Old 02-20-2005, 09:23 AM   #1
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
Default Some basic oil questions
I checked the unabombers oil faq, but didn't find what I was looking for.
I have a 2005 wrx with 850 miles on it. The manual says you don't have to change the oil until 3000 miles, but I've heard lots of people say to change it at 1000. Which is more common?
I also heard it's not good to switch to synthetic right away. Is this true?
If I don't switch to synthetic, what is a good brand of dino oil? Up until now all i've had to get was whatever was cheapest. :-p
Thanks to the answers to the noob questions.
CletusTheDwarf is offline   Reply With Quote
Old 02-20-2005, 09:37 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
on these newer engines you really dont need to change the oil til 3000
some guys are old skool and paranoid and insist on changing it at 1k
you must decide for yourself on that one.
Jamie
www.subiegal.com
Subie Gal is offline   Reply With Quote
Old 02-20-2005, 09:42 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
This is one of the biggest cans of worms there is.......but do yourself a favor and don't put syn oil in your car for at least 5k miles......there are internal parts that have to 'machine' themselves to eachother and syn oil can be too slick to allow this to happen properly....and it's not just the rings seating, either.
....waiting for this to be locked/moved....
Old 02-20-2005, 11:02 AM   #4
z&cobb
Member#: 12344
2002 2JC
blue
Cliff Notes: Jamie and Scotty are right. What follows is a bit about cylinder walls.
Drive the car as close to what subaru suggests regarding 4000 rpm for 1000 miles, mostly in the mountains or back roads with lots of up and down shifting and use the gears a lot and don't forget to get into the boost. That's good for the very hard Nikasil TM coating/"liners." Then keep the oil in for 3000 to 3750 miles.
I did change to synthetic at 3750 miles, with a weight recommended by Subaru for the environmental conditions (Fall/Winter of 2001). If you can't do the right kind of driving during and past break in, you should probably do as Scotty said, or maybe go even longer before changing to synthetic.
Don't use high sulfur gasoline, which can be bad for the Nikasil. Nikasil has been used on many "elite" cars, including the BMW V12, and in a lot of racing engines for cars, bilkes and ultralites. BMW owners have had problems with Nikasil, usually owner preventable via better maintenance and better fuel. However, BMW once had an engine replacement program for a Nikasil problem. Problems tend to go with Nikasil plating on high pressure castings which are porous. More facts can be obained via Google for Nikasil and process or patent.
There is an engine manufacturer, I forget which one, who recommends that Nikasil engines be broken in on the road, and never on a dynamometer, so there seems to be a little science/art about this Nikasil business.
The good news about Nikasil, is high durability (way over 100,000 miles) plus good heat transfer and low friction.
z&cobb is offline   Reply With Quote
Old 03-04-2005, 11:44 PM   #5
shemoves
Member#: 80663
2005 STi
Why is it good to do revvy mountain driving rather than "easy" cruising during break-in?
shemoves is offline   Reply With Quote
Old 02-20-2005, 11:36 AM   #6
HomerJay
Member#: 1135
2005 WRX WAGON
I put synthetic at my first oil change. No problemo. Oh, it was at 3K. I don't drive my car very hard though. Turbo cars usually burn oil and synthetic holds up better, hence the change to synthetic.
HomerJay is offline   Reply With Quote
Old 02-20-2005, 12:09 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
well - if you go with the assumption that any random crap left around in the system from the engine build will get flushed out after 500 or so miles, changing the oil is just to get rid of that.
Modern cars don't use special oils for break-in, so changing the oil at low miles really doesn't matter from that point of view (i.e., if the oil is reasonably clean, and the filter isn't loaded up with metal fines or anything, and you are just changing to fresh conventional oil at 500 or 1000 miles, the engine won't notice any difference). I view the early oil change as a "just-in case" sort of thing. ymmv.
DrD is offline   Reply With Quote
Old 02-22-2005, 09:24 AM   #8
bluesubie
Member#: 767
04 FXT
If the folks that change that early really want to get rid of that random crap in the system from the engine build, they had better change the oil every 500-1,000 miles until the car reaches 10-12,000 miles.
There are lots of Subaru used oil analysis' out there showing the engines are still wearing in at 12,000.
-Dennis
Old 02-22-2005, 06:35 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if the engine is running, then wear is taking place.
by random stuff I am thinking more bits and pieces left over from the building process (excess gasket material, small metal chips, etc.) - not particles from normal wear and tear.
Old 03-14-2005, 12:32 AM   #10
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
You might be surprised how little (practically none) wear can take place on a broken in motor, especially compared to when it was young.
santofontana is offline   Reply With Quote
Old 03-14-2005, 12:30 AM   #11
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Modern cars don't use special oils for break-in, .
That is probably not true. UOAs over at BITOG have pretty much proven that manufacturers use oils with more additives than normal, especially moly. The oil they use for break-in would not qualify for SM classification because of the extra adds. I know Honda does this, but Im not sure if Subaru does it, I would go search but i need to go to bed.
Old 03-14-2005, 07:28 AM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
that's interesting - I wonder if it's just the oil their chosen supplier gives them, or if there is a specific reason they use a higher additive concentration - in the days of old, the break-in oils were generally thinner and allowed increased wear during the break-in process (so that things can seat properly) - increased additives, esp. things like moly. could be corrosion inhibitors (molybdates are frequently used) or perhaps to improve the lubricity of the oil I would think - maybe they want to slow wear in the initial period to allow things to gradually seat, and a higher additive conventional is cheaper than a synthetic fill? - by the way, what is UOA and BITOG? (not up on my acronyms, I guess )
Old 03-14-2005, 08:52 AM   #13
bluesubie
Member#: 767
04 FXT
Used Oil Analysis and Bobistheoilguy.com (usually refers to the forums there).
Subarus do not use a break-in oil or additive.
-Dennis
Old 03-14-2005, 02:46 PM   #14
shemoves
Member#: 80663
2005 STi
One of the dealers I spoke with said my STi's factory oil had a break-in add pak. I know, never trust the dealer, but I spoke with him about differentials and the DCCD and it sounded like he new what he was talking about there...anyone know for sure?
Old 03-14-2005, 06:13 PM   #15
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
so when they do the oil analysis, how do they differentiate from something which may be due to an assembly lube (so it's in the first oil change, but not because the factory fill had something special in it) and something which was added to the oil to aid with break-in?
Old 02-20-2005, 05:50 PM   #16
rexaroo
Member#: 35732
2002 WRX Wagon
DrD has it right. Sorry to spoil the party but yes you can and should change over to Mobil 1 around 1000 miles. It won't hurt your turbo engine in any way whatsoever and will confer so many positive benefits we don't have space to go into them here. I changed mine over actually at 640 miles and at 25K the engine is happy as a clam, runs strong as hell, burns NO oil between changes and in short has no problems or issues whatsoever. (Knock on wood ) The thing about flushing out possible machining contaminants and loose gasket materials in a new engine is very important--you don't want those foreign materials circulating in your oil for 3000 miles, no way. Great way to put a lot of unnecessary "mileage" on your brand new engine.
rexaroo is offline   Reply With Quote
Old 02-21-2005, 10:15 AM   #17
z&cobb
Member#: 12344
2002 2JC
blue
Nah, Nah, Nah, everything you said holds for my engine at 78,000 miles, and I followed my own paranoid path.
Old 02-21-2005, 10:52 PM   #18
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
my .02: wait until 3000 and use a decent dino oil (I like Castrol GTX)
never heard of Nikasil btw
Mike Wevrick is offline   Reply With Quote
Old 02-21-2005, 11:54 PM   #19
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
it's a wear resistance coating used by Subaru and a number of other manufacturers
Old 02-22-2005, 07:22 PM   #20
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I had no idea that Subaru used Nikasil!
FWIW, I changed my oil with dino at ~1700, 3,500, 7,000 and 10,000 before switching to Mobil 1. My motor uses no perceptible amount of oil between changes with 58K on it now. I probably could have started using synth earlier...ymmv
Stanley is offline   Reply With Quote
Old 03-05-2005, 10:06 AM   #21
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Cruise control, in particular, is forbidden during break-in. Vary the RPM as much as you can within the limits provided (4K). I believe a constant RPM has the effect of polishing the rings and cylinder walls instead of allowing them to wear enough to seat properly.
OneOBS is offline   Reply With Quote
Old 03-12-2005, 01:59 AM   #22
shemoves
Member#: 80663
2005 STi
Hmm...I was planning on doing some early oil changes but a guy at the dealer (i know) said that it is a good idea to keep the factory oil in for a while as it has an add-pack that helps with break-in. Anyone know any more info on this one?
Old 03-12-2005, 02:19 AM   #23
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
ewww...cruise control, never used it and i never will. during engine break in you definitely want your engine RPM to vary to properly break in the engine. it's even good to do brief periods of WOT up to roughly 55mph to properly set the rings in. basically you don't want to pamper your engine like a baby, if u want it to run properly you gotta rough it up a little.
i'd say use synthetic oil on your 5th oil change. dino oil does it job fine for new engines before reaching 15k mile mark. i like Castrol GTX, it's a good dino oil. after that use Mobil 1 or Royal Purple or something. and i use the Puralator oil filter, although i'm not sure if there is much of a difference between Puralator and OEM oil filter
eltrouble is offline   Reply With Quote
Old 03-12-2005, 02:52 AM   #24
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
I've changed the oil on two STi's at less then 10 miles, as the ones that come with port installed guage pods still need to have the oil temp sensor installed. I think if the oil was treated or special in some way, we would not be doing this. Also I changed my oil at about 1000 miles, and it appeared to have moisture in it. Even though it only had 1k on it, it had sat at the dealer for 8 months and who knows how long since the oil was poured in initally. I've done fleet service, they change every 3 months regardless of mileage. btw, I also switched to mobil 1 at around 5k.
00Maddog is offline   Reply With Quote
Old 03-13-2005, 07:24 PM   #25
shemoves
Member#: 80663
2005 STi
huh...good to know. I used to be all M1, but now I am torn between Redline and Amsoil 10w30 (once I do go to full-synth). I decided not go M1 cause it is thin and not with the jerman juice because of its winter viscosity rating being out of Subie recommendations. As far as dino is concerned...would OEM Sub or Castrol be best? (or other than those).
some basic rebuild questions cowboy_Rob Built Motor Discussion 6 03-29-2009 11:37 PM
Some basic tuning questions... firedust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-14-2003 11:47 AM
some basic questions am0n Newbies & FAQs 7 09-08-2003 03:39 PM
Some basic questions about getting HIDs WHTWRX Interior & Exterior Modification 7 12-20-2002 01:23 AM
Some basic and one stupid question MarkZ Newbies & FAQs 5 10-30-2001 04:23 PM
