Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 05-09-2000, 08:45 AM   #1
RacerinLSL
Member#: 1174
2011 Subaru WRX
Exclamation Help Quick!!
Hey guys,
This morning the top half of my clutch pedal went dead. The clutch is still fully engaging and disengaging, but all on the bottom few inches of peddle. The peddle is literally halfway to the floor right now. I can pull it up with my toe, but as soon as I depress it, it does not come all the way back up again. Clutch fluid is fine. What gives???
RacerinLSL is offline
Old 05-09-2000, 08:52 AM   #2
newscooby
Member#: 995
2000 MkIV GTi&23 LSV
Red cars PWN me
Post
Check to see if your slave cylinder is leaking. I have the EXACT same problem with my All-Trac Turbo and it seems the slave cylinder has developed a leak and can't build enough pressure to return the pedal completely. Nothing to worry about if the clutch still disengages fine. You just have to keep adding fluid.
Mike
newscooby is offline
Old 05-09-2000, 08:53 AM   #3
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
It sounds like the clutch master cylinder has or is failing.
rao is offline
Old 05-09-2000, 09:23 AM   #4
RacerinLSL
Member#: 1174
2011 Subaru WRX
Exclamation
OK now the pedal is back, what is going on?
If it IS the master cyl. would the pedal suddenly be back?
Old 05-09-2000, 09:27 AM   #5
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
Because it hasen't totally failed yet. If this keeps happening, then it is only a matter of time before the cylinder will stop working.
rao is offline
Old 05-09-2000, 09:44 AM   #6
RacerinLSL
Member#: 1174
2011 Subaru WRX
Exclamation
Thanks for your help.
Just called local dealer, can't get in til tommorrow and they cn't give me a time "drop it off in the morning and we'l look at it." Damn service departments!!
Old 05-10-2000, 12:06 AM   #7
RacerinLSL
Member#: 1174
2011 Subaru WRX
Talking
Got to take my car in at 12:00 noon.
Just heard from the dealer,
air pockets in hydrolic fluid was causing the problem. No biggie. How did the damn air pockets get there in the first place. No work has ever been done on my car.?? Oh well, it's not the master cylinder at least.
Old 05-09-2000, 02:25 PM   #8
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Lightbulb
That's the same thing that happened to my car a while back, and it's been happening again lately. The first time was about 8 months ago. The dealership did the usual "give it to us and we'll see if we can make it happen" kind of thing. I ended up getting a new flywheel, pressure plate, and clutch disk all under warranty. But I don't think that was the real problem. I thought that air in the clutch hydraulic system made sense, but what do I know? It seems to happen the most on cool, humid mornings. I have to pump the pedal about 8 to 10 times to get it back to normal, then it's fine the rest of the day.
Does anyone know the proper way to bleed the clutch? I don't feel like playing with the Subaru goofballs again.
Travis R is offline
Old 05-09-2000, 02:27 PM   #9
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
It's not that hard to bleed the clutch, but you wil need help. The clutch line is only about 15" ling, but it forms a semi-circle. You bleed it just like you would bleed a brake line. Open the fitting and attach a tube to the fitting and run it to a container. Add fluid depress the clutch, close the fitting, repeat until no air comes out of the fitting.
rao is offline
Old 05-10-2000, 07:57 AM   #10
Travis R
Member#: 153
'07 Mazda CX-7, '91
Post
Thanks rao, I figured it would be pretty similar to bleeding the brakes. But when you push the clutch pedal down, it pushes against the clutch lever and releases the clutch, then when you open the bleed valve, the clutch lever pushes the slave cylinder back in. You now have your clutch engaged with your foot to the floor. I'm concerned that the clutch master cylinder will stay down and you will be SOL. I guess it comes down to the design of the clutch master cylinder. If there is an internal return spring it will probably come back on it's own and take another "gulp" of fluid from the reservoir to allow you to continue bleeding the system.
Anybody have an exploded diagram of the '99 RS clutch master cylinder?
Travis
(with off-and-on clutch pedal issues)
Travis R is offline
Old 05-10-2000, 08:21 AM   #11
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
You can always use a vacuum system (you can get them from super cheap to real expensive) if you are concerned about that - though I don't think you will have that problem.
rao is offline
HTML code is On
('93-'01) Need HELP quick please... kaos200 Impreza Forum 2 04-21-2001 08:22 AM
Help! Quick Question MagicMT Bay Area Impreza Club Forum -- BAIC 3 04-17-2001 09:35 AM
('93-'01) car is running rough!....help, quick! nav Impreza Forum 10 04-14-2001 08:20 PM
('93-'01) Dry Crank? help quick! Ethan Impreza Forum 5 04-11-2001 07:16 PM
Please Help!!! Quick! adamsrs Normally Aspirated Powertrain 8 03-15-2001 04:25 PM
