South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 12-03-2004, 01:22 PM   #1
kwh29
Member#: 22100
Default WRX Exhaust on the 92 Turbo Leg
Wow it's hard to believe how quiet this car is now -- the exhaust is completely inaudible at cruise but still sounds nice at full throttle. The buyer is going to be very happy. That 3" turbo back with dynomax muff. was LOUD, even at cruise.
--Kevin H.
kwh29 is offline   Reply With Quote
Old 12-03-2004, 02:24 PM   #2
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Did you have the exhaust shop do all the modifications to the WRX exhaust (i.e. the hanger swaps and the lengthening required to fit it to the BC/BF Legacy Turbo)? How much did the shop charge you for that setup? Did you get a new O2 bung welded in, or just use the WRX's post-cat bung (or did you only use the catback)?
I need to upgrade the exhaust on the Legacy, but I want to keep it quiet in the process. Of course, lately it's been "upgrading itself" as it's started getting progressively louder as the condition of the exhaust system worsens...
Shane
Warp3 is offline   Reply With Quote
Old 12-03-2004, 03:07 PM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
You still owe me a stock exhaust because of this!
-Biggly hasn't forgotten
DrBiggly is offline   Reply With Quote
Old 12-03-2004, 03:13 PM   #4
kwh29
Member#: 22100
Not!
You said you didn't want one after you sold the red car I thought?
--Kevin H.
Old 12-03-2004, 03:11 PM   #5
kwh29
Member#: 22100
I had the shop do the mods -- the front and middle section fit perfectly. The brackets on the tranny even match!
The shop moved the first hanger (on the midpipe) back about 2" and down about 1/2"
They added about 4-1/2" to the straight part of the rear section directly under the axle.
They cut off the hanger directly behind the axle then welded the cut part back on in a way that works.
They cut off the drivers side rear hanger and rotated it around then welded it back on. The pass. side rear hanger fits perfectly without modification.
I'm using the O2 bung that's on the rear cat. This is probably not ideal but the car works and there's no black clouds so I'm not too worried.
It was sort of expensive -- $55 after the club discount.
--Kevin H.
Old 12-03-2004, 04:22 PM   #6
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I have some parts now, but not an entire exhaust. You don't remember how reluctantly I gave those to you?
Old 12-03-2004, 10:51 PM   #7
kwh29
Member#: 22100
Biggly, you're on crack!
(that's what Kevin says, but this is Steven hijacking his username)
Hey, I hear newscooby has a full stock exhaust he's not doing anything with, hint, hint.
Sellin the 92 t-leg Arctic Assassian AKIC Private Classifieds 21 01-11-2009 07:44 PM
92 Turbo leg sedan part out. old school NWIC Private Classifieds 6 05-25-2008 07:53 PM
new scoop on the 92 turbo bmxkelowna Legacy Forum 18 06-07-2006 04:29 PM
92 turbo leg 5mt in cars fs forum kwh29 Pre-2002 Factory Turbo Powertrain 4 12-06-2004 08:50 PM
WRX exhaust on the OBS Mgardenier New England Impreza Club Forum -- NESIC 11 03-22-2002 10:46 AM
