Old 06-10-2004, 02:21 AM   #1
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
Question Launching?
I was wondering if you guys had some advice I would like to learn a little better how to launch my car in the 1/4 mile. I have a '04 WRX with a stage 2 cobb. I have not ran it hard yet because it just now has 1500 miles. but I am going to start running it hard on some tracks. What should I focus on when I launch to get a good 0-60 and 1/4 mile time. Things like RPM's when launching how you let out on clutch to allow the car to get the most out of the take off.
STUDAndring is offline   Reply With Quote
Old 06-10-2004, 09:59 AM   #2
madSTI
Member#: 38961
2004 wrx STI
JAVA BLACK PEARL
SEARCH is the magic word. use it
don't take this the wrong way, i'm being nice, compared to some of the others around here
madSTI is offline   Reply With Quote
Old 06-10-2004, 02:15 PM   #3
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
1) pulse/blip revs btw 4-7k
2) on 2nd yellow keep your pedal to the floor
3) let off on the clutch, do not slip it, do not dump it...
3a) imagined you just stepped in dog crap, thats how your foot should react BUT do not let the clutch go back on its own weight
that is THE best method, my creation & no one else may take credit for it
<------------there is proof 1, proof 2 is that i just had my tranny checked out & it is in PERFECT condition, but my tranny fluid on the other hand needs to be replaced badly...
that is all
Hassassin is offline   Reply With Quote
Old 06-10-2004, 02:40 PM   #4
STI_Jaguar
Member#: 54498
2005 Impreza WRX Sti
blue/gold
I also would like to know more. I did a search and the questions I needed was not addressed.
I am wondering what RPMs I should be in 1st gear? 2nd? 3rd? 4th?
A guy I know says that he hits 6500-7000 on all gears (this was before I broke my car in so I wasn't really paying attention)
When I tried it myself I felt that there was no way to hit 7K in first or second.
Would you still get good results going up to 4-5K in first gear and second before shifting, or am I not maxing out using this technique?
STI_Jaguar is offline   Reply With Quote
Old 06-10-2004, 03:00 PM   #5
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
you need to hit 6 at least I think. If you have a ECU upgrade you should hit 7 then shift because you are at max power between 5 and 7 after ECU upgrade.
Old 06-10-2004, 04:40 PM   #6
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
that is all
Beware however..as I finally got the launch down pat and on my last run of the night it felt so good as it hooked off the line then BAM BAM I broke one half shaft and the other hub.
I did this on Neo Gens too so it wasn't like I was using a sticky slick. That and it was hot as all hell with a lousy barometer so I shouldn't even have been making decent power either
2002WRXSTi is offline   Reply With Quote
Old 05-06-2005, 11:08 PM   #7
AudiTTkiller
Member#: 72875
2004 W R X
platinum silver metallic
if your making 400 whp then you should expect soemthing like that to happen
AudiTTkiller is offline   Reply With Quote
Old 05-06-2005, 11:17 PM   #8
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Happened when I was making under 300whp. Engine and ECU were stock at the time.
Old 06-10-2004, 05:03 PM   #9
thesmokingman
Member#: 17751
WRX heads stop breathing after 6000 ish rpms. Shift sooner.
thesmokingman is offline   Reply With Quote
Old 06-10-2004, 07:11 PM   #10
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
you have no idea what you're talking about, shift at 6500-7k every gear
Old 06-10-2004, 07:46 PM   #11
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
seconded.
bezerk is offline   Reply With Quote
Old 06-10-2004, 08:31 PM   #12
2002WRXSTi
Member#: 58647
02 Exedy Carbon
Question
I dunno...seems if I shift at lower RPM I am going faster. If I shift at 7000 I am in the 13's but if I shift at 6500 I got 12.7's. The last run I was gonna try shifting at 6200 or so but I broke both my rear axles so I was trailered for the night
Old 06-11-2004, 12:34 AM   #13
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
well it all depends on where exactly you hit peak power, on the stock ecu most HP peaks at anywhere btw 6-6.5k, so to be safe shifting at 7k is good, but hey shifting at 6.5k might be better for some
Old 06-11-2004, 02:01 AM   #14
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
it mostly depends on what turbo your running. Shifting at 6k is pretty stupid because you will be at too low rpm in the next gear.
dan avoN7 is offline   Reply With Quote
Old 06-11-2004, 02:53 AM   #15
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
My problem is that after I shift into second I get a lag on my next gear. The turbo bogs is that because I am dumping the clutch or is that totally normal is there a way for me to minimize the lag on it.
Old 06-11-2004, 11:42 AM   #16
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
if your lagging after the 1-2 shift then your not shifting fast enough. I used to have the same problem when i put in the vf30 (yes its not huge but i noticed a difference) I would shift then the rpms would drop too low and the turbo would have to spool again. Because of this i relized i wasnt shifting correctly or fast enough. Now when i do the 1-2 shift the front end doesnt dive, just stays up and the car pulls hard.
Old 06-11-2004, 06:37 PM   #17
2002WRXSTi
Member#: 58647
02 Exedy Carbon
I let off the throttle a slight amount on the first second shift but then flat shift the rest of the gears. Seems to work best for me that way.
Old 06-12-2004, 03:11 AM   #18
thesmokingman
Member#: 17751
Stock wrx heads stop breathing well at the upper regions. Do with it what you will, but the amount of thrust available above 6500 is at a reduced rate versus the area below that.
BTW, remind me to stop backing you up. There are many ways to the same goal. Thanks for telling me I have no idea wth I'm talking about.
Old 06-12-2004, 07:23 AM   #19
turbo2nr
Visiting NASIOC Timeout
Member#: 63849
Arrow launching
I have at least 500 runs on two different wrxs. It is the most difficult car to launch in the world! This is my favorite way with a manual trans for this car.
1) lightly depress throttle untill you see 5500rpm and try to maintain while watching the tree
2) do not side step clutch, do not release slow, but somewhere in between.
3) a little front left wheel spin is good
4) do not paint traction compound (VHT) on tires or you will break something
5) sticky, wide tires will also break something
6) a stock clutch is strong enough to break everything!
7) i have had over 300 launches at dragstrip with only half wear on one clutch, that includes many smoked clutches( that is when you are taching out in first, but are going no where) clutch will be ok after it has cooled, just leave drag strip and do some semi hard shifting for twenty min. it will come back to life
8) I have nipped into the 10S with major car lightining, dogbox, 500hp avo turbo, nitrous, no exaust at all, no bumpers, swaybars, airbags, a/c, lightweight seats, no crash bars, no sub-frame connector. I inject methanol/water to prevent detonation along with 116octane fuel. also i pack my top mount intercooler with ice or better yet, dry ice in the pits. the extra volume of piping for a front mount greatly increases turbo lag. fmi is ok for street and road racing, but my top mount will chill better for short duration drag.(using ice or dry ice)
9) i can't wait untill east coast shootout '04
turbo2nr is offline   Reply With Quote
Old 06-12-2004, 12:25 PM   #20
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
o ok so now 6000 all of a sudden turns into 6500...
all i said was the truth, you shift at 7k to be conservative or 6700 or so if you really wanna be nit-picky, you said to shift SOONER then 6000rpms which is the dumbest remark i have ever heard because no matter how you are making your power, it'll peak btw 6-7k on a wrx, so shifiting sooner then 6k is the last thing you'd want to do!
back me up? i have no idea waht your talking about. didnt mean to be harsh but sometimes the truth isnt pretty.
Old 06-12-2004, 10:39 PM   #21
thesmokingman
Member#: 17751
Did I say shift sooner than 6000rpms? If my post was unclear, ask for a clarification. Peak power comes 1K rpms before redline, thus what's the point in staying in it till 7K like the convention says to? Thats my point. It would have been easier if you asked me to clarify, instead of the typical way in which you reacted. Now I know.
Old 06-12-2004, 11:54 PM   #22
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
Old 06-13-2004, 08:59 AM   #23
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
imo, although not optimal, it's not really the heads--it's the turbo running out of steam. there are plenty of folks out there with bigger turbos making quite nice power all the way to 7200rpms.
jm2c
ken
Old 06-13-2004, 10:51 AM   #24
Hassassin
Member#: 16771
12.9 @ 102MPH
1.784 - Stock Turbo
jm2c
ken
exactly... he gets all up in a hissyfit for nothing... jeeeeeez
Old 06-15-2004, 07:57 AM   #25
eurodick
Member#: 64075
i like cicadas
eurodick is offline   Reply With Quote
WRC STI launch vs stock STI launch sunnyniazi South West Impreza Club Forum -- SWIC 6 01-27-2008 03:02 PM
SRT-4 launch > WRX launch srturbo Off-Topic 42 01-02-2007 11:22 PM
('93-'01) Subaru launches www.rally.Subaru.com Mike Smith Impreza Forum 5 05-11-2001 01:06 PM
('93-'01) houston we have a launch ! jclamon Impreza Forum 1 05-02-2001 08:09 PM
('93-'01) Launching with stock suspension, shocks, and rims = bad?? RSarte Impreza Forum 14 04-08-2001 10:33 PM
