Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 04-20-2004, 01:15 AM   #1
Ahzlon
Member#: 45216
2005 Baja Turbo
Question Closed loop - open loop switching
OK.. i hope this doesn't sound confuseing... I had my scanner hooked up this afternoon when i was driving down the road... i noticed that when ever i got on the gas or got completely off the gas the car went to open loop (dri) which i'm guessing meaning open loop while driving. but if i just get on the throttle a lil it stays closed loop... i have checked my plug wires & vacume fittings *have a vac gage in the car* and i'm still comming up blank... is this normal for our cars???
Only engine mod
Borla Heads
Thanks peoples
Jonathan
Ahzlon is offline   Reply With Quote
Old 04-20-2004, 01:18 AM   #2
speedracer47
Member#: 2765
Mine does the same thing. I'm assuming it's normal.
-Dan
speedracer47 is offline   Reply With Quote
Old 04-20-2004, 08:26 AM   #3
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Wink
Normal......think of it this way.....closed loop is when the O2 sensor is feeding info to the computer.......open loop is when the O2 sensor is not feeding info to the computer.
When you first start your machine in the am.....until it warms to a specified temp.....it runs open loop....once there the computer gets info from the O2 sensor (and others) to manage your fuel and keep it at about 14.7/1 (air/fuel).
Now what happens when you mash the throttle......it wants to go full rich and disregard the O2 sensor.....ergo back to open loop.
OK don't flame me for not providing all the other minutia about how the system works.......just providing a simplistic view of what happens.
Hope this helped..........
lakepop is offline   Reply With Quote
Old 04-20-2004, 11:12 AM   #4
Ahzlon
Member#: 45216
2005 Baja Turbo
yep.. the information helped ... cause a few days ago i got a flashing cell *happned to be dirty contacts on the coil pack *.. just never really saw it switching before then.. and just wanted to make sure nothing else was F.U.B.A.R.
thanks again LakePop and SpeedRacer
Ahzlon
Jonathan
Old 04-22-2004, 12:15 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Originally posted by lakepop
14.7/1 (fuel/air).
air/fuel
White 2.5rs is offline   Reply With Quote
Old 04-22-2004, 04:14 PM   #6
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Unhappy
OOps...my bad........corrected to 14.7 (air/fuel).
Thanks for picking that up
What does closed loop/open loop mean? FuJi K Newbies & FAQs 8 08-12-2014 08:59 PM
how the ecu works...closed loop...open loop? IllNastyImpreza Engine Management & Tuning 13 11-26-2005 05:06 PM
Closed loop / open loop controlled by throttle position sensor? boxxxer Engine Management & Tuning 9 05-16-2005 12:12 PM
Can anyone explain the 04-05 closed loop/open loop lean cond.? boxxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2005 09:00 PM
closed loop/open loop questions Rickyh Engine Management & Tuning 2 02-27-2004 06:06 PM
