Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 09-28-2004, 08:28 PM   #1
Member#: 70820
2004 WRX STi
Default steering rack bushing install. how hard to DIY?
I was thinking about getting the Whiteline steering rack bushing kit and I was wondering how hard is it to install? Is this something I can do in my garage? Also, does it really make a noticable difference? Thanks.
nwdriftking is offline   Reply With Quote
Old 09-28-2004, 08:46 PM   #2
Member#: 10757
2013 BRZ Limited 6MT
Relatively simple to do. It will take about 1.5-2 hours if you take your time. Can be a little quicker if you work quicker. Drive up on ramps, mark steering knuckle, take everything apart, bend the power steering lines a bit to get the driver's bracket off, then reinstall. It made a difference on my car, steering felt much better.
cnk is offline   Reply With Quote
Old 09-28-2004, 11:02 PM   #3
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
well, i just did this mod this weekend in my apt parking lot
its less then a hr job. not too bad, and not as bad as everybody said.
PARANOID56 is offline   Reply With Quote
Old 09-29-2004, 01:03 AM   #4
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
yo tambien!
Definitely helps to have an extra set of hands to "massage" the driver's side bushing into place.
BTW - this could be one of the best mods I have done so far. Very noticible in a small way.
MT_WRX is offline   Reply With Quote
Old 09-29-2004, 04:31 AM   #5
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
15 minute job.
you need:
-8, 10, 12, 14mm sockets and various racthets and extensions
-pack of grease
-new bushings
-pair of big heavy needlenose pliers or some good serrated slip-joint pliers
-drive up on ramps and make sure your steering is centered
-crawl under with all your tools and a shoplight
-unbolt the small bolt holding the PS hardline where it goes up into the engine bay on the passenger side
-unbolt the bolts holding the rack brackets on
-pull the rack brackets down and out of there - you may have to bend the hardlines a little on the driver side to get it out don't bend it a lot, just enough
-yank out the old bushings by moving the rack down as far as it'll reasonably go and gripping them with the pliers
-install the driver side bushing first by greasing it up a LOT and then sliding it around... you should slide it around the front of the rack over top and around to the rear. A screwdriver may help push the leading edge of the bushing around the rack if your dexterity is that of a computer programmer. Position it fully and then push the bracket for that side into place but don't bolt it up yet.
-install the pass side bushing in a similar manner. this one will be easier to slide around. put it's bracket on
-bolt up both the brackets
-bolt up the little bracket holding the hardlines up by the engine bay
-wash hands and put on some clean pants
-drive car off ramps and enjoy
nhluhr is offline   Reply With Quote
Old 03-11-2006, 01:10 PM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Originally Posted by nhluhr
15 minute job.
....-drive car off ramps and enjoy
For anyone that didn't know, Nick is teh Man.
It took me more like an hour, because I stopped after the passenger side to look up information about loosening the steering column -> steering rack bolt (didn't want to screw it up). Fortunately it lowered about a half inch without dropping completely out, so I didn't have to worry about re-aligning it.
It was Nick's technique for getting the bushing in that made this really easy for me.
Butt Dyno is offline   Reply With Quote
Old 09-29-2004, 06:27 AM   #7
Member#: 26607
2002 wrx wagon
did this last weekend. i like the bushings.
it took me an hr to get it done...including time spent jacking up the car etc....
lube up the drivers side bushing to get it in....and bend the power steering lines a bit with a screwdriver or something, to get enough room to move the bracket over towards the drivers side so you can get to the bushings.
garie is offline   Reply With Quote
Old 09-29-2004, 08:32 AM   #8
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
The grease packet is your friend. Don't be afraid to grease that driver side bushing up. It makes a big difference.
CTKAG is offline   Reply With Quote
Old 09-29-2004, 09:24 AM   #9
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
Egan is offline   Reply With Quote
Old 09-29-2004, 10:31 AM   #10
Wagon Joe
Member#: 34436
did mine yesterday and DAMN did it make a difference in steering response! I already have rear swaybar, endlinks, and front/rear strut braces, so maybe that amplified the improvement. Hardest part for me was also getting the damn square bushing around the rack... I got it three-quarters of the way, and it took forever to get it to peek around the front. Finally, some coercion with a screwdriver got it all the way around.
Wagon Joe is offline   Reply With Quote
Old 03-11-2006, 02:15 PM   #11
Member#: 61884
It makes a very noticable difference. I don't know what Subaru was thinking with the OEM bushings...
ps. gease the stuffing out of teh new bushings before installing.
boxered is offline   Reply With Quote
Old 03-11-2006, 05:12 PM   #12
Back Road Runner
Member#: 60082
2004 Forester STI
There was a movie of a full steering rack bushing install floating around here somewhat recently.
Back Road Runner is offline   Reply With Quote
Old 03-11-2006, 07:25 PM   #13
Member#: 90438
Yea the driver side isnt as easy as the passenger side, but with a lot of grease it will slide in I lost most of the slop in the steerin wheel. Its good. I just installed em last night, as well as a helix front sway bar.
IIdiceII is offline   Reply With Quote
Old 03-11-2006, 07:54 PM   #14
Member#: 88954
'05 Saab 92X Spec C
desert silver metallic
I just did it this morning. It took me about 2 hours but i took my time. I have the 05 sti steering rack so I don't think it was as hard as the regular rex install would've been anyway. I didn't really notice that much of a difference, and when I took the stock bushings out, they seemed pretty solid anyway...o well.
desertaero is offline   Reply With Quote
Old 03-11-2006, 08:07 PM   #15
Member#: 65699
15 WRX
WR Blue
The 05 models got a new rack design so they aren't as helpful as they are on the older models. Though for $50, why not. I think I'll be throwing mine on tomorrow.
tuskenraider is offline   Reply With Quote
Old 03-11-2006, 09:26 PM   #16
Member#: 108975
2013 Impreza
Marine blue
where can I get one of these bushings for my GC8? I think it was a friday when they built my car and they used marshmallows on my steering rack.
FuriousGeorge is offline   Reply With Quote
Any tips for a DIY steering rack bushing install? kaisersouse Service & Maintenance 3 03-29-2006 11:53 PM
Help if you lowered your rack for steering rack bushing installation maxler3 Brakes, Steering & Suspension 19 09-13-2004 02:11 PM
Whiteline Subframe Bushing Kit And Steering Rack Bushing Install North Ursalia Brakes, Steering & Suspension 94 11-04-2003 01:09 AM
comfort ALK and noltec steering rack bushings installed slater Brakes, Steering & Suspension 16 04-23-2003 12:19 AM
whiteline steering rack bushing install skoobywrx Brakes, Steering & Suspension 2 12-09-2002 08:02 PM
