Old 02-23-2004, 07:36 PM   #1
XRayHipp
Member#: 50070
2002 Black Slushbox
2.5 Ounces to Freedom
Question Price for plug change
I'm just wondering if $90 is a fair price to pay someone to change plugs in my car -- plus I'm providing the v-powers.
Sorry if this should be in the noob section -- I don't feel comfortable doing it right now as I don't have any type of magnetic "grabber"
XRayHipp is offline   Reply With Quote
Old 02-23-2004, 07:39 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You don't need magnetic "grabbers" for plugs. It takes about an hour to an hour and a half to do the plugs if it's your first time so $90 is about right as most places charge $65/hour for labor. You could always see if there's someone in your area that is willing to do it with you or do it cheaper.
Calvin
cnk is offline   Reply With Quote
Old 02-24-2004, 12:03 AM   #3
Fubaru
Member#: 6046
'08 Prius
I've changed the plugs in my WRX once and I swore I'd never do it again... I assume it's a similar PITA in your 2.5RS to swap plugs.
If you do it yourself it would help to have a 1" or 2" articulated ratchet extension. Personally I think it's worth $90 to have somebody else do it.
Fubaru is offline   Reply With Quote
Old 02-24-2004, 12:47 AM   #4
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
did them in my L and it took me bout 10 min and cost the price of the spark plugs.... like 16$
xxtwowheelfiendxx is offline   Reply With Quote
Old 02-24-2004, 12:53 AM   #5
silvscorp
Member#: 28480
um..i changed mine and i thought it was a lot easier than I though. I have 02 WRX btw, only need to remove the battery and airbox. Entire process took me 40 mins.
If you take to the dealer then it should be one hour job I assume? Depends on the dealer's rate, average should be around 70-75 an hour.
silvscorp is offline   Reply With Quote
Old 02-24-2004, 12:19 PM   #6
Hayes
Member#: 11808
My Forester 2.5L engine takes me about 45 minutes to change plugs. Remove front part of air intake, two bolts on window washer and move aside and do it. The first time the rubber spark plug boots are very tight and will require a strong hand to twist and pull them loose. Eddie
Hayes is offline   Reply With Quote
Old 02-25-2004, 12:10 AM   #7
mofoporn
Member#: 4766
2001 2.5 RS
BRP
Spark plugs are very easy to do. All you have to do on the drivers side is take the windshield washer fluid resv out. Takes 20min max if that. I say save the $90 and buy beer and stippers!!!
mofoporn is offline   Reply With Quote
Old 02-25-2004, 01:52 PM   #8
scoobydrew06
Member#: 32951
dido
scoobydrew06 is offline   Reply With Quote
Old 02-25-2004, 02:30 PM   #9
gr8-wrx
Member#: 38411
2003 WRX Sedan
2001 Honda CR-V SE
In the WRX, you only needed to remove the battery and airbox? Did you have to use a special extension like the other folks?
gr8-wrx is offline   Reply With Quote
Old 02-25-2004, 02:45 PM   #10
cnk
Member#: 10757
You don't even have to remove the battery. With the right tools, you can just remove the airbox on the passenger side and lift the windshield resevoir out of the way on the driver's side for access. I use a spark plug socket and a 1/2" extension to get the plugs loosened and then I remove the socket wrench and just turn the extension and socket with my hands.
Calvin
$120 a decent price for plugs intsalled? goon54 Newbies & FAQs 16 09-02-2009 06:40 PM
Is $99 a normal price for an oil change by Subaru dealership? undrgroundskat3r Newbies & FAQs 5 03-08-2009 08:20 PM
is $280 a good price for labor on a clutch change bubba03wrx Southern California Impreza Club Forum -- SCIC 18 06-21-2005 01:17 PM
good price for timing belt change? tmaler13 Normally Aspirated Powertrain 6 07-22-2002 10:35 PM
Complest pictorial for Spark Plug change. ChosenWon Normally Aspirated Powertrain 3 07-02-2001 03:41 PM
