Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 01-01-2005, 02:00 AM   #1
dgp2003wrx
Member#: 60955
2003 wrx
blue
Default spark plugs
i read unabombers faq, but i still have a question it says in there that if they are pre-gapped they are not intended to have the gap changed by the end user, so i'ts about time i need a set of one step colder and a guy on here has some ngk iridium one step colder and he says they are pre gapped at .44, so i was wondering if i shouldnt buy these becuase they are already pre gapped? or if i can change the gap
dgp2003wrx is offline   Reply With Quote
Old 01-01-2005, 10:15 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You [i]can[i] gap iridium plags, but you best leave it up to someone who knows the theory of gapping iridium plugs. .44 is NOT good, so they would have to be gapped by someone who knows what they are doing. The reason you need a pro is that if you mess them up, you will ruin the iridium plug as teh tip is so, so small.
Old 01-01-2005, 10:20 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Gapping ANY plug down from .044(-11) to ~.030 for a WRX is a bad idea.....and it is REAL-REAL easy to make a good $11 plug into a paperweight in a blink.
Get the correct plug to start with, the NON -11 plug , and go from there.
Old 01-01-2005, 11:11 PM   #4
AirForge
Member#: 70035
I had to decrease the gap on my autolite plugs. They were up in the .40 range out of the box (even though the guy at autozone said they were pregapped to .30). I just tapped em down a little bit and gapped them to .30. Ive had em in for about 300 miles and it runs like a champ. I donno, maybe i just got lucky.
AirForge is offline   Reply With Quote
Old 01-02-2005, 01:02 AM   #5
rbcsaver
Member#: 78039
02 WRX
WRX Blue
AirForge,
Their regapping dicussion only pertains to the iradium plugs. But it has been my many years of experience that the correct plug is usually pretty close outta the box.
regards,
Steve
rbcsaver is offline   Reply With Quote
Old 01-02-2005, 09:36 PM   #6
Uncle Scotty
OK buy Nates beans
An NGK sparkplug that has a '-11' at the end of the number is pre-gapped at 1.1mm or .0433" That is the WRONG plug because the SAME plug WITHOUT the '-11' is pre-gapped at .7-.8mm or .0275-.0314" which is the CORRECT plug to start with, for a WRX.
This IS on NGK's website...
Old 01-11-2005, 04:30 PM   #7
sparkplugs
Member#: 79003
no matter the plug type, you shouldn't gap < or > .008". The reason for this is the ground electrode and center electrode won't line up properly, hindering spark plug performance.
The manufacturers say you should not gap iridium plugs. This is because most people do not know how to properly gap a spark plug, and the center electrodes on the ultra-fine iridium can easily snap if mishandled. There is no warranty for snapped center electrodes. The manufacturers say an iridium spark plug will run so much better than a traditional plug, even if it is not gapped for that motor, that they would prefer you just leave it rather than risk snapping the center electrode.
Here's instructions on properly gapping:
"If it iss necessary to widen the gap, do so with a tool that only pulls back on the ground electrode without touching the center electrode or the porcelain. To close the gap on a plug, gently tap the plug, electrode first on a hard surface." (taken from sparkplugs.com's "sparkplug 411" page)
Scotty's 100% correct on the "-11". Start with the non"-11" plug and this will minimize or eliminate the amount you will need to gap.
sparkplugs is offline   Reply With Quote
Old 01-11-2005, 10:46 PM   #8
XRayHipp
Member#: 50070
2002 Black Slushbox
2.5 Ounces to Freedom
Sorry for the mis-understanding .. but what is the correct gap for 2.5NA???
XRayHipp is offline   Reply With Quote
Old 01-11-2005, 10:56 PM   #9
Uncle Scotty
OK buy Nates beans
for the NA, 2.5, SOHC, according to the FSM, .039" - .043"
So the '-11' plug is the CORRECT plug for the NA, SOHC, 2.5
Old 01-11-2005, 11:01 PM   #10
XRayHipp
Member#: 50070
2002 Black Slushbox
Kong
Old 01-12-2005, 08:05 AM   #11
Uncle Scotty
OK buy Nates beans
Kong
....it's FASTER now
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 709 Yesterday 08:02 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
