should be the same as the legacy, aren't they, minus the shields?
bobturismo is offline   Reply With Quote
Old 02-23-2004, 06:25 PM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
anybody?
Old 02-24-2004, 12:50 AM   #3
BoostdBoxer
Member#: 53163
ouchie can you take it to a local tuner and explain what is wrong or should I say go to a local tuner and tell them what is wrong maybe one that did an engine swap that may have encountered this problem
BoostdBoxer is offline   Reply With Quote
Old 02-24-2004, 04:24 AM   #4
Delicious Tuning
Member#: 1990
Are you getting power to the ECU? It might sounds stupid, but you got to ask these questions? Also is it grounded correctly. There are multiple grounds and if one of them are nto hooked up then there could be a problem there.
Delicious Tuning is offline   Reply With Quote
Old 02-24-2004, 05:06 AM   #5
bobturismo
Member#: 42145
6-4 jockin da bish-
no it doesn't, your right, i know i used to install car audio for a living and i triple checked the power, power is the prob 9 times out of 10, then my friend told me to ground the case of the ecu and that didn't help, but thats how i found out that the ecu wasn't energizing the main/ign relay
Is my alternator dead or is it something else? Jus Blaze Electrical & Lighting 4 09-22-2008 11:09 AM
Is my router dead-dead, or just....mostly...dead sonicblue Off-Topic 10 07-21-2008 01:10 PM
Tuning my WGDC, is my turbo dead? arch4life Open Source Reflashes 14 03-26-2008 04:43 PM
Is my starter dead or is it a bad connection? DoinkMobb Service & Maintenance 13 12-30-2003 08:42 PM
is my amp dead? sybir Car Audio, Video & Security 3 03-28-2002 04:36 AM
