Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-08-2005, 02:41 AM   #1
dgp2003wrx
Member#: 60955
2003 wrx
blue
Default ecutek boost problem
ok im not sure what is causing this, but i have a stock turbo and i just got my car reflashed on wednesday. when i get on the gas the boost spikes to about 20 then drops down to about 16, my mods are catless TBE+Up-pipe, and intercooler hoses. i had the 3/16 mod from being stock, but then i was told after i got the reflash that, that could be causing the high boost, so i took that out yesterday and today its still spiking, it was about 15-25 degrees out today when i tested it out, so is there anything anyone can recommend or have any thoughts on how to reduce the boost, or what is causing, im going to calll the shop that tuned it on monday to see whats up. i have a 2003 wrx
dgp2003wrx is offline   Reply With Quote
Old 01-08-2005, 09:47 AM   #2
antimullet
Member#: 44193
2008 WRX STi
You may not have spike at all; it could be the way your tuner designed the boost mapping.
ECUTECK is good stuff they can ramp the boost up in the low to mid range and then taper it off as the revs climb for a safety factor. ANd of course they compensate for the increased boost with adjustments in the other areas IE fueling ignition etc. This may be what you have.
Was it dyno or road tuned? Or thru the mail?
antimullet is offline   Reply With Quote
Old 01-08-2005, 10:10 AM   #3
dgp2003wrx
Member#: 60955
2003 wrx
blue
i belive it was just an off the shelf map, they said it would be a 150-200 dollar more(i cant remember) for the dyno tune, but isnt it bad to have the boost on a stock turbo that high, or is it "ok" for it to just spike to that then taper down?
Old 01-08-2005, 10:43 AM   #4
Performance Driven
Vendor
Member#: 75855
04 Dynapack
it should go to the tune boost setting.
have ecutek and only time when it spikes
when it is 40 or below and my low boost
is 16.3 and spikes to 17 and come right back.
when it is warm, 50 or above the boost never
spikes.
Performance Driven is offline   Reply With Quote
Old 01-08-2005, 11:44 AM   #5
dgp2003wrx
Member#: 60955
2003 wrx
blue
yea it is very cold, so i was also wondering if that causes it to spike
Old 01-09-2005, 02:09 AM   #6
dgp2003wrx
Member#: 60955
2003 wrx
blue
any other ideas?
Old 01-10-2005, 02:24 PM   #7
4830DeuceWRX
Member#: 54762
02 Aspen WRX- VF22
and S202 Springs & Struts
Check w/ you tuner, im sure he will ahve the answer for you.
4830DeuceWRX is offline   Reply With Quote
EcuTEK reflash problems Jim Payne Commercial ECU Reflashes 1 09-16-2006 01:24 PM
Weird ECUTek Boost Solenoid problems Virusx86 Engine Management & Tuning 1 10-23-2005 12:19 AM
ecutek boost problem dgp2003wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-08-2005 02:54 AM
vf34/Vishnu Ecutek Reflash Problem Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-19-2004 02:48 AM
ecutek possible problem? onesillyracer2k2 Engine Management & Tuning 6 05-31-2003 04:57 AM
