Old 04-22-2004, 06:37 PM   #1
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Default Solution to RPM "surge" under boost?
I'll do my best to explain this:
Under heavy throttle (not necessarily WOT), it's very obvious that when I shift when still making boost, I get RPM surge.
In other words, I'm on the gas making boost, I get off the throttle to go to shift, and even though I'm off the gas, as soon as I clutch in, my RPMs will rise a few hundred or so rather than dropping immediately.
The problem doesn't exist when shifting when not making boost (or when only boosting a few psi or so), so my theory is that the factory recirculating valve just can't "blow off" the extra boost quick enough between shifts.
Its become very annoying, even more so because revs in my S2000 drop so fast between shifts that you have to shift like mad to keep up.
I certainly don't expect the WRX to respond in the same manner as the S2000, but I'm wondering if there is a solution for this "problem" of rising revs between shifts when under boost.
Has anyone noticed with a fully or semi-atmospheric BOV that this problem is alleviated? I'd be curious to find out...
Although I'm not really interested in a BOV due to the problems it causes with running rich between shifts, I'm wondering if I might learn to live with it to solve my other issue.
Looking forward to any suggestions...
heffergm is offline   Reply With Quote
Old 04-23-2004, 05:34 AM   #2
file_id
Member#: 28197
2003 WRX w/ VF34
Known subaru quirk. Try letting off the gas pedal earlier then push in the clutch.
file_id is offline   Reply With Quote
Old 04-23-2004, 08:43 AM   #3
mouserWRX
Member#: 48960
2006 TL
Anthracite
Yep, I have found that if you let off the gas for about a second before depressing the clutch, you're fine. Otherwise, just live with it, it's not that bad
mouserWRX is offline   Reply With Quote
Old 04-23-2004, 08:48 AM   #4
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Well, I agree, you're right... letting up on the throttle for what I'd consider an extended period of time (enough for the boost to drop) solves the problem.
What I'm curious about, however, is whether running a BOV that vents at least partially to atmosphere has any effect on the problem (either making it better, worse, or not changing it at all).
Anyone running an aftermarket BOV notice a difference?
Old 04-23-2004, 10:04 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i noticed a slight difference for the better when switching to a 100% VTA BOV. still occurs to some extent though.
the extra fuel helps prevent shift knock!
ken
Old 04-23-2004, 11:54 AM   #6
Aegon
Member#: 42435
I'm VTA and I will still surge if I don't let off early.
When it does surge I'll take my time on the shift and everything works out great.
Aegon is offline   Reply With Quote
Old 04-23-2004, 01:31 PM   #7
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
I have heard that it does this to burn off extra fuel in between shifts here ...and a reflash could help. I have the same problem and I have a APS bov...a hybrid valve that recircs and VTA. One thing I notice is when the boost is low enough to recirc and I shift I do get the RPM spike. When I get enough boost that the bov will VTA the car will want to after fire instead of RPM spike.
edit: maybe not with a reflash...I think I read that wrong.
Turbo9000 is offline   Reply With Quote
Old 04-23-2004, 01:34 PM   #8
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Interesting. In that case, perhaps some folks with a Cobb AECU (stage 1 or 2) would chime in so we could see if that helped at all.
Old 04-23-2004, 01:41 PM   #9
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Replace your heavy stock flywheel whith an Exedy or some other significantly lighter one.
I don't think that the cable throttle models rev for emissions. I wouldn't think that is possible without throttle by wire.
mbiker97 is offline   Reply With Quote
Old 04-23-2004, 01:51 PM   #10
Aegon
Member#: 42435
Flywheel weight would tend to carry momentum, not to add momentum. The only thing that will make revs rise in this scenario is fuel+air. A lighter flywheel will simply rev higher!
Old 04-23-2004, 01:57 PM   #11
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
I have a Cobb stage two and don't notice any difference. I think it is more a matter of driving style than mechanical problems.
PKer is offline   Reply With Quote
Old 04-23-2004, 02:00 PM   #12
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Well that's my thought (the mass part anyway). Since the flywheel is being accelerated by the engine, when you release the clutch only the pistons/rods/etc. is acting on the flywheel to deccelerate it. However since there is less mass in a lighter flywheel and the mass of the rest of the engine stays the same the flywheel should deccelerate faster.
Or disregard what I'm thinking because I haven't had physics since I graduated from college.
Old 04-23-2004, 02:15 PM   #13
Aegon
Member#: 42435
The flywheel will drop revs faster, just as it will pick revs up faster. The amount of time between | clutch in -> revs gain -> revs drop to RPMs at clutch in | will be the same for both flywheels, but the lighter one will hit a higher RPM.
Old 04-23-2004, 04:32 PM   #14
TheJonesBoy
Member#: 55779
2004 WRX Wagon
WR Blue
Flywheel mass and rev limit are 2 separate things. Lighter flys in general will allow the engine to rev quicker, slow faster, screw up idle and engine balance, and accelerate quicker. Your rev limit is decided by reciprocating mass (piston + con rod mass, valve + lifter mass) and valve springs.
That little blip you are trying to get rid of is usually seen in fly-by-wire cars for emissions. Cable linkage cars like ours are not immune, as the idle stabilizer valve may open to allow a little air past the butterfly. I am actually trying to track this down too, as it tics me off immensely.
TheJonesBoy is offline   Reply With Quote
Old 04-23-2004, 05:02 PM   #15
Aegon
Member#: 42435
All this means is that given the same amount of energy the lighter flywheel will spin faster. I'm not suggesting that the redline will be increased or anything along those lines.
Old 04-24-2004, 04:02 AM   #16
Hey_its_Cole
Member#: 55305
MIne surges like everyone else but doesnt seem to make a bit of difference on slow shifts or fast shifts. Maybe I just shift differnt or just don't notice but I dont see how it makes shifting smoothly a problem. I know it doesnt for me. I think most turbo cars behave like this.
Hey_its_Cole is offline   Reply With Quote
Hesitation at 5k rpms under boost chuckrfish Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-26-2010 11:16 AM
Dead spot under boost, near 4k RPM? slates74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-20-2009 01:26 AM
Help - Weird temporary CEL under boost and at high rpm. gling Open Source Reflashes 9 06-07-2009 06:51 PM
Just returned car to stock, LOUD annoying squealing sound under boost! PhastEddie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-17-2008 09:23 PM
High pitched wistle at high RPM when under boost. roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-15-2003 12:22 PM
