Old 03-17-2005, 06:18 PM   #1
maxim
Member#: 53037
1993 Fake WRX
Grandma Red
Default ej18 ej25 SWAP Dyno Results, HEADS UP!
Before a/f adjustements my car ran LEAN, WAY LEAN! especially from 4k-5k rpm.
run 3: missing (their printer wouldn't work, Ill post it in a few days), but
recorded 130 WHP 137 lb/ft torque. and a very smooth a/f curve never below 12.5 and above 13.5 from 2500 rpm +.
93 impreza LS auto with 2001 manual 4.11 Stage II SOCH 2.5.
Adjustments to a/f were made using HKS afr (awesome product btw)
Hm... lets see. Whoever said 1.8 ecu + 2.5 = rich? Think again.
Detonation at 3500-3800 rpm WOT was almost cured during 3rd run(and I thought it was exhaust rattle, I am lucky I didnt blow my motor running 87 octane). You can actually see Detonation on the dyno results. Hm... time to stop saving money on gas. 1.8's Ignition is quite aggressive, who needs the know sensor? Thanks Suabru. Anyway, I am happy, I didnt realise I was missing 15 hp on average. Although peak hp was only improved by +5 (it was a little rich at 5500rpm), the car is faster, much much faster. $80 well spent.
To all the people who have done this swap I would recommend 91 octane, AFR/AFC, and a few dyno runs. I only drove this motor for 1500 miles and they were easy "dating" miles. If I drove it like I normally do (4k-6k canyons) my motor would have been out of my car by now and I'd be scratching my head over a bent rod/failed bearing from detonation.
maxim is offline   Reply With Quote
Old 03-17-2005, 06:21 PM   #2
maxim
Member#: 53037
1993 Fake WRX
Grandma Red
Mine should be fine on 91, since a/f is good and there's almost no carbon deposits. Where does yours detonate? 3700 rpm?
Old 03-17-2005, 07:47 PM   #3
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
Thats awesome. I was one of those that said it runs rich. When I first did the swap, I noticed that when then engine is cold (startup in the winter) It ran and still does run, noticeably rich until it warms up.
Detonation: I definatly had the same issue when running 87 and 89, I even notice it on occasion running 91. It would start to detonate under high loads WOT, 93 makes everything nice though.
I was unable to view your dyno graphs, said i needed to register, Ide love to see them though...
Hawk296 is offline   Reply With Quote
Old 03-18-2005, 10:44 AM   #4
Diz
Member#: 874
2003 Honda S2000
2004 Mazdaspeed MX-5
Thanks for posting your results. I'm waiting for a local shop (SuperRupair) to set up their dyno so I can do a little tuning.
I ALWAYS run the 91 in the wagon. However, it's a higher compression hybrid (phase I EJ25 shortblock, EJ22 heads, Delta cams), so I knew what I was getting into from the start.
Nice shot of the motor, too. Looks clean.
Diz is offline   Reply With Quote
Old 03-18-2005, 11:56 AM   #5
AcquaCow
Member#: 36838
2000 RS Sedan
2004 STi w/RS body swap
One of these days I will swap =P
Hopefully this summer.
-- Dave
AcquaCow is offline   Reply With Quote
Old 03-18-2005, 07:23 PM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Would another option for the poor folks be to purchase a used ECU for the same year/model of the motor you are using? I mean, you could purchase an ECU at places like car-part.com. That's where I get my ECUs from.
Kevin Thomas is offline   Reply With Quote
Old 03-18-2005, 08:34 PM   #7
maxim
Member#: 53037
1993 Fake WRX
Grandma Red
Well... no Kevin. Its not cost effective in my opinion for any swap to change ecu from another Subaru. Especially when the car is OBDI and engine is OBDII. I mean just think about it, you will need to somehow wire:
A/C
Tach (analog to Digital)
Speedo, intrument panel,
heat controls,
emmission controls,
fans,
blah
This will take you at least 100 hours the first time you do it, just like the guys who do the wrx swaps. 100hrs*($15/hr or more for most of us hopefully) + cost of all parts.
That's at least $2000. And guess what? still no control over what engine does and a crappy oversensive knock sensor, etc.
For the poor folks what I did is the only option I believe is available.
I mean engine = $500, piggyback = $100, dyno time = $80. And that's it. Depending on quality of stuff you buy you can do entire swap in less than $1000.
A standalone like Link 2 would be my choice for a turbo swap, I never understood the point of 100+hrs of wiring crappy OBDII ecu on your car.
07 WRX, VF-30, e-Tune, Deceiving Dyno Graph silverf0x Proven Power Bragging 79 07-08-2010 12:05 AM
ej18 ej25 SWAP Dyno Results, HEADS UP! maxim Subaru Conversions 8 03-18-2005 08:22 PM
EJ18-> EJ25 Dyno results Hawk296 Normally Aspirated Powertrain 10 09-21-2004 09:30 PM
STi Accessport Dyno results are up at cobbtuning.com volkl23 Engine Management & Tuning 13 05-31-2004 06:43 PM
Dyno results ... what's up?? wRxbeater11 Proven Power Bragging 7 01-20-2003 11:04 AM
Message Board Statistics All times are GMT -4. The time now is 11:44 AM.
