Old 01-21-2005, 01:25 PM   #1
scoobysnowrally
Member#: 76478
06 STI & Tribeca
Aspen Graphite
Default how to depressurize ABS
Ive looked in the mitchel program and know where that I can find does it say how to depressurize the system. but yet it stresses the siverity of doing it.
scoobysnowrally is offline   Reply With Quote
Old 01-21-2005, 01:39 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Huh?
There is no pressure in the system until you put your foot on the brake pedal. If the ABS is activated (wheels locking up), then the ABS pump will kick in and regulate the pressure going to the wheels that are not turning. As soon as you take your foot off the brake pedal, the pressure is gone.
OneOBS is offline   Reply With Quote
Old 01-21-2005, 01:58 PM   #3
scoobysnowrally
Member#: 76478
06 STI & Tribeca
Aspen Graphite
Im replacing all rotors, pads, and changing fluid. So in order to bleed the system I wont have to depressurize the ABS with a scantool because in a sense there is no pressure. I dont know but how sure are that the ABS doesnt hold its pressure
Old 01-23-2005, 03:48 PM   #4
MrHorspwer
Member#: 4063
Very sure. Do everything just as you normally would, nothing special is required.
MrHorspwer is offline   Reply With Quote
How to Read ABS Trouble Codes Austin Brakes, Steering & Suspension 124 03-19-2016 12:08 PM
How to disable ABS on 96 Legacy L pmaryan Brakes, Steering & Suspension 2 04-27-2008 10:04 AM
How to pull abs codes from 96 impreza? simpreza2 Brakes, Steering & Suspension 0 09-04-2004 01:21 PM
How to disable ABS? lushboy Legacy Forum 8 04-13-2002 06:50 PM
