Old 03-01-2004, 02:33 PM   #1
persianwrx
Member#: 51976
Default my wrx is about to hit 60k what needs to be done??
My 02 wrx is about to hit 60k what needs to be done specifically to keep it in great shape with out spending a fortune?
persianwrx is offline   Reply With Quote
Old 03-01-2004, 02:49 PM   #2
grindMARC
Member#: 23547
13 Focus ST
Blurple
There's only about 100 threads on that subject.
Check the owners manual or do a search.
grindMARC is offline   Reply With Quote
Old 03-02-2004, 12:41 AM   #3
persianwrx
Member#: 51976
I tried searching but didn't really come up with anything useful
Old 03-02-2004, 08:22 AM   #4
grindMARC
Member#: 23547
13 Focus ST
Blurple
Old 03-02-2004, 06:13 PM   #5
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Originally posted by grindMARC
http://www.allsubaru.com/schedules.html
That only goes up to 30,000 miles.
redobs is offline   Reply With Quote
Old 03-02-2004, 11:35 PM   #6
hawksoob
Member#: 51978
1996 Legacy Outback
Red
my.subaru.com
sign up and register.
They have maintenance intervals up to 120K. After that, just start adding 3000 to what you have. Start over again, basically.
hawksoob is offline   Reply With Quote
Old 03-03-2004, 12:05 AM   #7
regan
Member#: 52744
1999 Outback
61 VW Bug
60000k if all service was done on a regular basis then all that is required is a nd oil chage, tire rotation, and check over.
regan is offline   Reply With Quote
Old 03-03-2004, 12:36 AM   #8
hawksoob
Member#: 51978
1996 Legacy Outback
Red
Here's what my.subaru.com says for my car, anyway. YMMV
Inspect Clutch and hill-holder system
Replace Spark plugs - 2500cc DOHC
Replace Spark plugs - 2500cc SOHC
Replace Spark plugs - 2200cc
Perform Replace fuel filter and inspect fuel system, hoses and connections
Replace Camshaft drive belt
Replace Drive belt(s) [Except camshaft]
Inspect Steering and suspension
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Brake linings and drums
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Replace Brake fluid
Inspect Automatic transmission fluid
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Replace Air cleaner element
Perform Replace engine coolant and inspect cooling system, hoses and connections
Replace Engine oil filter
Replace Engine oil
Newbie About to Hit 60k miles R&C_rallySS Service & Maintenance 8 09-24-2008 06:41 PM
What needs to be done to fit brembos on 07 WRX wheels? gopsu Newbies & FAQs 1 08-22-2007 11:04 PM
Anyone know what need to be done to export a car to the States? H5N1 Vancouver Impreza Club Forum -- VIC 0 01-08-2006 03:23 AM
Sometimes this is what needs to be done Impreza01 Off-Topic 34 01-29-2004 10:03 PM
My dad is about to buy an XT. need some help figguring out what would be a good deal. DoctorNick Forester Forum 10 08-05-2003 04:56 PM
