Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-25-2004, 04:11 AM   #1
Oldalfaguy
Member#: 45091
2004 STI
Silver (Stealth)
Default STI and A stock. Now what do I do?
So I went out and won my first Novice AutoX (Dammit!). Now I'm in A stock (just read the rulebook, yawn) and don't have a clue as to what to do about understeer. I know about tire pressures and alignment (going to go to -1.5 fr and -1.0 rear, thoughts?) but is there anything else I can do to get the understeer under control? I know that I can change the front roll bar but not the rear but I don't know if that will do anything for the car. STU isn't an option right now as I don't have the moola.
Discuss amongst yourselves...
John
Oldalfaguy is offline   Reply With Quote
Old 04-25-2004, 09:22 AM   #2
makofoto
Member#: 25243
2006 Legacy Outback
Lots of applicable threads below .... and in the 2.5 Forum ... I believe the JDM STI has a thicker from sway bar ... they put a thinner one on for the US since they figure we can't drive ...
makofoto is offline   Reply With Quote
Old 04-25-2004, 05:33 PM   #3
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Nope they use to put a thinner one in the jdm sti now they put the same as the USDM sti.
Bigger front sway bar will reduce ultimate front end grip but will make the car transfer better and keep a better camber curve.
Shocks can help alot if you get them valved right, but since your a novice autoxer what will help most is to autox more.
afpdl is offline   Reply With Quote
Old 04-25-2004, 06:52 PM   #4
Redneck Ricer
Member#: 21458
2011 Jeep
Smurf Blue
tires, tires, tires, nice sticky ones
in A stock you can run r compounds, something to consider.... but.. since you are tlaking about money (or lack there of) it may not be good. most likely you will need second set of wheels, then tires, and looking at $1500 or so..
p-rex
Redneck Ricer is offline   Reply With Quote
Old 04-25-2004, 07:29 PM   #5
Watkinsm3
Member#: 51740
2004 STi A-Stock #24
Same as my Coffee : Black
I don't agree with this...
-Matt
Watkinsm3 is offline   Reply With Quote
Old 04-25-2004, 08:40 PM   #6
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
-Matt
Pretty sure it does on an ideal chassy but since we lose camber with body roll its a bit tricky to find the ideal size bar.
Old 04-26-2004, 09:18 AM   #7
Watkinsm3
Member#: 51740
There ya go!
It may not be fun... it may not be cheap...
Test... test... test...
Or you could just wait for someone else to do the testing and hope A) they'll share the info B) the info they share is accurate.
-Matt
Old 04-26-2004, 10:26 AM   #8
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
Slow in, fast out. It is possible you're driving the car just right at one of your first events, but that doesn't seem to be usual in autocrossing. First, get a good alignment. Then work on driving. If you want to spend some money on the car, that's fine, but realize that you'll get more time from working on the driver.
I just did an autocross and rode in two other STis (who both ran novice last year). Their biggest problem was going too fast in the corners, leading to various degrees of scrubbing and pushing, which means they can't get back on the throttle coming out (they also didn't unwind and back off). I think corner exit is our car's huge advantage over the others, and if you're going too fast in the corner, you just push out on the exit which means you can't get on the throttle. This isn't the car, in my opinion -- heck, my loosy goosy Miata would do it if you went into a tight corner too fast. Number two for them would be looking ahead -- that cuts down on extrenuous steering inputs and exiting a corner pointing in the wrong direction.
I'm trying to be helpful. I found my stock STi with a good alignment to be pretty nice. It didn't rotate, but it did nice drifts under power. The only time I recall it plowing was when the driver (me) screwed up and didn't slow down enough for the corner. Amazing how much times drop when you can go just slow enough in the slow parts and fast in the fast parts.
Regarding alignment, do some searches. Didn't some of the national guys in WRXs run 0 toe front and some toe out in rear to help it rotate? Max front camber -- mine only made it to -1.2 stock. Obviously max caster.
WRX_Mundi is offline   Reply With Quote
Old 04-26-2004, 10:42 AM   #9
jmott
Member#: 6713
2007 Prius
brown
camber loss due to body roll:
as the wheels move up in the wheel wells, they get MORE negative camber.
which is what happens to the outside tire
which is what you want, yes?
so why is there loss of negative camber due to body roll?
jmott is offline   Reply With Quote
Old 04-26-2004, 10:44 AM   #10
Watkinsm3
Member#: 51740
Not sure I could have said it better...
As for the stock alignment... can we change caster on a stock STi suspension? I was under the impression that it was not adjustable.
-Matt (Still a scooby-noob)
Old 04-26-2004, 11:05 AM   #11
Watkinsm3
Member#: 51740
with the strut style suspension the amount of camber gain through compression is so small compared to roll over due to body motion. This is obvious from tire wear (i just corded two victoracers up front this weekend)... why? they corded on the front and the VERY outside edge was what went (about a half inch from the line that sperates the sidewall from the tread. The insides are near full tread. So the concept behind it is to help keep the tire flat in the corners with the limited negative camber gain (this ain't no double wish bone!!!). How do you do that? reduce body roll. How do you reduce body roll up front in stock? Massive stiffening of the front rollbar. Test different settings till you find the optimal balance between stiffness and contact patch.
If you get it right... the car should loosen up on turn in... exactly where it needs it. I'm still testing these things but I believe the theory sound. I believe that some of the FWD stock tuning techniques (such as a smaller front bar) should NOT be used with the STi. The vehicle should be treated as a strut equiped RWD car for setup purposes.
Adjustable front bar should be on the car next week... combined with an alignment this week (with weekend testing in between). We shall see... I'll have good benchmark drivers both weekends to help figure if an advantage was achieved. Then, of course, DC at the end of may.
-Matt
Old 04-26-2004, 11:07 AM   #12
skuttledude
Member#: 738
2008 Lexus IS-F
Ducati Monster 800
Perfectly said.
I found the plowing to be true this past Saturday on a fairly slow AutoX course with sweping 180degree turns. Lots of fun. Times kept coming down as I was trying to get in the corners SLOWER and get on the gas little earlier and full power.
What really helped me was having an experienced Subaru RS owner show me this in my own car. He killed my time 2 months ago as he drove it way faster than me but really showed me the slow in fast out thing. (IMHO, is very hard to control as I want to go in hotter)
Suggestion: full rear DCCD lock helped for me. (weather was 70 degrees and dry)
Rally On,
Davis
skuttledude is offline   Reply With Quote
Old 04-26-2004, 12:22 PM   #13
jmott
Member#: 6713
2007 Prius
brown
gotcha
would be interesting to do some testing to see at what point more front roll stiffness starts to hurt grip more than help.
Im planning on getting that "geez" device so I can do stuff like that with my new toy.
-Matt
Old 04-26-2004, 12:34 PM   #14
kwh29
Member#: 22100
It appears that it's not possible to get a big enough front bar in _stock_. I am still considering having a HUGE (like 30mm!) bar custom made just to find out for certain.
--Kevin H.
kwh29 is offline   Reply With Quote
Old 04-26-2004, 12:47 PM   #15
makofoto
Member#: 25243
2006 Legacy Outback
The Hotchkis bar is 1 inch ... 25.4 mm ... but hollow ... so equal to more like 23 mm. It helps ... but is no substitute for stiffer springs/coil overs ...
Old 04-26-2004, 12:59 PM   #16
MonoSki
Member#: 9377
1a- Don't forget this is supposed to be fun
1b- Evolution Driving School - or something like it
2- Race tires
3- Alignment
4- Shocks
5- Bigger front bar
MonoSki is offline   Reply With Quote
Old 04-26-2004, 01:09 PM   #17
FSelekler
Member#: 41410
Atlas Gray
-Matt
Yep, I am with Matt on this. We have done some testing with graphed results if you are interested:
http://www.selgp.com/sti_modifications.htm
FSelekler is offline   Reply With Quote
Old 04-26-2004, 01:13 PM   #18
Watkinsm3
Member#: 51740
Ah... but without the springs/coil overs option in A-Stock we're left with one lonely solution... front bar please!
As for the bar I'm experimenting with? Its BIG... Its adjustable...
-Matt
Old 04-26-2004, 01:22 PM   #19
MonoSki
Member#: 9377
-Matt
Bigger front bar reduces steady state grip but increases transitional grip. most autox's these days are all about transitions. what you make up there is more than you might loose on the few sweepers.
better damped shocks will help on the sti as it is underdamped to beging with
Old 04-26-2004, 01:23 PM   #20
Watkinsm3
Member#: 51740
You don't happen to have the average/mean G loads for those turns do you? Somewhat unimportant since the raw times tell a good deal but, average constant loads are tell a great story compared to peak loads.
Good and interesting info!
-Matt
Old 04-26-2004, 01:28 PM   #21
Watkinsm3
Member#: 51740
An your data is where? I seriously hope this is not just a "bigger front bar induces understeer" generalization. Check out FSelekler's link when you get a chance... shocking!
NOTHING... beats real world testing (with a good driver in a consistent eviroment... blah, blah, blah). BUT... if you still believe you're right you are MORE than welcome to run this other setup in Topeka... I won't stop you... in fact, I only encourage you to!
-Matt
Old 04-26-2004, 02:20 PM   #22
FSelekler
Member#: 41410
Atlas Gray
-Matt
LOL, amazing you are the first one to notice and ask for that
Yes, we have that data, but we did not publish it at our site as we have to protect some part of the data that we use internally. It is just too easy for other vendors to grab data and run with it
As you stated, it does not make much difference from the end result perspective, but it is the kind of data we actually need to do development for various combination of products.
Old 04-26-2004, 02:41 PM   #23
Watkinsm3
Member#: 51740
Ah! Makes sense... I just put 2 & 2 together and connected that page with the rest of the site! You guys have some good info in there. I was looking over your info when I first got my STi about 4+ months ago.
-Matt
Old 04-26-2004, 02:54 PM   #24
FSelekler
Member#: 41410
Atlas Gray
Thank you Matt, I appreciate
Old 04-26-2004, 03:30 PM   #25
jmott
Member#: 6713
2007 Prius
brown
what data logging tool did you use? do you reccomend it?
Running a crazy tune right now. What should I do? WrxRick AccessPort 8 06-18-2007 05:16 PM
o man, now what did i do BlowDro Newbies & FAQs 36 02-16-2007 04:50 PM
There are no mods in here right now, what can we do?? rice h8r Off-Topic 23 01-19-2007 06:08 AM
Finally got a website...now what the hell do I do?! STR8OUT Off-Topic 45 10-14-2004 01:07 PM
