Old 05-11-2004, 10:59 AM   #1
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
Question Wilwood 4 pot vs Subaru 4 pot
How do those 2 calipers compare for track use? Availability of pads? I already have the Wilwoods but have never tried the Subaru.
Other calipers recommended that fit under 16 inch mags?
Jaz
Jaz_rs is offline   Reply With Quote
Old 05-11-2004, 11:04 AM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
this was covered in depth a week ago.. and a week before that, and a month before that... in other words, everything you may wish to know can be found by searching.
Safir is offline   Reply With Quote
Old 05-11-2004, 12:06 PM   #3
SPIDEYWrX
Member#: 36109
Default Re: Wilwood 4 pot vs Subaru 4 pot
Jaz
The subarus don't fit under 16 inch wheels...
There is seriously a tonne of info out there... check out the search.
SPIDEYWrX is offline   Reply With Quote
Old 05-11-2004, 12:09 PM   #4
Jaz_rs
Member#: 60800
00 Impreza RS
BRP
Yes, seen.
The Brembo 4 pot won't fit under 16 inch wheels, but the Subaru 4 pot will.
Old 05-11-2004, 12:40 PM   #5
SPIDEYWrX
Member#: 36109
Yes, seen.
Maybe under the RS wheels, 16x7.0 with proper offset, but not stock wrx wheels
Old 05-11-2004, 12:43 PM   #6
Safir
Member#: 3873
. Paradise is
it will with a 3mm spacer - as you said there is a ton of info out there, maybe you should read it too?
Old 05-11-2004, 12:44 PM   #7
SPIDEYWrX
Member#: 36109
maybe I should.. maybe you should be less of a dick too?
Old 05-11-2004, 01:28 PM   #8
newscooby
Member#: 995
2000 MkIV GTi&23 LSV
Red cars PWN me
To settle this:
Yes, it's a WELL known fact that the suby 4 pots fit under the GC chassis RS wheels. The ones that are 16x7. I've got a set that are shod with my race rubber.
edit:
To answer the original question, I can only answer from the perspective of the Suby 4 pots. Mine have been thru 3 track days and have held up extremely well lap after lap. Even at Roebling Road, where the end of the front straight I was seeing 120+
The brakes never even hinted at fade after 12-15 minute sessions.
For a bit of empirical data, all HPDEs have been run with Porterfield R4S pads.
mike
newscooby is offline   Reply With Quote
Old 05-11-2004, 01:33 PM   #9
Safir
Member#: 3873
. Paradise is
Originally posted by newscooby
To settle this:
while I agree 100%.
they will also fit with the stock WRX wheels and a spacer.
http://freebmw.net/safir/NASIOC/4pot3mmspacer%20002.jpg
Old 05-11-2004, 03:21 PM   #10
newscooby
Member#: 995
Red cars PWN me
while I agree 100%.
Yeah Joe, I wasn't trying to dispute you. I was just trying to tell the Spider-guy that it's been very established that the older RS wheels fit fine. I remember the discussion we had with Clayton about this about a year and a half ago.
mike
Old 05-11-2004, 03:32 PM   #11
SPIDEYWrX
Member#: 36109
mike
well isn't that what I said? under RS wheels?
Old 05-11-2004, 05:39 PM   #12
Safir
Member#: 3873
. Paradise is
mike
understood - you were not 100% clear so i was just being sure.
Old 05-11-2004, 06:43 PM   #13
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
The Subie 4-pots will fit under 16" SSR's also
Old 05-12-2004, 12:42 AM   #14
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
You got a pic of this?
Not that I ddoubt you a sec, but SSRs + 4pots = eye candy.
ss
subysouth is offline   Reply With Quote
Old 05-12-2004, 08:24 AM   #15
Uncle Scotty
OK buy Nates beans
ss
Sadly, no.....
I was doubly assured by Luke that it is a match made in heaven....as I'm considering buying the 16" SSR's to match my 17's
See: http://forums.nasioc.com/forums/show...hreadid=552651
Old 05-12-2004, 03:02 PM   #16
StopTech
Vendor
Member#: 13134
2002 WRX Wagon
Seal Gray Brake Dust
I can assure you that the Subaru 4-Pots are an all-around better part than the Wilwoods. The only thing the Subies give up is weight. IMO, the Subaru caliper is superior.
Tim
www.stoptech.com
StopTech is offline   Reply With Quote
Old 05-12-2004, 04:00 PM   #17
Safir
Member#: 3873
. Paradise is
Tim
www.stoptech.com
Based upon my experience with both setups, i have to disagree. I am interested in hearing what brought you to this conclusion.
Old 05-12-2004, 05:00 PM   #18
StopTech
Vendor
Member#: 13134
2002 WRX Wagon
It's the stiffness of the the Subaru caliper that does it for me. I prefer the firmer pedal that the Subaru caliper provides. I also like the fact that the Subaru caliper doesn't have an external crossover tube.
Old 05-12-2004, 05:54 PM   #19
Safir
Member#: 3873
. Paradise is
the wilwood dynalite does not have an external crossover, it is crossed over internally. I have seen no evidence that the subaru caliper is in fact stiffer (i presume you mean flexes less under load) or, more specifically, the wilwood is not stiff, but am open to any evidence you have. Pedal feel is a preference, as I have detected no difference in feel driving both setups. i have noticed that the addition of the 2-piston rear wilwoods to the 4 piston front setup did effect pedal travel quite a bit, if this is what you mean by having a firm, or soft pedal. I have not driven a car with both front and rear FHI setups.
This is, of course, a topic of personal preference, and some heated debate. I am more than willing to hear arguments from the other side and any evidence to prove what setup is better.
Old 05-12-2004, 06:31 PM   #20
StopTech
Vendor
Member#: 13134
2002 WRX Wagon
I have been wanting to get my Subaru 4-Pots on our flex rig for a while now, perhaps this is the kick in the butt that I needed. And my apologies about the Dynalite, for some reason I was thinking of the Dynalite II which does have a cross-over tube but is also not used in any Subaru kits as far as I know.
Old 05-12-2004, 08:39 PM   #21
Safir
Member#: 3873
. Paradise is
I would love to see the results of this
what i would realy love to see is pictures of the calipers flexing as pressure is applied
Old 05-12-2004, 09:12 PM   #22
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
4 pots fit under legacy gt rims. they are 16s.
also, what is a good brake upgrade for the rear if doing the 4 pots for the front?
I have a 95 legacy and it has 1 piston brakes front and back. I was thinking the h6 upgrade but i cant find the rear mounts, but i can find all of the wrx parts to do that.
subiekid is offline   Reply With Quote
Old 05-12-2004, 09:42 PM   #23
StopTech
Vendor
Member#: 13134
2002 WRX Wagon
Maybe I'll bust out the digicam. The first thing I need to do is find a rebuild kit for my four pots and get them back together. I've been thinking about doing a nice little "22B" number on them with our special two-part epoxy finish that we use.
Old 05-12-2004, 09:52 PM   #24
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Kid the 4pots dont fit under the Legacy GT wheels without spacers.
You must have the single pots on the 260mm rotors. Lemme do some math and find out how the 4pots would affect your stock bias to begin with.
I dont know what you mean by mounts, but to get the "H6" rears on you car you need to replace all the rear setup - calipers, caliper brackets, rotors, pads and hardware.
ss
Old 05-12-2004, 11:56 PM   #25
Uncle Scotty
OK buy Nates beans
The Nissan Z32 rebuild kit should work just fine
STI brembos VS Subaru 4 pots/2 pots Sypher Brakes, Steering & Suspension 6 05-17-2006 05:22 PM
wilwood 6 pots vs brembo 4 pots? and some other q's mrb16a Brakes, Steering & Suspension 5 08-16-2005 11:07 AM
Legacy H6 rear upgrade vs. Subaru 4 pots no_rex_yet Brakes, Steering & Suspension 21 01-16-2004 03:05 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
perrin wilwood vs. subaru 4-pot? subaruracerx Brakes, Steering & Suspension 6 09-16-2002 12:36 PM
